FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 18 Feb 2018 (Sunday) 05:17
Picking A Travel Tripod
Dlee13
Gallery: 380 photos
Joined Apr 2012
Feb 18, 2018 05:17 |  #1
After many weeks of research, I'm stuck between two models. The Sirui T-024X or the Manfrotto BeFree in Carbon Fiber.
Price wise I found the Manfrotto on special so it's actually $20 cheaper than the Sirui for the next few weeks. Either way, the price isn't much of an issue between these two.
I think the main thing I would like to know from anyone who has or still owns either one/both of these is, which is the most stable?
I will likely be using it with my 6DII and 16-35 f4L IS and/or 35mm f/2 IS.
From what I can say, both seem to be great quality but being that I already own the Manfrotto 055XPROB legs and know how good the quality of them are, I am slightly leaning towards them. I do hear nothing but good things about the Sirui which makes them even more tempting.
Sony Alpha A7III ~ Canon EOS M5 ~ Canon EF-M 22mm f/2 ~ Canon EF 35mm f2 IS
Canon EF 16-35mm f4L IS ~ Canon EF 100mm f2.8L IS USM ~
Sigma MC-11 ~ Sony FE 85mm f/1.8 ~ Sigma 35mm f/1.4 Art
Blog (external link) | Flickr (external link) | 500px (external link)
John ­ from ­ PA
Joined May 2003
Post edited 4 months ago by John from PA.
Feb 18, 2018 07:07 |  #2
If you haven't already done so, I would check all the reviews at B&H on the two you are considering. From my viewpoint, the Sirui has a better track record, no review rates below a "3". In the case of Manfrotto there are a few that are "1" and "2" and generally in those reviews the tripod has broken or collapsed or is noted as "not stable", "too flexible", etc. In contrast the Sirui seems to be noted for its stabilty, not just for cameras but on some sites discussing use of spotting scopes and high power binoculars. Links are below, just make sure you expand the review section to see all reviews and then sort as needed, like "Worst reviews" first.
https://www.bhphotovid​eo.com …ompact_travel_c​arbon.html (external link)
https://www.bhphotovid​eo.com …raveler_light_s​eries.html (external link)
Not that capacity ratings can be trusted, but the Manfrotto is much lower than the Sirui.
Flip locks vs. twist locks. Any preference?
From http://www.techradar.c​om …s-for-your-camera-1325010 (external link) it is said about the Manfrotto "Light and compact, but comes at the expense of stability".
bigVinnie
Feb 18, 2018 11:58 |  #3
You will like the head on the Sirui much better.
Act1 Photo Booths (external link)
Dlee13
Gallery: 380 photos
Joined Apr 2012
Feb 18, 2018 14:31 |  #4
John from PA wrote in post #18566583 (external link)
Thanks for the links, I'll have a read through them both :)
I don't really have a preference for leg locks but I have read some people saying that twist are more annoying than flip?
That article about the Manfrotto is interesting because the Sirui is even lighter than the Manfrotto so I have to wonder if that means it's less stable.
DaviSto
... sorry. I got carried away!
Gallery: 56 photos
Joined Nov 2016
Feb 18, 2018 14:48 |  #5
Dlee13 wrote in post #18566864 (external link)
I think you'll find people on both sides of the twist/flip debate. Twist locks are more compact and, arguably, quicker to lock/unlock. Flip locks are easier to maintain/adjust and, perhaps, less prone to failure from grit/corrosion. I think buying a tripod is something you need to do in a store. Until you have some hands-on time with them, you are not going to know what will work best for you. Differences in capacity ratings across brands should be ignored completely.
David.
Comment and (constructive) criticism always welcome.
John ­ from ­ PA
Joined May 2003
Feb 18, 2018 18:37 |  #6
The difference is 0.3# so I don't think that means as much to stability as leg stiffness. The fact of the matter is many reviews state the Sirui is very stable and some reviews state the Manfrotto isn't.
Dlee13
Gallery: 380 photos
Joined Apr 2012
Feb 18, 2018 20:30 |  #7
DaviSto wrote in post #18566875 (external link)
I don't really have a preference for twist or flip, just as long as they are well made. Yeah they both seem to be very similar in specs and both are carbon fiber so that's why I'm a bit stuck between the two.
