FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 14 Feb 2018 (Wednesday) 16:23
ARCA-style plates: What're the screws for?
SkedAddled
Gallery: 16 photos
Feb 14, 2018 16:23 |  #1
The plate which shipped with my Sirui ballhead included a large QR plate
which I don't intend to use, while the others I bought are smaller.
The difference is the plate undersides: The original is free of hardware
other than the screw for camera/lens, with the others having two
hex-head screws each:
IMAGE: https://farm5.staticflickr.com/4751/39559423384_e4e2f45b5d_o.jpg
As these plates cannot mate to the head in any way with the screws installed,
I am quite curious as to just what these screws are for, because the heads
protrude below the bottom of the plate with no room in the head's socket
to accommodate them.
I therefore ask you knowledgeable folks here what the purpose of these may be -- ?
I'm at a loss in understanding it, other than to imagine mounting to accessory devices
such as gimbals or somesuch... ?
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Feb 14, 2018 16:28 |  #2
Usually they would be slide stops to keep the camera from sliding out of the clamp if the clamp came loose. Usually this is something you see on lens plates to keep them from sliding out, I don't know why they'd be on a camera plate as the ballheads usually have a pin to catch the camera plate, rather than putting the pin in the plate.
500px (external link)
1x (external link)
instagram (external link)
Wilt
Post edited over 5 years ago by Wilt. (2 edits in all)
Feb 14, 2018 16:29 |  #3
Based upon the direction that you prefer for your camera when you turn it on its side for Portrait more (CW vs CCW) you remove one of the screws.
The one that remains allows the camera to slide into the QR in the partially released state and STOP without continuing to slide downward and fall out before you locked it in place.
I don't use that feature myself.
SkedAddled
Gallery: 16 photos
Feb 14, 2018 16:39 |  #4
Wilt wrote in post #18563887 (external link)
Well, this makes some sense; I hadn't thought of it.
Doesn't seem to apply to me, either, as I mount the camera before adjusting the tripod.
Wilt
Feb 14, 2018 16:41 |  #5
SkedAddled wrote in post #18563895 (external link)
One viewpoint is that the screw stops the camera at the 'right place' -- even horizontally, you need not try to center the plate in the QR, you merely slide it in until it stops and then lock the QR
Since I prefer to open fully the QR to insert/release the plate, sliding in the plate from the side so it then stops is not necessary
SkedAddled
Gallery: 16 photos
Feb 14, 2018 16:49 |  #6
Wilt wrote in post #18563898 (external link)
Another reasonable rationale; thanks.
The stop-pin keeps my gear from heading towards destruction, as I slide the plate in
while holding firmly, so another reason I don't want the screws.
Interestingly enlightening explanations all the same, so thanks again, Wilt.
hoskoau
Joined Feb 2018
Post edited over 5 years ago by hoskoau.
Feb 14, 2018 17:44 |  #7
On a RRS leaver clamp if you open the leaver half way you can adjust the position of the plate, this is very useful for nodal slides to get them positioned perfectly. The screws physically stop the plate sliding off the clamp.
You might not think you need it, however the first time it saves your camera from falling from a height you will thank it for being there. If you really don't want it they are trivial to remove.
SkedAddled
Gallery: 16 photos
Feb 16, 2018 13:39 |  #8
hoskoau wrote in post #18563934 (external link)
Took me a moment on this one, but I think I understand.
Also does not apply to me; I slide the plate away from myself into the head to attach
and towards myself to release. And again, I make a firm mount prior to any
tripod head adjustments.
bigVinnie
Feb 16, 2018 13:50 |  #9
Actually, those are safety stops. They keep the camera from sliding out if the clamp comes loose.
Act1 Photo Booths (external link)
SkedAddled
Gallery: 16 photos
Feb 16, 2018 13:56 |  #10
bigVinnie wrote in post #18565292 (external link)
You're right.
The Sirui head has a built-in safety stop however, making these screws unnecessarily
redundant for my own useage. The built-in stop engages the underside of the plate.
bigVinnie
Feb 16, 2018 17:21 |  #11
Far as I know the Sirui clamps are the only ones that have that feature.
SkedAddled
Gallery: 16 photos
Feb 16, 2018 17:39 |  #12
bigVinnie wrote in post #18565467 (external link)
Seems to be a big plus in favor of Sirui.
I know nothing more about this, so somebody more knowledgeable may chime in
with further information.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Feb 16, 2018 17:45 |  #13
If you're referring to the safety stop built into a ballhead clamp then there are plenty of heads that have them. Sirui isn't the only one, or the first.
1x (external link)
Choderboy
I like a long knob
Gallery: 185 photos
Feb 17, 2018 20:56 |  #14
I have on occasion loosened the wrong knob, ie the clamp instead of ball head. I have never had an accident, always realised quickly, but those screws provide a backup to stupid mistakes like that.
Dave
Image editing OK
2,599 views & 7 likes for this thread, 6 members have posted to it and it is followed by 3 members.
1508 guests, 129 members online
