Thread started 03 Mar 2018 (Saturday) 10:33
[IMAGE ENLARGNET] How to get high detail image for large print
Albys
Joined Mar 2018
Mar 03, 2018 10:33 |  #1
Hi everyone, i was wonder if there is any way to take a photo/image like the one below (or a 20/24mpx@300dpi image) and ready it to be printed on a huge format, say 10x6 meters, without losing too many details (it would be looked at from 1/1.8 meters away).
PhotosGuy
Moderator
Joined Feb 2004
Mar 03, 2018 11:00 |  #2
Welcome to POTN!
Printed 10x6 meters...
Why?
Albys
Joined Mar 2018
Mar 03, 2018 16:14 |  #3
PhotosGuy wrote in post #18576607 (external link)
Welcome to POTN!
Thank you!
Printed 10x6 meters... Why?
Well... because!
I need it..
PhotosGuy
Moderator
Joined Feb 2004
Mar 03, 2018 16:37 |  #4
Good luck with that!
BigAl007
Gallery: 526 photos
Mar 03, 2018 16:42 |  #5
There is no way that you will be able to get an image that is 10m wide, and viewable from less than two meters. At 10m on the long edge the 6000 pixels you get from a 24 MP image will give you 15.3 PPI. If it's being viewed from 1m you will still want to be printing at 300 PPI. This would require you to digitally enlarge the image by 19.65×. So for every existing image pixel in the original file you will need to create 19.65 new pixels from "nothing" to make a file that was large enough to print at 300 PPI and 10m long.
Notwithstanding this I don't know of any printing process that will allow you to print an image at that size, at a resolution of 300 PPI. You are talking about something the size of a billboard, and they are always designed to be viewed from a much further distance. An image of 10×6m would normally be expected to be viewed from a minimum distance of 12m or so, so you are trying to get ten times closer than would be expected.
Alan
My Flickr (external link)
agedbriar
Post edited 3 months ago by agedbriar.
Mar 03, 2018 17:27 |  #6
For the specs you posted is hard to give a sensible advice, as it is a far from normal viewing situation.
If I were in your position, I'd take a 1/20th crop (linear) of a critical part of the image and do a few A3 prints from it, each after a different resize amount, to see which looks best from that viewing distance. It's about the balance between pixellation vs the introduction of a multitude of invented pixels.
Of course, a lot will depend on resize quality (algorithm used).
Tom ­ Reichner
"I am a little creepy"
Gallery: 138 photos
Post edited 3 months ago by Tom Reichner.
Mar 03, 2018 17:54 |  #7
I have been in two National Wildlife Refuge visitor centers where they have a photo printed at huge sizes similar to that which the OP is asking about. . In each situation, the image is routinely viewed from a distance of 5 to 20 feet, depending on where one stands in the room in which the photo is displayed.
Both images of which I speak are printed at floor-to-ceiling height, which is about 10 feet in each case. . The one image is 30 feet across (I know this because I paced it off quite intentionally) and the other is approximately 24 feet across.
The one that is 30 feet across looks pretty good, even from just 4 or 5 feet away.
The one that is approximately 24 feet across looks terrible because the digital file just didn't have enough resolution to capture fine detail throughout the image.
Neither of these images could have been done by stitching multiple images together, because of great movement in the subject matter - one is a flock of Greater White-fronted Geese in flight and the other is a meadow of wild grasses being blown by a stiff wind.
For those who think that there is no real-life situation where one would print a photo at this size, or that photos of this size are never viewed from very close distances, well, you are simply wrong. . There are times when people want to use a single photo in a mural-like fashion, and have it cover an entire wall from one end to the other, and run from floor to ceiling - and they sometimes want to do this in rooms that are relatively small.
There is no need whatsoever to print an image at 300 units per inch (whether they be dots or pixels). . Anywhere around 100 units per inch will be just fine for all but those with microscopic vision. . My personal acuity limits out at about 140 units per inch.
CisherPhotography
Gallery: 20 photos
Joined May 2013
Mar 03, 2018 19:23 as a reply to  @ Tom Reichner's post |  #8
Hey Tom,
Did you snap selfie to share?
You have me intrigued.
Left ­ Handed ­ Brisket
That's my line!
Gallery: 10 photos
Joined Jun 2011
Post edited 3 months ago by Left Handed Brisket.
Mar 03, 2018 19:43 |  #9
Dye sub printers generally can't make use of more than 175 ppi
Most places will tell you that 125-150 ppi is plenty.
That still isn't going to get you anywhere close. And yeah viewing distance is a huge factor.
Enlarge the file to the size you want to print it, print a standard size print of one small area of the image, then pin it to a wall at head height. This will give you a very good idea of what you are dealing with.
Tom ­ Reichner
Gallery: 138 photos
Mar 03, 2018 20:37 |  #10
CisherPhotography wrote in post #18576939 (external link)
Hey Tom,
No, I didn't think of that.
But it's not really anything that unusual .... some museums I've been to also have mural-sized photos covering a wall.
Problem with taking selfies with my cell phone is that I have no idea how to share them over the internet, because I don't know how to get pictures from my cell phone onto my computer. . So all I can do is text them to people. . Besides, I'm not really a selfie guy - I'd much rather take a photo that doesn't have me in it. . Honestly, I've never understood the whole selfie thing.
Wilt
Post edited 3 months ago by Wilt.
