Thread started 25 Feb 2018 (Sunday) 07:52
I need help...
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Feb 25, 2018 07:52 |  #1
Hi,
I just bought the godox x1t-c together with one xtr16 receiver for my godox dp 400 watts strobe series 1... Initially, they work well in triggering the strobes.
However, I can't adjust the strobe power using the x1t-c. I have to turn the power output dial of the strobe to set it. When I am trying to attempt, the xtr16 receiver is responding but the strobe stays on its setting.
Is there something I am missing here? I bought them all brand new including the strobes...
DP Series 1 have 5.0 to 7.0 stepless increments. Are the trigger and receiver compatible with the strobe? Hope you can me guys.
Thank you.
Left ­ Handed ­ Brisket
Gallery: 12 photos
Joined Jun 2011
Feb 25, 2018 08:07 |  #2
http://shop.godox.co.u​k/products/sflash/dp/d​p400.html (external link)
^^^ says power control is done with the FT-16
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Mar 01, 2018 08:50 |  #3
I see, I thought there could be some work around in this...
Thank you.:-)
Gallery: 12 photos
Joined Jun 2011
Post edited over 1 year ago by Left Handed Brisket.
Mar 01, 2018 09:08 |  #4
I am not 100 percent confident there is no way to use just the x series transmitter.
But if you have a need, you could control the power with the ft16 and fire the strobe with the x series.
TeamSpeed
01010100 01010011
Gallery: 103 photos
Joined May 2002
Mar 01, 2018 12:25 |  #5
After changing the power on the x1 unit, did you try pressing the test button to send it? That might be needed?
For Sale: Sigma USB Dock
For Sale: Ladies Thirty-One Camera Sling
inkista
Post edited over 1 year ago by inkista. (2 edits in all)
Mar 01, 2018 13:26 |  #6
Jiggo0109 wrote in post #18571811 (external link)
... DP Series 1 have 5.0 to 7.0 stepless increments. Are the trigger and receiver compatible with the strobe?...
Nope, not really. That's why they came out with the DP II series (external link); so they could build in the X receiver and get power control to work. If you can exchange the DP400 for a DP400II (external link), that would probably be your best bet. Then you wouldn't need the XTR16, either.
At this point, Godox has only Mk-II updated the QT, QS, DP, GS, and SK series strobes.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
agv8or
Gallery: 10 photos
Mar 01, 2018 13:28 |  #7
There has always existed an issue with the X1T-c and the XTR-16 receivers and it doesn't seem they've fixed the issues with firmware updates. The Nikon version of the X1T does not have the issues so the problem is not with the XTR-16 receivers or the flash units they are attached to but lies in the Canon version of the X1T transmitter. What I did to work around it was to use an XT-16 transmitter in the hot shoe of X1T-c to run all the flash units with XTR-16 receivers.
Rand
Gear
Angmo
looks like I picked a bad week to give up halucinagens
Gallery: 25 photos
Joined Dec 2015
Mar 01, 2018 14:37 |  #8
Wasn’t there a Godox chart showing what works with what..? It was posted somewhere here I think. Maybe it needs updating.
Nikons, Rolleiflexes, Elinchroms, Billinghams
TeamSpeed
01010100 01010011
Gallery: 103 photos
Joined May 2002
Mar 01, 2018 14:55 |  #9
Again, I think you have to make the changes to the group holding the strobe(s), then hit the test button to send them. It is a pain, but it does work, so that you can remotely modify them. The XPro, I believe, does this better.
1,533 views & 0 likes for this thread
I need help...
Latest registered member is sdbsr
1066 guests, 322 members online
