Thread started 07 Dec 2017 (Thursday) 10:01
Affinity editor layout
elitejp
Dec 07, 2017 10:01 |  #1
Not sure exactly what its called (editing layout ?)but i bought affinity and am using the newest version. I think its version 1.6.1.86. The problem is that i cant find simple tools such as the crop tool and other basic functions which should be on the left hand menu bar . The whole layout is completely different than the trial version i was using and anything that i see in tutorials. My guess is that there must be a edit function that will change the layout to a different style.
Any help is appreciated.
6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
Pete328
Dec 07, 2017 10:43 |  #2
First make sure you are in the Photo persona. Then from the top menu bar select View. From the ensuing drop down menu ensure that the "Show Tools" item (3rd from the bottom) is checkmarked.
Pete
elitejp
Dec 08, 2017 05:04 |  #3
Ok, Im an idi0t. I bought designer instead of photo
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Dec 08, 2017 10:23 |  #4
elitejp wrote in post #18513173 (external link)
oh man, sorry but that made me LOL.
MCAsan
Joined Jun 2010
Dec 09, 2017 14:04 |  #5
Before you purchase Affinity Photo, know that it is not non-destructive once you leave the Raw Persona. You render it to go to Photos and other Personas.
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Dec 09, 2017 16:14 |  #6
MCAsan wrote in post #18514201 (external link)
Neither is PS...with both you still have the RAW file. Affinity works w/ layers so you can work non-destructively just like PS. I fail to see your point.
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
MCAsan
Joined Jun 2010
Dec 09, 2017 19:58 as a reply to  @ DagoImaging's post |  #7
Can you leave the Raw persona via hitting the develop button, go to Photos persona and do some edits, and then go back to the Raw persona to redo some raw editing?
elitejp
Dec 09, 2017 21:08 |  #8
hey its 50bucks for a lifetime subscription. Photoshop cant do that, if it could then I would consider it. And thats not even mentioning how much destructive editing you really have to do to screw up a picture. I mean its seriously alot of work.
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Dec 10, 2017 08:48 |  #9
MCAsan wrote in post #18514390 (external link)
Nope, but that only works in PS if you open the image from Cam Raw as a smart object. It would be interesting to see numbers of how many people actually do that. I for one never do that. So if you use Cam Raw, make an edit and take the photo into PS after CR and then go back to CR after other adjustments, your CR sliders are all zeroed. This is true for CR or taking the image from LR.
BigAl007
Gallery: 556 photos
Dec 10, 2017 11:08 |  #10
DagoImaging wrote in post #18514586 (external link)
I'm not sure how you are seeing that the ACR adjustments for the image are at zero, after editing a RAW in ACR, then moving to Ps, making edits in Ps and saving them as a PSD/TIFF with layers. I normally use Lr, and open in Ps from there, but I have some CR2's that are not in the catalogue, as they require preprocessing to DNG's for editing, so I tried a couple of those from Bridge via ACR.
All of the ACR edits made to the CR2 files are auto saved to the .xmp sidecar file. So the edits to the RAW are kept at that level. The same applies to opening a RAW image into Ps from Lr with the Edit in command. All the existing RAW file's edits are kept as is.
The PSD file is a new RGB file, and all of the visible image data is RGB. Yes you can open an RGB file in ACR, and there can be good reasons to do so. However since the saved file will be a new RGB file, you will start with the default settings for an RGB file if you do open it in ACR. The same applies to a new RGB file imported into Lr, which is what happens when you hit Save in Ps, after opening in Ps from Lr using the Edit in command.
So normally you keep the existing RAW edits in the RAW file, either stored in the Lr catalogue, or in xmp sidecar files, or in my case both, so that I can use both Lr and Bridge together. New images get a new set of defaults, existing images retain any existing edits, just as you would expect.
On the subject of opening the RAW in Ps as a Smart Object, that is how I have regularly opened images to Ps since I got my new system about 18 months ago. Yes it makes for a much larger file, but it does have some advantages though. One advantage is that it gives you the possibility of having multiple conversions of the same image, that you can see while using Bridge. It's nowhere close to as efficient as the Virtual Copies that you can use in Lr, and IMO Virtual Copies would be much easier to implement in Bridge than its effort at doing Smart Collections. The actual reason that I open as a Smart Object is that very often I will realise that I missed something at the RAW stage while editing in Ps, and this gives me a means to correct the problem, without the effort required to go back to the RAW editor, make the change, then get that new version into the existing RGB image as a layer. Of course the downside is that the corrections you do make to the Smart Object within the RGB file can't be propagated back to the original file. As I have got more into Smart Objects the more useful I have found them. Having flexibility built in is useful where you might need to make adjustments a few layers or steps back to balance later effects out.
Alan
Gasmansteve
1 post
Joined Oct 2017
Post edited over 5 years ago by Gasmansteve.
Dec 10, 2017 15:05 |  #11
I seem to remember they offer a 30 day refund policy! Have to say though that after buying Affinity Photo I also bought Affinity Designer and now learning digital art, both products now have excellent work books and no I don't work for them;-)a)
Regards
Steve
4,718 views & 1 like for this thread, 7 members have posted to it and it is followed by 3 members.
1519 guests, 132 members online
