Thread started 08 Mar 2018 (Thursday) 07:05
Longer lens hood for 24-70
Vitoflo
Joined Aug 2013
Mar 08, 2018 07:05 |  #1
Hi,
I am considering purchasing 24-70 f/4 and I found out that it has the short lens hood while the f2.8 has the longer one:
https://upload.wikimed​ia.org …s/7/77/CanonEF2​4-70mm.jpg (external link)
What would be the benefit of having the longer lens hood?
I understand a longer hood will be visible in the 24-50mm range, correct?
oldvultureface
Gallery: 67 photos
Mar 08, 2018 08:45 |  #2
Depends on which camera you have, i.e., field of view. Short hood for full-frame, long hood for APS-C.
Vitoflo
Joined Aug 2013
Mar 08, 2018 09:16 |  #3
Ok, I found out that the longer hood is for the first version of the 24-70 2.8 which zooms at 24mm while newers do at 70mm.
Now, I must admit that I was struck by the quality of the sample images produced by the 24-70 first version.
I hope the f/4 version is on the same league.
Nick5
Mar 08, 2018 09:17 |  #4
Which 24-70 f/2.8 L are you comparing lens hoods to? Version 1 or 2.
Without having either f/2.8, I do like the smaller size hood for my f/4 L IS. I am sure there is a reason why the f/4 L IS Hood is smaller than the f/2.8's without getting "too Techie".
No reason to go larger.
The f/4 L IS is a darn nice lens.
Canon 5D Mark III (x2), BG-E11 Grips, 7D (x2) BG-E7 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 24-105 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 100-400 f/4.5-5.6 L IS, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 50 f/1.4, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon Pixma PRO-10 Printer
apersson850
Mar 08, 2018 10:08 |  #5
I don't have any 24-70 mm f/2.8 lens. But I do have the EF 24-105 mm f/4L IS II USM, and had the EF 24-105 mm f/4L IS USM before that. For these two, the lens hood designed for the EF-S 17-55 mm f/2.8L IS USM fits fine. No vignetting on full format, but quite a bit better protection of the front lens than with the hood that accompanies the two 24-105 lenses.
The design of the EF 24-70 f/2.8L USM is quite unusual. Almost all other lenses get longer when set to longer focal lengths. So does the EF 24-70 mm f/2.8L II USM. But the fact that the first version works in the opposite way, combined with that the hood is sitting on a part of the lens which does not move during zoom operation, means a much larger hood can be used. Note that the total length of that lens, with the hood included, doesn't change during zooming.
Anders
SkipD
Joined Dec 2002
Post edited 3 months ago by SkipD.
Mar 08, 2018 10:09 |  #6
Vitoflo wrote in post #18580315 (external link)
......... the first version of the 24-70 2.8 which zooms at 24mm while newers do at 70mm.
Would you please explain the comment in bold? It does not seem to make sense as written. Both lenses can be zoomed through their entire focal length range. Maybe your definition of "zoom" is something unique?
Skip Douglas
Tom ­ Reichner
"I am a little creepy"
Gallery: 138 photos
Mar 08, 2018 10:24 |  #7
SkipD wrote in post #18580341 (external link)
I couldn't understand that sentence either. . I've read it again and again and again and it still doesn't make any sense to me.
It would help if some explanation, or re-wording of the sentence, or some clarification were provided so that we could understand exactly what was meant.
apersson850
Mar 08, 2018 10:30 |  #8
He means that the old lens is physically longest at the 24 mm setting, but the mark II version is the opposite. Longest at the 70 mm setting, just like almost every other lens.
Anders
Vitoflo
Joined Aug 2013
Post edited 3 months ago by Vitoflo.
Mar 08, 2018 12:18 |  #9
apersson850 wrote in post #18580359 (external link)
Yes this is it.
I'd like to talk about the image quality of the f/4 IS. Usual comments on the 2.8 version (especially the MK I) are about its unique character and color for portrait while the f/4 IS is said to be sharper.
I must say I would use the f/4 for portrait mainly but cannot afford the 2.8 version.
2,489 views & 2 likes for this thread
Latest registered member is gunz46
782 guests, 265 members online
