FORUMS Other Digital Cameras Olympus Digital Cameras
Thread started 09 Feb 2018 (Friday) 17:59
Oly 75-300 MK2 Dark Corners
Pagman
I just hold the thing :-)
Gallery: 1540 photos
Joined Dec 2011
Feb 09, 2018 17:59 |  #1
Hi all, just a quick quiry - I have this lens mounted on my E-M1 mk1 and have noticed that I am getting a very slight shading fall off in the corners even at f8, and wondered if this a normal thing.
There is no lens hood attached as I am awaiting that in the post.
P.
Some stuff.
bidkev
Gallery: 1932 photos
Joined Jul 2013
Apr 09, 2018 18:36 |  #2
Pagman wrote in post #18560298 (external link)
P.
Built In camera correction should have solved vignetting? Dunno if you ave to register the lens to the camera though? Is firmware up to date?
Olympus E-M5 gripped | Olympus OM-D E-M5 mkll gripped | Olympus OM-D E-M10 mkll gripped | Olympus Zuicko 12-40 2.8 pro | 40-150 | 75-300 |45mm 1.8 | 17mm 1.8 | 60mm 2.8 macro |Panasonic 12-32
Pagman
Joined Dec 2011
Apr 09, 2018 18:57 |  #3
bidkev wrote in post #18603427 (external link)
I spoke about this in the dpr forum as I sorted it out under normal multi zone metering, uisng the in camera setting, but when I use spot metering I still get dark - er corners than uisng the multi, very strange the cam has not long come back from Oly after having work done including a new shutter / rear dial and a check and clean up.
P.
Some stuff.
331 views & 1 like for this thread
Latest registered member is jeroe
779 guests, 338 members online
