Thread started 24 Feb 2018 (Saturday) 07:28
Newb; I'm a lost ball in the tall grass.
Tygr1
Gallery: 13 photos
Post edited 3 months ago by Tygr1.
Feb 24, 2018 07:28 |  #1
Hi kids,
When I take a shot in RAW or Jpeg, I first open them in Faststone for sorting. They are dull and have no contrast until I open them in lightroom where they suddenly pop and become usable. What am I doing wrong? Do I have a bad sensor? Am I using the wrong color space? I'm really lost on this one and really need your help. I will try and upload a couple of images to demonstrate what I'm seeing.
Before Lightroom, then after:
-Richard
Tygr1
Gallery: 13 photos
Feb 24, 2018 07:57 |  #2
I figured it out! My new to me used 80D had a user defined picture style set up in the menu that I had never noticed before. I changed it from cine-style to neutral and I really increased the contrast in my photos.
Well hell, I'm excited even if you're not!
-Richard
gonzogolf
dumb remark memorialized
Feb 24, 2018 11:23 |  #3
I think that once you become used to it shooting with the camera using a neutral picture style and then adjusting in post will be rewarding for you. In part the neutral picture style is better for judging exposure using the histogram. I've always found a good bit of joy in finding that the shots that I liked in camera had even more potential in post. With my first DSLRs using the portrait or landscape picture styles I was often less impressed with the image on the computer screen than I was the review screen. I'd much rather go from flat previews to exciting finished products as the excitement grows rather than deflates. Of course if you are shooting .Jpegs then its better to get the picture style right in the camera.
Tom ­ Reichner
"I am a little creepy"
Gallery: 138 photos
Feb 24, 2018 11:24 |  #4
Picture styles are only for jPeg images.
Just curious .... have you ever tried shooting RAW with your 80D?
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Feb 24, 2018 12:00 |  #5
If you find a picture style you like and you shoot JPG, then that is perfectly fine.
Raw is nice if you miss exposures, or are shooting problematic scenes regarding exposure or high dynamic range, or have a workflow that enables you to keep the raw digital file around, but also produce nice JPG results with little effort.
So you can eventually delve into the world of raw if you want the most from your photos long-term, or you can even start to define your own picture style from scratch with total control of what it does for a JPG result using Canon tools and uploading them to the camera. Lots of options!
Past Equipment | My Gallery (external link)
Tygr1
Gallery: 13 photos
Feb 24, 2018 12:58 |  #6
I do shoot in RAW. It was the deep and overlooked menu setting that had me stumped. Thanks for all of your kind words.
-Richard
BigAl007
Gallery: 526 photos
Mar 04, 2018 20:48 |  #7
As Tom said the picture style is only affecting the embedded JPEG preview image if you are shooting RAW. It makes zero difference to the RAW data, but as has also already been mentioned that embedded JPEG is used to generate the histogram that you see on the back of the camera. By using a high contrast, high saturation picture style you can make the camera show overexposure warnings, and push the histogram way over to the right. Pulling the exposure back so that you don't get those indications can lead to you underexposing the RAW image data by up to two stops.
To get around this I shoot using faithful, and then turn both saturation and sharpening down to -4, with the other two options centered at 0. Of the factory styles, and in camera processing options this is the one that brings you closest to having a JPEG that matches the RAW data. I think the cinestyle picture styles that are available take this even further, by using an almost linear contrast curve too, since it minimises the processing baked into a video file, where you don't have the option of recording truly RAW sensor data.
In addition to the picture style, the WB can also have an affect on the JPEG data that can skew the histogram and blinkies. If you want the absolute maximum in similarity to RAW data and histogram, then you need to use what they call UniWhiBal. This sets the camera up so that all of the WB channel multipliers are 1, hence unity white balance. If you use Magic Lantern then that will allow you to set UniWhiBal as an option in the menu. Otherwise you have to set it by using a custom WB setting, using an image that is completely over exposed. I normally shoot a second or two at max aperture and ISO 100 in daylight for this. When you select it for the custom WB it will say there is a problem with the file, but you just ignore this.
UniWhiBal is very good when combined with the picture style settings, but it does cause the preview image to look bright green. It's not a problem though as long as you set up your conversion software defaults to be either Auto, or one of the other presets. If you use Lr, once it is imported it will just show up as normal then.
If you want to pre cull before importing into Lr, but want to use settings that will optimise your histogram etc matching the RAW data, I would maybe suggest using Fast Raw Viewer (external link). It's really quick for culling, but importantly it uses the actual RAW data, not the preview. This means that you get all sorts of advantages, such as true RAW histograms, and default conversions that you can tweak. You can even make some corrections, and add stuff to the metadata, and FRV will then write it to an .xmp file that Lr will read during the import, and incorporate into the catalogue.
Alan
My Flickr (external link)
900 views & 4 likes for this thread
Latest registered member is Elemental13
880 guests, 317 members online
