Thread started 10 Feb 2018 (Saturday) 17:21
ND filter exposure & color balance off???
n1as
Post edited over 5 years ago by n1as.
Feb 10, 2018 17:21 |  #1
I just bought a brand new B&W 6 stop ND filter. Took pics with it. The images end up being under exposed by 2/3 to 1 stop and I have to dial in about 1200 deg C more color temp to restore white balance (the filter is cool).
Oh, and the corners show more light fall-off with the filter than without. This is with UWA lenses. I haven't tried with normal or tele focal lengths.
Is all of this normal???
- Keith
http://darwinphoto.zen​folio.com (external link)
DesolateMirror
Gallery: 251 photos
Joined Oct 2015
Feb 10, 2018 18:34 |  #2
Yeah, they are common problems that you have to work around for the most part. When you see 9/10 stop long exposures people will often opt to make them black and white due to the colour issues. The cheaper filters tend to suffer more from colour cast, vignetting and unevenness.
Someone who has tested a lot of ND filters might be able to give advice on which ones work well.
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Post edited over 5 years ago by Nogo.
Feb 10, 2018 19:24 |  #3
Even the best are not neutral. No matter what ND you use you will need to adjust the color in post some. The better ones just require less adjustment than the good ones do.
Learn to work with what you have. If you try to find perfect filters especially with ultra wide lenses you will go broke.
Philip
Peripatetic
Joined Dec 2016
Feb 14, 2018 01:11 |  #4
I have tried a lot of filters and B&W were my favorite until I came across breakthrough photography. Poke around the web and check out reviews. I highly recommend them.
DCBB ­ Photography
Gallery: 478 photos
Mar 13, 2018 09:46 |  #5
Peripatetic wrote in post #18563374 (external link)
I second this, there is very little color balance difference with Breakthrough's filters, even the 10 stop.
John
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 13, 2018 10:11 |  #6
Optical vignetting on an UWA when using an ND filter is going to be unavoidable. The light entering the edges of the frame is traveling at an obtuse angle. making the filter effectively thicker the further from the center of the frame you get. It's usually not too bad though, and easily corrected in post.
500px (external link)
1x (external link)
instagram (external link)
RPCrowe
Joined Nov 2005
Jun 22, 2018 22:08 |  #7
Have you tried establishing a custom color balance before shooting with your ND filter? It's real easy to do with Canon cameras, I don't know about other brands...
6,165 views & 2 likes for this thread, 7 members have posted to it and it is followed by 6 members.
1505 guests, 131 members online
