Thread started 02 Mar 2018 (Friday) 09:58
Electronic level not working in the vertical on the Canon 5Dmkiv
Pegasus1
Gallery: 13 photos
Joined Sep 2011
Mar 02, 2018 09:58 |  #1
Hi Guys, I have discovered that the electronic level in the viewfinder and liveview has a fault on the vertical axis on my canon 5Dmkiv, as in stuck on pointing down..the horizontal works as normal, have tried everything to rectify this to no avail..Thanks in advance
5Dmkiv - 60D - 300f4L - Sigma 24-105 f4 Art - Tamron 60 f2
apersson850
Mar 04, 2018 06:19 |  #2
Did it work to begin with? Some earlier models required a firmware update for proper operation, but one could assume they would be beyond that by now.
Anders
cristphoto
Mar 04, 2018 08:51 |  #3
Mine works in either orientation but I have the latest firmware (1.0.4). I don't recall using the viewfinder level with original firmware however. As previously stated confirm you have latest firmware and see if that fixes it. Otherwise call Canon.
5D MKIV, 5D MKIII, 1D MKIV, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 300LIS, 16-35LIS, 24-70L, 70-200LIS, 100-400LIS
Pegasus1
Gallery: 13 photos
Joined Sep 2011
Mar 05, 2018 10:59 |  #4
Thanks for the replys, Yes on latest firmware, yes worked in both orientations before, going to bring it into where I bought it see if they will swap it out as its just a couple of months old...not bothered with it but other stuff may fail..
Pegasus1
Gallery: 13 photos
Joined Sep 2011
Apr 13, 2018 03:31 |  #5
As a follow up, had the evf hidden, till now, I hid it just now and it has fixed itself▀ś
Weird..
1,544 views & 0 likes for this thread
Latest registered member is Malonesmama
736 guests, 368 members online
