Thread started 02 Mar 2018 (Friday) 09:45
Proper glue for attaching rubber band of Sekonic L-358
eaglexdr
Joined Oct 2016
Mar 02, 2018 09:45 |  #1
Could this title be any more confusing?
Hey guys,
I recently bought a perfect 2nd hand L-358 with only one problem: The rubber part on the left part lost it's adhesive strength and fell. I tried gluing it using a random quick glue I had laying around my house, but it failed to attach.
I was wondering if anybody knows which kind of glue will be the proper match for it? The rubber part is.. I believe, well, rubbery, and the unit itself seems to be made of Plastic. I emailed Sekonic, but they did not respond.
Photos are attached for easier understanding.
Thank you guys!
Noam.
My Gallery (500PX) (external link)
My Facebook Page (external link)
gjl711
According to the lazy TF, My flatulence rates
Mar 02, 2018 09:50 |  #2
Contact cement (external link) works well.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Left ­ Handed ­ Brisket
That's my line!
Gallery: 10 photos
Joined Jun 2011
Mar 02, 2018 10:19 |  #3
E6000 is amazing.
I actually completely nerded out one day and really looked into what was a great, strong as hell glue. E6000 was the answer. I have glued plastic to metal, metal to metal, and fabric to metal. As long as you let it cure for a day it will bond just about anything.
If I had to marry a glue, it would be E6000.
mmmfotografie
hanging up-side-down in a cave
Joined Jul 2013
Mar 02, 2018 10:44 |  #4
Left Handed Brisket wrote in post #18575891 (external link)
E6000 is amazing.
To be never divorced...even not in death. So not a good idea.
Wilt
Post edited 3 months ago by Wilt. (3 edits in all)
Mar 02, 2018 10:52 |  #5
I would examine the seam that joins the halves of the meter shell... If separation of the two, for repair purposes, might ever be needed, my choise of adhesives for the rubber would not be to choose something that i do not feel could be readily 'unstuck' to permit the repair to occur. Contact cement is far too tacky, I would reserve that for never-ever-separate-it (without high heat)
Barge brand cement is something that is fairly strong in adhering things, yet it stays flexible and separable...I have stuck suede onto the soles of rubber-soled shoes used for dancing, they have stuck for years, but then I can peel the worn suede layer off readily, so I can glue on a new layer of suede.
John ­ from ­ PA
Joined May 2003
Mar 02, 2018 12:54 |  #6
You need something with some flexibility perhaps more than strength. Personally I'd suggest using a clear silicon based material. Often caulking is labeled as "adhesive sealant".
Grumpy_one
Mar 03, 2018 10:40 |  #7
Having to repair commercial aircraft interiors on the fly (pun intended) we use 2 part epoxy with a 5 minute cure time, or sometimes carpet tape, it's two sided and will stick to anything. Good luck. Make sure both sides are clean before applying glue or tape. Isopropyl alcohol can work in a pinch
I shoot Canon's
1DX II, Canon 7D Gripped, 5D3, 24-70L II, 70-200L 2.8 IS Mk I, 85 1.8, Pocket Wizard II triggers, assorted speedlites and modifiers, 580EX, 580EXII, YN560's (6 or so) 50 1.4, t/c 1.4 MkII
www.happyvalleyphotogr​aphy.com (external link)
That's my line!
Gallery: 10 photos
Joined Jun 2011
Mar 03, 2018 10:50 |  #8
mmmfotografie wrote in post #18575900 (external link)
Ouch.
Although probably better than if I were "stuck" with my ex wife.
eaglexdr
Joined Oct 2016
Mar 04, 2018 06:56 |  #9
Wow, thank you!
I definitely didn't expect so many detailed replies.
I really really appreciate it :) I will now choose a proper adhesive based on your advice. Wish me luck.
Noam.
1,015 views & 1 like for this thread
Latest registered member is brotherbear86
837 guests, 366 members online
