Thread started 12 Mar 2018 (Monday) 08:31
Not sure what to call what I am asking.
Bassat
"I am still in my underwear."
Joined Oct 2015
Mar 12, 2018 08:31 |  #1
I am trying to find out if Canon flashes (550EX, 580EX II) can be set up to fire in response to another flash going off. Example: Shooting a Yashica FX-D w/Yashica CS-220 flash in Auto mode. Can I set up my Canon's for fill/BG and have them auto-fire when the the camera-mounted 220 fires? I'm thinking not.
Do other units do this?
Tom
gonzogolf
dumb remark memorialized
Mar 12, 2018 09:24 |  #2
You want them to act as slave units. They don't do this by themselves but you can buy a slave attachedment for them to slave in manual mode. http://flashzebra.com/​products/0118/index.sh​tml (external link)
Left ­ Handed ­ Brisket
That's my line!
Gallery: 10 photos
Joined Jun 2011
Mar 12, 2018 09:45 |  #3
Also keep in mind that a built in canon flash is always in ttl mode and fires a preflash. If you don't use flash exposure lock, your optical slave flashes probably won't behave as expected.
Obviously this goes for OCF TTL triggers too.
OceanRipple*
Joined Dec 2014
Post edited 3 months ago by OceanRipple*. (5 edits in all)
Mar 12, 2018 10:49 |  #4
The CS 220 itself did not require a pre-flash - so that's easy.
All Canon Ex Speedlites require a subset of add-on slave units to drive them (Edit: Not a 'Slave' in 'CanonSpeak'). So as Gonzo implied, they must be 'Canon EX Compatible'. These tend to be about 1 stop less sensitive than generic slave units so be prepared to optimise the light path, whether direct or bounced, from the driving unit to the slave. A corded slave can sometimes help with this - might as well have a threaded pc lock.
Built-in flash units on the 7D and higher/later can have their flash Mode set to M - and - 'Wireless' disabled - which loses any pre-flashes.
gonzogolf
Mar 12, 2018 12:03 |  #5
Also consider the investment. I don't know what sourcing these slave units would cost in the UK, but you are nearly halfway to the cost of some cheap flashes built in slaves like the yn560.
Bassat
Joined Oct 2015
Mar 12, 2018 16:38 |  #6
Left Handed Brisket wrote in post #18583532 (external link)
Simply not true. All EX units have a manual mode, my 80D built-in has a manual mode, the CS-220 doesn't do TTL, so no pre-flash there, either.
I am talking about controlling CANON EX flash, from an old-style AUTO-Flash, no pre-flash anywhere here.
Tom
Bassat
Joined Oct 2015
Mar 12, 2018 16:39 |  #7
gonzogolf wrote in post #18583514 (external link)
Interesting. Thanks.
Tom
Bassat
Joined Oct 2015
Mar 12, 2018 16:43 |  #8
I think there may be some confusion here, though it may be on my part. I interpret slave as a unit controlled by another unit. Such as on-camera and remote EX units. That is not what I'm looking for. What I want is a something to FORCE an EX unit to fire when my FX-D fires the on-camera CS-220 which has no pre-flash, and no way to control the remotes units: a pure "I flashed because you flashed REACTION."
I think gonzo in post #2 has what I need. Will research more, in a bit.
Tom
gonzogolf
Mar 12, 2018 19:15 |  #9
Bassat wrote in post #18583895 (external link)
Not all built in flashes on canon cameras allow you a mode without a preflash.thats only available on the newest models.
ra40
Gallery: 159 photos
Joined Jan 2013
Post edited 3 months ago by ra40.
Mar 12, 2018 19:19 |  #10
AFAIK the Canon units do not have a dumb optical trigger option. I have been using the 600EX RTII in optical mode to trigger the 580EX set to "slave" mode. The 600 will adjust the output of the 580EX in the ratio section so I use the 580 as a group B flash. C is also available.
With a non-Canon unit you can use a variety of aftermarket radio triggers and set each flash manually for the output desired.
Chet
my rates fluctuate
Gallery: 125 photos
Mar 12, 2018 19:20 |  #11
I use these optical triggers. They do the job.
https://www.amazon.com …ket-JSYK-3A/dp/B00S3Z8ODY (external link)
Curator of the Bob's Pickle Emporium experience. -As always, One location to serve you better!
~Feel good today and donate to this great forum~ LINK
My Gear List
Bassat
Joined Oct 2015
Mar 13, 2018 00:29 |  #12
gonzogolf wrote in post #18584031 (external link)
True, but irrelevant. I am controlling flash with a 30 year old manual film camera,. Not a Canon dslr.
Tom
Bassat
Joined Oct 2015
Mar 13, 2018 00:31 |  #13
Chet wrote in post #18584036 (external link)
Thanks, Chet. Cheaper than the other ones
Tom
gonzogolf
Mar 13, 2018 01:38 |  #14
Bassat wrote in post #18584223 (external link)
Not entirely irrelevant give your rather curt answer above to left handed brisket.
ra40
Gallery: 159 photos
Joined Jan 2013
Mar 13, 2018 14:05 |  #15
Went to read up a bit on the 550, the 580EXII will control the 550EX in optical mode. This is the same as I am doing with the 600 and 580 allowing three groups, A,B,C. If you want to future ready this system a radio trigger system. That way there won't be line of sight issues from camera to remote flash. The dumb mode optical triggers will be the least expensive.
4,954 views & 0 likes for this thread
Latest registered member is lynx36
896 guests, 404 members online