Mar 03, 2018 20:44 |  #11
A photographic image will never carry more detail than was originally captured within the camera sensor. If you take a full camera frame that had 2000 line pairs of detail across the smallest dimension and you enlarge it to A4 size, the 2000 lines of detail would fill the A4 size (21 cm) you would view the A4 print from about 30 cm. If you then enlarge the print 100 times larger and view it from 100 times the distance, there is still only 2,000 lines of detail in that huge print. You would never see any more detail if you walked closer to the print.
The image quality of the A4 print viewed from 30 cm is identical in quality compared to the print which is 100 times larger and viewed from 3000 cm, 100 times the first distance.
Tom ­ Reichner
Gallery: 138 photos
Post edited 3 months ago by Tom Reichner. (2 edits in all)
Mar 03, 2018 21:00 |  #12
Wilt wrote in post #18576984 (external link)
You are correct.
However, in real life the viewing distance DOES NOT increase as the size of the print increases. . That whole theory is a falsehood, and is actually quite ridiculous.
A medical clinic purchased upwards of 40 metal prints from me. . The smallest of them were 36" by 24", and the largest were 48" by 32".
Guess what? . They put most of them in tiny little patient rooms, most of which measure 7 feet by 10 feet. . So, despite the large size of the prints, because of the way a counter runs along the opposite wall, the very furthest one can view my photos from is 5 feet. . And when standing where you would normally stand in these rooms, the prints are about 3 feet from your eyeballs.
The above situation is not an anomaly; it is actually a very normal way to size and display prints.
Viewing distance IS NOT determined by print size - rather, it is determined by the layout of the space in which the prints are displayed. . Many people like nice big prints that pretty much fill up the wall that they are displayed on, despite the fact that the room itself may be quite small.
Wilt
Post edited 3 months ago by Wilt. (5 edits in all)
Mar 03, 2018 21:40 as a reply to  @ Tom Reichner's post |  #13
I do not disagree in the least, Tom.
  • My point about viewing distance proportional the print size holds QUALITY.
  • And your point, that viewing distance is not proportional to print size
...both are equally true.
When the viewing distance is not proportional in growth to the print size, then we have the issue raised in the OP
  • ...there is NO GROWTH of DETAIL.
  • There can be an increase of pixel count so as to make the jagged stair-stepped aliasing of any lines not perfectly aligned to horizontal or vertical axes less apparent even when up close,
but WITH NO INCREASE in 'detail'.
tzalman
Fatal attraction.
Post edited 3 months ago by tzalman. (2 edits in all)
Mar 04, 2018 02:09 |  #14
Albys wrote in post #18576584 (external link)
With a budget for printing and putting up a photo-mural this size (6+ m. ceiling means hotel or institutional building lobby? And a sore neck when viewed from 1.8 m.) couldn't you rent a Phase One IQ 180 (80 Mpx, 10,328 x 7,760) and lens or at least a 5Ds?
Tom Reichner wrote in post #18576995 (external link)
But the OP is talking about a print that is 394 in. x 236 in., viewed from 3 to 5 feet. And if the reference to 24 Mpx is to a Canon camera this suggests an APS-C sensor so a 444 times enlargement from the optical image.
Gotta' comment tho, I would have expected that for a project this size an experienced, knowledgeable and well equipped pro would have gotten the job.
Elie / אלי
kirkt
Post edited 3 months ago by kirkt. (4 edits in all)
Mar 05, 2018 10:36 |  #15
A couple of things to consider above and beyond the relationship between image size and viewing distance.
1) The image itself looks like a specimen of agate or similar geological specimen - but it can be viewed as an abstract pattern. In this case, detail is not so relevant, as it is the impression, pattern and color that creates the experience of viewing it, not recognizing someone's face in an image shot from 50,000 feet above the surface of the earth. You can try resizing to the desired output size and resolution using Photoshop or some specialty software and see how it looks.
2) If you actually shot this image for the purpose of creating a large, highly detailed print at the size you have called out here, then you might consider shooting the specimen again, with a microscope, and stitching a set of images together to form a large, highly-detailed composite. You would need to carefully index the stage of the microscope so that you could manipulate it to shoot rows and columns of images and then stitch the matrix of images together to form the full-sized final composite. You would need to figure out what optical zoom level (10x, 20x, etc.) you would require to get the final output size you need for the sensor size you are using to record the images you shoot through the microscope optics.
The file size of such an image would be staggering, so you need to consider your computer hardware and software's ability to handle the job. 10m is roughly 30 feet: 30 ft * 12 in/ft * 300 pixels/in = 108,000 pixels on the long edge... for the 10mx6m image at 300 pixels per inch, you are talking about a 7 GigaPixel image. This seems like serious overkill.
I created a 360 degree spherical panoramic image of a workshop years ago shooting with a 5DII and a 15mm fisheye lens. I stitched the images together and created a final image that was somewhere in the neighborhood of 13000-15000 pixels on the long edge (I cannot remember the exact amount). It was printed on a dye-sub printer (on fabric) for a trade show backdrop, 20 feet wide and 8 feet high. The printer told me the final resolution (in PPI) at print size that he required for the file- I used photoshop to enlarge the image not a trivial amount. The image printed perfectly fine, even at a viewing distance of a couple feet. But, I had a lot of pixels to work with from the beginning because I made a composite from multiple images.
good luck,
kirk
Kirk
1,489 views & 7 likes for this thread
Latest registered member is Elemental13
784 guests, 344 members online
