Thread started 26 Feb 2018 (Monday) 09:29
maybe this is a lens question
chuckmiller
Joined May 2012
Feb 26, 2018 09:29 |  #1
In harsh mid-day and overhead full sun does a CPL filter or a UV filter help tame the harsh light?
Retiring from Fire/Rescue after 37 years on 6/30/2020 and counting the days
Left ­ Handed ­ Brisket
That's my line!
Gallery: 10 photos
Joined Jun 2011
Feb 26, 2018 09:54 |  #2
UV does nothing, under any condition, ever. Some people use them to "protect" the lens.
You haven't said what you are taking pictures of, but generally if the sun is directly overhead a CPL will not have much effect ... depending on at what, and where you are pointing the camera.
It is intended to remove reflections and haze at angles less than 90 degrees to the camera.
Tom ­ Reichner
"I am a little creepy"
Gallery: 138 photos
Feb 26, 2018 10:57 |  #3
chuckmiller wrote in post #18572561 (external link)
I don't know if any optics can ever tame the light itself, but what they may be able to do, at times, is to tame the effects of the light.
One of the major effects of midday sun is heat distortion. . This is a real problem, even when it is extremely cold out (some people mistakenly think that heat distortion is only a problem during warm or hot weather).
There are no optics - neither filters or lenses - that can tame heat distortion. . If you are facing heat distortion, there are two things that can be done:
1: . Don't bother shooting, and instead wait for the sun to lower in the sky.
2: . Get close to your subjects so that there isn't much distorted atmosphere between your subject and your camera.
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Post edited 3 months ago by TeamSpeed. (3 edits in all)
Feb 26, 2018 11:13 |  #4
No these won't help, but having flash and/or reflectors to reduce the harsh contrast areas will, or moving to a more diffused lit area, or shaded areas.
The UV is a protective filter from dust/dirt, and nothing more really.
A polarizer will help eliminate light coming in from angles and if you have a circular polarizer, you can control from where it controls this. So sometimes reflections off water or glasses can be minimized with a CPL.
Past Equipment | My Gallery (external link)
chuckmiller
Joined May 2012
Post edited 3 months ago by chuckmiller.
Feb 26, 2018 11:24 |  #5
TeamSpeed wrote in post #18572646 (external link)
...The UV is a protective filter from dust/dirt, and nothing more really.
I like what it does to the color of the sky. ((HUMOR :-D))
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Feb 26, 2018 11:30 as a reply to  @ chuckmiller's post |  #6
Sure, but when you mention harsh lighting and contrast with overhead sun, one assumes you mean the impacts of those on subject material on land in front of you. At least that is what I took from this, because that is the common issue faced by shooters for weddings, portraits, etc, and the desire of clients wanting their events during these times of day, instead of in the morning or near dusk. :)
mcoren
Gallery: 26 photos
Joined Mar 2015
Feb 26, 2018 11:33 |  #7
Left Handed Brisket wrote in post #18572577 (external link)
Actually, UV filters were used back in the film days. Older color films had UV sensitivity in the blue layer, which resulted in a blue cast to photos taken under bright open sky, especially at higher altitudes. UV filters helped reduce this. People also used skylight filters, which were UV filters that had a slight, almost imperceptible warming tone (around 1.5 DM).
Whether or not you want a UV filter on a lens today is basically a religious issue. If you choose to use one, pick a high quality filter from a manufacturer like B+W or Hoya. Don't use the cheap $10 no-name filter that are sold on line. Those can definitely affect image quality.
Mike
Canon EOS 7D Mark II, 7D, and 100 (film SLR)
Canon EF-S 24mm f/2.8 STM, EF-S 55-250mm f/4.5-5.6 IS STM, EF-S 18-55mm f/3.5-5.6 IS STM
Sigma 100-400mm f/5-6.3 DG OS HSM | C, 17-70mm f/2.8-4 DC Macro OS HSM (non-C)
A backpack, a bicycle, and a pair of hiking boots
That's my line!
Gallery: 10 photos
Joined Jun 2011
Feb 26, 2018 11:33 |  #8
TeamSpeed wrote in post #18572663 (external link)
Bingo.
chuckmiller
Joined May 2012
Feb 26, 2018 11:47 |  #9
post #5 updated.
That's my line!
Gallery: 10 photos
Joined Jun 2011
Feb 26, 2018 11:56 |  #10
mcoren wrote in post #18572665 (external link)
Excellent point. I even used UV and skylight filters back in the old days ... I should not have made such a sweeping statement.
chuckmiller wrote in post #18572677 (external link)
post #5 updated.
I had kind of read it like that, but wasn't sure.
"It makes things pretty!" lol
chuckmiller
Joined May 2012
Feb 26, 2018 12:09 |  #11
Left Handed Brisket wrote in post #18572683 (external link)
Excellent point.."It makes things pretty!" lol
Even better!!
Wilt
Post edited 3 months ago by Wilt.
Feb 26, 2018 19:13 |  #12
Tame 'harsh light'...what does not mean to you?
  • reduce contrastiness of lighting
  • reduce blown out highlights (vs. shadow areas)
  • reduce squinting subjects
No, No, and No.
CPL and UV filter do none of those things.
So, if you better define what characterizes what causes 'harsh lights', you can better start to filter down the list of 'solutions' for yourself
1,045 views & 2 likes for this thread
Latest registered member is jeroe
802 guests, 348 members online
