I bought a used Canon 35mm f1.4L lens. It didn't come with a box and I don't know if it's version I or II. Is there a way to check on the lens to see what it is?
Mar 13, 2018 13:48 | #1 I bought a used Canon 35mm f1.4L lens. It didn't come with a box and I don't know if it's version I or II. Is there a way to check on the lens to see what it is? Anita W.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 13, 2018 14:10 | #2 Version 1 has knurled focus ring back a bit from the lens front, with the distance scale at the very front. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
TeamSpeed 01010100 01010011 More info Post edited over 5 years ago by TeamSpeed. | Mar 13, 2018 14:17 | #3 Picture of both courtesy of Ken Rockwell Past Equipment | My Personal Gallery
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Mar 13, 2018 15:40 | #4 anitaw2 wrote in post #18584664 I bought a used Canon 35mm f1.4L lens. It didn't come with a box and I don't know if it's version I or II. Is there a way to check on the lens to see what it is?
Alan Myers
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Mar 13, 2018 15:50 | #5 Permanent banWilt wrote in post #18584678 Version 1 has knurled focus ring back a bit from the lens front, with the distance scale at the very front. Version 2 has knurled focus ring near the front edge, and the distance scale is closer to the body. Version 1 is not IS, Version 2 has IS. Version 1 takes 52mm filters, Version 2 takes 67mm filters Version 1 Canon specifies 2.7" (67.4mm) diameter by 1.7 " (42.5mm) long., Version 2 Canon specifies 3.1" (77.9mm) diameter by 2.5" (62.6mm) long. Wilt, you may want to read the question again. Neither lens has IS. I'm pretty sure both take 72mm filters.
msowsun "approx 8mm" More info Post edited over 5 years ago by msowsun. (4 edits in all) | Mar 13, 2018 16:02 | #6 Wilt wrote in post #18584678 Version 1 has knurled focus ring back a bit from the lens front, with the distance scale at the very front. Version 2 has knurled focus ring near the front edge, and the distance scale is closer to the body. Version 1 is not IS, Version 2 has IS. Version 1 takes 52mm filters, Version 2 takes 67mm filters Version 1 Canon specifies 2.7" (67.4mm) diameter by 1.7 " (42.5mm) long., Version 2 Canon specifies 3.1" (77.9mm) diameter by 2.5" (62.6mm) long. You are describing the EF 35mm f/2 and EF 35mm f/2 IS, not the EF 35mm f/1.4 and EF 35mm f/1.4 II as asked by the OP. Image hosted by forum (904559) © msowsun [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
TeamSpeed 01010100 01010011 More info | Mar 13, 2018 21:29 | #7 Probably the easiest is simply to look at it and compare it to the picture provided. They are very distinctly different from each other, and just a casual glance at one or the another makes it very obvious which is which. Past Equipment | My Personal Gallery
Mar 14, 2018 13:04 | #8 Thanks everyone. I have version I. Anita W.
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Mar 14, 2018 14:05 | #9 Just an FYI, the 35mm f/1.4 USM was announced in 12/1998 and the 35mm f/1.4 USM II was announced 8/2015.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info Post edited over 5 years ago by cristphoto. | Mar 15, 2018 07:32 | #10 Next to the red ring after 35mm L 1.4 it will have a II (for version two). Also the version one doesn't have the weatherproof gasket at the lens mount (version two does). 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
Mar 15, 2018 07:44 | #11 cristphoto wrote in post #18586058 Next to the red ring after 35mm L 1.4 it will have a II (for version two). Also the version one doesn't have the weatherproof gasket at the lens mount (version two does). so version I is not weather sealed? Anita W.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Mar 15, 2018 08:08 | #12 It’s well made and pretty much sealed around the focus ring and af switch, but unfortunately not sealed at the lens mount. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Mar 15, 2018 13:12 | #13 cristphoto wrote in post #18586076 I...unfortunately not sealed at the lens mount. Not really a very big deal.... Alan Myers
| Latest registered member is semonsters 1676 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
