FORUMS Sony Cameras, Lenses & Accessories Sony Lenses
Thread started 14 Feb 2018 (Wednesday) 15:09
Which wide-angle lens on a Sony A7RII (secondhand -$600) with AF ?
CanonYouCan
Post edited over 3 years ago by CanonYouCan.
Feb 14, 2018 15:09 |  #1
I know nothing about Sony glass, do they have a cheap UWA lens -$600 second handprice?
As i'm going to use an MC-11 or Metabones V for my Canon glass I only know the Canon 17-40 f4L for this price :)
It may also be a prime.
Does the Rokinon/Samyang 14 2.8 AF (Sony mount) works good with the A7RII for example, anyone tested this ?
Sony A7 III | Metabones V | Canon 16-35 F4 L | Sigma 85 1.4 Art | 70-200 2.8L II
Lighting : Godox AD600B TTL + Godox V860II-S + X1T-S
Modifiers: 60cm Collapsible Silver Beautydish + grid | Godox 120cm Octagon softbox + grid + Speedlite Flash bender
Tripod: Vanguard Alta 253CT carbon
yellowt2
Joined Sep 2009
Feb 15, 2018 12:58 |  #2
No cheap Sony wide angle zooms; cheapest is the 16-35 f/4 at ~$1300 new
The Samyang 14 f/2.8 is probably the best bet for native glass. There is also the Sony 28 f/2 which has optional wide angle and fisheye converters (which turn it into a 21mm or 16mm fisheye), but the price of the lens with converter(s) is more than the Samyang
If you want a cheap zoom you're better off with an EF mount lens on the adapter. The Canon 17-40, or Tokina makes a few wide-angle EF zooms.
Could also try the Canon 10-18; it's an EF-S lens but works from 14-18mm on full frame cameras. Might be worth trying out. https://photography-on-the.net …/showthread.php​?t=1388461
Charlie
Guess What! I'm Pregnant!
Feb 15, 2018 15:02 |  #3
due to the initial popularity of the 12-24 and 16-35GM, the 16-35 F4 has taken a hit on prices. It ranges slightly out of your territory at 700-850 used.
I'de save up a little more and get that, optically it's pretty good.
Sony A7siii/A7iii/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic G9 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
CanonYouCan
Feb 16, 2018 05:37 |  #4
And if you could chose between the Canon 17-40 f4L, 16-35 F4L both with adaptor or the new Rokinon/Samyang 14 f2.8 AF directly with sony mount, which one would you prefer and why ?
yellowt2
Joined Sep 2009
Post edited over 3 years ago by yellowt2.
Feb 16, 2018 12:45 as a reply to  @ CanonYouCan's post |  #5
I'd go with a 16-35 if you can afford it. I prefer the zoom for focal length options, and the 16-35 is significantly sharper than the 17-40
I have a Canon 16-35 f/4 L IS and a Rokinon 14 f/2.8 (the old manual focus version), and the Canon was my favorite lens on my Sony A7 (on a metabones adapter). The autofocus was pretty bad, so I manually focused most of the time; AF on the newer Sony bodies (A7ii, A7Rii, A7Riii, A6500) should be fine. Pretty much the only time I used the Rokinon was for astrophotography, where the extra stop in aperture helped. For landscapes I was usually stopping down from f/4 anyway.
The native Sony 16-35 f/4 will be a little smaller (the lens is about the same size, but you don't need an adapter), and similar in image quality (I think the Canon is a little better, but they're close). If I was buying now I would get it instead of the Canon (when I bought the Canon lens I was still using a Canon DSLR as well)
Scatterbrained
Gallery: 246 photos
Best ofs: 12
Feb 16, 2018 13:41 |  #6
Personally, my 17-40L is practically glued to my A7RII. Is it the best UWA out there? Uh, no. Do I have issues with it's sharpness? Not really. Bear in mind too that i shoot in the beach a lot where sand and sandstone really test the lenses IQ. I've found that by focus stacking at wider apertures I can get images that are plenty sharp when I need to (think of lots of sand very close to the lens) otherwise shooting at f/11 works just fine too.
500px (external link)
1x (external link)
instagram (external link)
CanonYouCan
Feb 22, 2018 05:31 |  #7
Thanks I ordered a second hand 17-40 f4L for $400, sharpness at f8/f11 isn't much difference with my previous 16-35 f4L IS I guess :)
Just read crop lenses like the 12-24 etc would also work, maybe I ordered too fast...
1,570 views & 0 likes for this thread
Latest registered member is Rebart
931 guests, 322 members online
