Each pixel on the sensor of the Canon 5DIV is divided into two sub pixels. If you shoot in Dual Pixel mode, two images are acquired: one composite image made by combining each of the two sub pixels; a second image from one of the sub pixels. The folks at LibRaw have made a utility that permits both images to be extracted from the resulting raw file and saved as DNGs.
Canon DPP software permits the focus and bokeh of the Dual Pixel image to be adjusted in post, based on the parallax that results from the slight offset of each sub pixel pair; however, what is even more useful is that the second image, acquired from a single sub pixel, is acquired at -1EV from the composite image - hello highlights!
Take a look here:
https://www.fastrawviewer.com/DPRSplit![]()
and here is a right up about the concept:
https://www.rawdigger.com …mode-highlights-are-there![]()
kirk
