Thread started 19 Mar 2018 (Monday) 09:17
I Hate the Godox AD600Pro
RDKirk
Adorama says I'm "packed."
Joined May 2004
Mar 19, 2018 09:17 |  #1
Just saying this for the record.
I hate it. Dang Godox.
I mean, I like the light for what it is, although the only thing I really needed from it is the higher power modeling light.
But the tube, battery, and AC adapter aren't compatible with the AD600.
Dang that. Dang it really hard.
I hate incompatibility.
MayaTlab
Joined Sep 2016
Mar 19, 2018 09:25 |  #2
It's mostly for the better though, isn't it ?
That said now that they've adopted a pretty good flash tube / mount position / modeling light design / default umbrella reflector design, I hope that they'll stick to it for their other lights as it's impossible to make modifiers that work on a consistent basis across various lights if you keep changing the design.
RDKirk
Joined May 2004
Mar 19, 2018 10:48 |  #3
MayaTlab wrote in post #18589169 (external link)
Unfortunately, the AD600Pro is evidence of one of my Godox fears--that they'll just churn out new models without regard to maintaining any level of intentional compatibility with the last model.
MayaTlab
Joined Sep 2016
Mar 19, 2018 10:58 as a reply to  @ RDKirk's post |  #4
Personally I rather see it as them fixing the AD600's much perfectible flash tube / reflector / LED / mount design for now. If they again change their mind later on, then I'll start to be worried.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 19, 2018 11:06 |  #5
RDKirk wrote in post #18589229 (external link)
That has been my realization too. Fast product turnaround, but at the expense of leaving last year's purchases on the roadside... This is why I picked up spare bulbs and other things for the Godox lights I have now, I plan on just using them as is until they die. Since they do what I really need them to do (with some wants for future models), I hopefully am good for a few years.
simonbarker
Mar 19, 2018 12:34 |  #6
It's a valid concern as that's what Chinese firms are known for but you'd have gotten the same from Elinchrom with ELC/ELB or Profoto D heads.
It would appear the price of progress is obsolescence but I'll not be replacing my AD600 anytime soon as it still works just fine.
RDKirk
Joined May 2004
Mar 19, 2018 12:56 |  #7
TeamSpeed wrote in post #18589247 (external link)
As soon as I heard about the new model coming out, Adorama had a sale of the AD600 and I jumped on that, just to have some compatible backup...just in case the new model was incompatible. Which it is.
fotopaul
Joined Jul 2015
Mar 19, 2018 13:22 |  #8
simonbarker wrote in post #18589329 (external link)
ELC/ELB in what sense?
Instagram (external link)
Blog (external link)
Osa713
Gallery: 48 photos
Joined Jun 2011
Post edited over 5 years ago by Osa713. (3 edits in all)
Mar 20, 2018 01:09 |  #9
RDKirk wrote in post #18589162 (external link)
All of this was addressed prior to the release. The two units are different though the pro is a higher end version of the Xplor aimed at “pros” not a replacement. Keep in mind the xplor is the entry level unit with TTL and manual option and the pro is TTL only.
I bought the Adorama version of the xplor prior to the pro announcement/speculati​on and no word on stopping support for it. And in the crazy event that happens Adorama has you covered for a discount towards a new unit if yours craps out and it can’t be replaced. You can’t beat that really for the cost.
It’s a little too early to think the xplor is outdated already, look at the rovelight there is still support for that unit and the xplor is better than that imo. Let’s wait until Godox makes a version II then we can panic.
LIGHT>LENS>BODY
Jotto123
Joined Jul 2012
Mar 20, 2018 05:28 |  #10
Hopefully they make a studio version.
6d - 135L - 85mm 1.8 - 50mm 1.8 - 35Art
MayaTlab
Joined Sep 2016
Mar 20, 2018 05:53 |  #11
Jotto123 wrote in post #18589905 (external link)
But is there a point, given that it will soon have the AC adapter, a 38W modeling lamp, and a 0.9 recycle time ?
Maybe heat dissipation could be improved though ?
RDKirk
Joined May 2004
Mar 20, 2018 07:03 |  #12
Osa713 wrote in post #18589818 (external link)
I'm aware of all that. Being aware of incompatibility does not make me like it.
I'm likely to buy an AD600 Pro, primarily for the modeling light. But the incompatibility will still irk me because "everything essential must be redundant."
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 5 years ago by TeamSpeed. (5 edits in all)
Mar 20, 2018 07:05 |  #13
RDKirk wrote in post #18589940 (external link)
Have you looked into the latest batches of LED lights? If you want a modeling light, the lights I just picked up for our video crew might be interesting to you.
The Neewer 480 LED panel takes main power or also 2 rechargeables for mobile/travel studios, and you can dial in the temperature setting and brightness, both useful as a modeling light. Only $70... It works pretty darn well for video, and I would think also as a modeling light. Just no remote control, but there are a few others that include an IR controller.
https://www.amazon.com …r=8-4&keywords=neewer+480 (external link)
The dual head for the AD200 does pretty well as a modeling light too, if you want to stay within the Godox line, and use the modularity of the current systems.
https://www.amazon.com …ywords=led+mode​ling+light (external link)
RDKirk
Joined May 2004
Mar 20, 2018 07:09 |  #14
TeamSpeed wrote in post #18589944 (external link)
'Way back in the early 80s I had a set of Spiratone AC flashes that each had a hot shoe for a little floodlight they sold as an attachable modeling light. I don't plan to go that route again.
I've got a couple of sets of LED lights I use for video interviews--both canister form-format that I can use with my still modifiers and panels that I use for general room lighting. I'm not going to try stuffing one of them into a softbox along with the flash unit.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 5 years ago by TeamSpeed. (6 edits in all)
Mar 20, 2018 07:11 as a reply to  @ RDKirk's post |  #15
So what about the dual head for the AD200? The dual head puts out just a bit less light than the AD600, and you get the modeling light (or 2 really, you can turn each on independently). Not sure if you have any AD200 units though, they are quite handy, and often you can pick them up on sale with accessories for around $280 or so each.
https://www.diyphotogr​aphy.net …200-lights-even-powerful/ (external link)
https://www.youtube.co​m/watch?v=vTMLoyYOy3s (external link)
11,753 views & 13 likes for this thread, 13 members have posted to it and it is followed by 6 members.
1451 guests, 128 members online