John from PA wrote in post #18567008 (external link)
The difference is 0.3# so I dodn't think that means as much to stability as leg stiffness. The fact of the matter is many reviews state the Sirui is very stable and some reviews state the Manfrotto isn't.
I know I read that the T-024 is a little more stable than the T-025 which is what made me decide on that one from Sirui. Maybe quality control is the reason for some saying the Manfrotto isn't as stable? I will probably try go to see them in store but the Sirui is a bit more tempting since the Manfrotto is from a grey market seller.
Snydremark
my very own Lightrules moment
Gallery: 44 photos
Feb 19, 2018 00:56 |  #8
Dlee13 wrote in post #18567057 (external link)
I'd skip grey market, might be hard to get help with it if you need service/etc. Even official Manfrotto gear's tough to get service help with in the States.
I've got a MeFOTO Glboetrotter that's served me relatively well so far: http://www.mefoto.com …globetrotter-classic.aspx (external link). It's not too much different than the Siriu, I believe. At the size the tubes are to keep all of these guys small, none of 'em are *super* stable but work well enough if you're not using them in strong conditions. I've used the setup up to my 7DII and 100-400 without too much issue other than having to wait longer for vibration from touching the rig to die down.
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
Dlee13
Gallery: 380 photos
Joined Apr 2012
Feb 19, 2018 01:30 |  #9
Snydremark wrote in post #18567172 (external link)
If it's hard to get help in the U.S then probably even harder here. There's some grey market sellers here I trust and have bought quite a bit from including bodies and lenses. I have read about issues with the Manfrotto which is what worries me since I haven't bought anything from this particular seller. I looked at the Mefoto ones but the prices are a lot higher compared to the Sirui and Manfrotto for carbon fiber models.
bigVinnie
Post edited 4 months ago by bigVinnie.
Feb 19, 2018 09:59 |  #10
Tripods are a funny thing. There is never a perfect one and they all seem to be over priced unless you try and sell a used one. Used ones go for squat.
I've owned Bogen (Manfrotto) tripods since the 80's. Got a rack of them now. Those old aluminum ones are tough as nails. Got a box full of quick release plates as well. Even have a carbon fiber one, don't remember the model off hand. Don't use any of them any more.
I picked up a Zomei travel tripod a couple years ago to just leave in the car and not worry about it. It was cheap at $75. I quickly fell in love with it. Became a big fan of arca swiss mount and ball heads. I now use this cheap thing all the time. I just hang my backpack or sandbag on the center post and solid as a rock.
Recently I was at Fry's electronics. Big electronics shop here in the states. They had the Sirui tripods on display. If I had seen those before buying the Zomei I would have spent the extra money, they are better built but a few inches shorter. Also a bit lighter. I was pretty impressed.
If I ever buy another tripod (who am I kidding, I will) it will have a good ballhead and arca swiss mount. Everything else is a P.I.T.A.
Link for the Zomei I bought: http://a.co/8x3Yd43 (external link)
RPCrowe
Joined Nov 2005
Feb 21, 2018 22:15 |  #11
I have two tripods, a very sturdy (but, definitely not lightweight - despite carbon fiber build) Giottos 8180 which is my general purpose "do everything" tripod.
My travel tripod is a modified magnesium Slik Pro 330DX modified with the optional shorter center column and a Flashpoint F-1, A/C, tripod head.
Since the longest lens that I carry for general travel is the 70-200mm f/4L IS on either a crop or full frame camera, this very lightweight combination works fine.
The tripod is fairly short but collapses to only 23.5 inches which fits quite nicely in my travel suitcase.
I have shot on some very windy days in the Canyon Country of Utah and the rig (at just two pounds four ounces total) worked just great. It didn't cost an arm and a leg either...
Jocce
Gallery: 12 photos
Joined Jun 2012
Mar 20, 2018 05:23 |  #12
How about the Manfrotto Pixi (Evo)?
/Jocce
Feel free to correct my English. I'm from Sweden ;)
My Website (external link)
Fotointresse.se (external link)
Twitter (external link)
1,104 views & 3 likes for this thread
Latest registered member is elizaseren
742 guests, 264 members online
