FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 19 Mar 2018 (Monday) 10:11
Light and SMALL tripods for travels
Jocce
Gallery: 12 photos
Joined Jun 2012
Mar 19, 2018 10:11 |  #1
I've had a Gorillapod for a while, perfect for trips when I need something small that doesnät take up much space in the luggage and when I dont know if I'll need a Tripod (or only going to use it a handfull of times).
But this is getting hard to get really stabel with my 5D Mark IV and a 24-70/2,8 or similar.
Any suggestions on other tripods that could work, but still are small?
/Jocce
Feel free to correct my English. I'm from Sweden ;)
My Website (external link)
Fotointresse.se (external link)
Twitter (external link)
renodcc
Joined May 2011
Mar 19, 2018 14:59 |  #2
Manfrotto pixi
SYS
Gallery: 602 photos
Joined Jul 2004
Mar 19, 2018 16:53 |  #3
I have Pixi, and it certainly can handle your camera and the lens. I just don't know whether you'd want something this small?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/03/3/LQ_905305.jpg
Image hosted by forum (905305) © SYS [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/03/3/LQ_905306.jpg
Image hosted by forum (905306) © SYS [SHARE LINK]
-Goethe
ra40
Gallery: 887 photos
Joined Jan 2013
Mar 19, 2018 19:13 |  #4
I've liked the Really Right Stuff TFA-01 with a medium type of head. Travels easily barring the head selected which can add size-weight. Bought the Ultra version a year some odd back with the smaller Cullmann head for use with the Canon M3 and P&S's.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/03/3/LQ_905326.jpg
Image hosted by forum (905326) © ra40 [SHARE LINK]
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 19, 2018 19:46 |  #5
There is also the Platypod, it's a bit different.
500px (external link)
1x (external link)
instagram (external link)
John ­ from ­ PA
Joined May 2003
Mar 19, 2018 19:54 |  #6
We discussed this quite a bit in mid-February. See https://photography-on-the.net …showthread.php?​p=18566583.
Jocce
Gallery: 12 photos
Joined Jun 2012
Post edited over 5 years ago by Jocce.
Mar 20, 2018 03:32 |  #7
SYS wrote in post #18589520 (external link)
Hosted photo: posted by SYS in
./showthread.php?p=185​89520&i=i223992307
forum: Tripods, Monopods & Other Camera Support
./showthread.php?p=185​89520&i=i4228164
Wow. Did not think it was that sturdy!
Could work. Small is good (= fits in any bag) even though a little bit higher would be better, but not a demand!
But it says it will only support 1kg. With a lens like that (and in my case Battery Grip) it weight is the double?
/Jocce
Jocce
Gallery: 12 photos
Joined Jun 2012
Mar 20, 2018 04:53 as a reply to  @ John from PA's post |  #8
Thanks! I'll have a look! :)
/Jocce
Jocce
Gallery: 12 photos
Joined Jun 2012
Mar 20, 2018 04:54 |  #9
I should also mention that I do not need it to be able to get high, so a lower one as the Pixi would work, as long as it is steardy enough and that I am able to point the camera in a quite steep angle upwards (astrofoto)
/Jocce
SYS
Gallery: 602 photos
Joined Jul 2004
Post edited over 5 years ago by SYS.
Mar 20, 2018 11:23 |  #10
Jocce wrote in post #18589866 (external link)
/Jocce
I never gave credence to those listed load capacity. When I was testing it with the load capacity you see in my photo, I felt that Pixi could actually take on more weight. Because of its small size, just be sure to use one of the legs in the same direction as the lens for better balance. If you have a store nearby where you live that carries the product, of course it's best to try it out first.
If load capacity concerns you, there are other options, such as, but not limited to, this by Sirui with the load capacity of 8.8 lbs:
https://www.bhphotovid​eo.com …pod_kit_black.h​tml?sts=pi (external link)
-Goethe
SYS
Gallery: 602 photos
Joined Jul 2004
Mar 20, 2018 11:34 |  #11
Of course, if budget is not much of a concern, I'd go with the Really Right Stuff TFA-01 mentioned above by ra40....
-Goethe
ra40
Gallery: 887 photos
Joined Jan 2013
Mar 20, 2018 14:37 |  #12
Had one of the Giottos mini tripods about 15 some odd years ago with a Manfrotto 486 ball head that I really liked. That rig with head was about $80 total. Used the 5D 24-70 on it without issue. Was stolen at a shoot unfortunately. I'd been able to easily replace the legs but the Manfrotto 496 head that superseded the 486 was coarse and gritty. (Manfrotto applied grease to the head and that was messy.)
They bundle the Giottos like this now:
https://www.bhphotovid​eo.com …moire_t2_mini_t​ripod.html (external link)
The Oben version looks similar also:
https://www.bhphotovid​eo.com …100_Table_Top_T​ripod.html (external link)
Mark ­ A.
Gallery: 361 photos
Joined Mar 2011
Post edited over 5 years ago by Mark A..
Mar 24, 2018 07:38 |  #13
I own perhaps a dozen tripods, including a Really Right Stuff 'Pocket Pod' TFA-01 with a BC-18 ballhead that I like quite a bit.
I carry it in my camera bag.
It is superbly made and able to support a Canon 1 Series camera.
The BC-18 ballhead is strong and secure, but I do find it a bit annoying to get it set to where I want it.
It works fine, but it is just weird to me (as in counter intuitive).
I chose it over a conventional ball head however, because I wanted as a minimalist approach as possible.
There is a technique where you can mount the tripod to the camera and support the assembly against your chest.
I saw it on-line somewhere and it helps with low shutter speeds.
It also is useful when 'going prone', sort of like a bi-pod on a rifle.
The whole assembly is so sturdy that you can mount the camera and either lash them to something (like a bench or a tree) or place a weight on a leg for added stability.
(I have used a bungee cord once, to hold the assembly down. It was great.)
With this class of tripod, with three short legs, tipping over is always a consideration, with any brand I would think.
Usually, it is best to have the weight of the camera over an out-stretched leg, if possible.
It is so strong, well-made, and compact that you can leave it of the camera in between shots and it is OK like that for a while (it is not too annoying).
Removing it is also a breeze though; RRS uses brilliantly shaped knobs.
This miniature tripod is superbly crafted and rock-solid.
I would rather pay good money up front than deal with something much lesser (and possibly frustrating) when in use.
(I've heard it said that you can often fix image noise, but it is harder to fix equipment motion blur)
I would buy it again, no problem.
As opposed to loading up this post, if you start with this image on Flickr and then scroll to the left, there are a few more images that may be useful.
IMAGE: https://farm1.staticflickr.com/395/31952477906_0f54e3f0ed_b.jpg
IMAGE LINK: https://flic.kr/p/QFwN​tu  (external link) DEF_0946_3 (external link) by Mark A. photo (external link), on Flickr
Mark ­ A.
Gallery: 361 photos
Joined Mar 2011
Mar 24, 2018 08:26 |  #14
I went looking for where I learned of the technique to use these mini-tripods against one's chest for added stability, and I found the video:
https://www.youtube.co​m/watch?v=dEPas8MoJLA (external link)
Jocce; there are lots of other tripod reviews on YouTube that may also be of value to you, as make your small tripod buying decisions!
John ­ from ­ PA
Joined May 2003
Mar 24, 2018 09:02 |  #15
A good thread from a few weeks back can be found at https://photography-on-the.net …showthread.php?​p=18566583.
8,798 views & 9 likes for this thread, 9 members have posted to it and it is followed by 6 members.
1125 guests, 170 members online
