Am I hearing this right from Canon that this combo will allow auto-focus up to f8???
As the 1DX would not do that...
picworx Goldmember 1,147 posts Likes: 4 Joined Jun 2005 Location: Ontario, Canada More info | Jan 03, 2018 14:46 | #1 Am I hearing this right from Canon that this combo will allow auto-focus up to f8???
MalVeauX "Looks rough and well used" More info Post edited over 5 years ago by MalVeauX. | Jan 03, 2018 14:49 | #2 1D series can AF at F8 with center point since over a decade.
Not to my knowledge and in the store the 1DX MKII + 100-400 II + 2X EXT III only shows the center point and will not focus?
Snydremark my very own Lightrules moment More info Post edited over 5 years ago by Snydremark. | Jan 03, 2018 16:31 | #4 The 100-400 + 2x TC gives you F11, not F8. That combo won't reliably autofocus on any body. You can attempt to work around it by taping off the pins that report the TC to the body and hope for the best; but it's going to be ridiculously slow to focus even then. - Eric S.: My Birds/Wildlife
picworx THREAD STARTER Goldmember 1,147 posts Likes: 4 Joined Jun 2005 Location: Ontario, Canada More info Post edited over 5 years ago by picworx. (2 edits in all) | That explains it then the video should have shown the 1.4 extender III not the 2X, but the chart was right so if I decide on this combo I will have to replace my 1.4 extender II with a 1.4 extender III if I want all those extra points?
Snydremark my very own Lightrules moment More info | Jan 03, 2018 17:53 | #6 picworx wrote in post #18532763 That explains it then the video should have shown the 1.4 extender III not the 2X, but the chart was right so if I decide on this combo I will have to replace my 1.4 extender II with a 1.4 extender III if I want all those extra points? I would presume so; yes. I don't have a 1Dx to verify that on, but that seems to be what is said there. - Eric S.: My Birds/Wildlife
apersson850 Obviously it's a good thing More info | Jan 04, 2018 05:27 | #7 If you use a 1DX Mark II together with either the EF 100-400 mm f/4.5-5.6L IS USM or the newer EF 100-400 mm f/4.5-5.6L IS II USM, you'll get AF with all 61 AF points. Anders
Thanks for this as I understand then the 2x is out of the equation if you want AF however the question is whether it is worth it to upgrade from a 1.4 II to a 1.4 III I guess it depends on what you shoot and whether the extra points is really worth it? 9 points is sill not bad
apersson850 Obviously it's a good thing More info | Jan 04, 2018 17:59 | #9 There's a noticeable upgrade of image quality between Mark II and Mark III, I've been told. I only have the Mark III, so I can't compare myself. Anders
| Latest registered member is semonsters 1510 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
