Thread started 09 Mar 2018 (Friday) 13:09
Laptop Monitor Display Issues
SYS
Gallery: 31 photos
Joined Jul 2004
Post edited 3 months ago by SYS.
Mar 09, 2018 13:09 |  #1
A few months ago I opted to go with Dell XPS 13 as my new laptop for portability. While I knew that I'd have to compromise somewhat on photo editing with LR and PS with this laptop, it's been actually working out quite satisfactorily thus far. However, one issue that's been driving me crazy is that whenever I open the PS (I have CS4 Extended version), all icons, functions, fonts, numbers, etc., they're so tiny that I have a hard time even trying to use my mouse to get to each function. When I'm trying to resize the image resolution, for example, it's a challenge to read the numbers in the box. I did try changing the font size in Dell, but that messes up by universal application of the change. The UI in PS has always been set to "Large." Is there any other way to resize just the PS window display? Or is this an non-fixable problem?
-Goethe
My Gear & DIYs
davesrose
Title Fairy still hasn't visited me!
Mar 09, 2018 19:18 |  #2
Adobe CC natively supports hiDPI scaling (the app will scale its font size to your desktop font size). With Windows 10, the first thing I would try is going to your photoshop.exe program and right clicking and then select properties. In the properties, select compatibility and then enable "Override high DPI scaling behavior. Scaling performed by:" and then select "System(Enhanced)". Windows will try to scale your old version of PS. I find this new compatibility setting to look the best for scaling old apps.
With previous versions of Windows, you had to do a hack which would magnify the fonts and icons (so they don't look as crisp as the new Windows 10 scaling features). If the Windows 10 compatibility setting doesn't work....here's the old method for hacking a font magnification:
Adobe App Scaling on High DPI Displays (FIX) (external link)
Canon 5D mk III , 7D mk II
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
SYS
Gallery: 31 photos
Joined Jul 2004
Mar 09, 2018 19:43 |  #3
davesrose wrote in post #18581317 (external link)
Thank you very much. Your instruction worked! Before reading your post, I actually tried the old hacking method that you linked to without success. :-)
-Goethe
My Gear & DIYs
537 views & 1 like for this thread
Latest registered member is daisan
923 guests, 432 members online
