Thread started 22 Mar 2018 (Thursday) 10:06
Panorama Issue
tspencer1
Joined Oct 2015
Mar 22, 2018 10:06 |  #1
I used Affinity Photo to do this panorama - total 22 photos. Any idea why the top of the roof is curved? I also tried ON1 Raw and got the same result.
Thanks-
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/03/4/LQ_905666.jpg
Image hosted by forum (905666) © tspencer1 [SHARE LINK]
saea501
... spilled over a little on the panties
Gallery: 43 photos
Mar 22, 2018 10:53 |  #2
I'm thinking it is because as you shoot each picture you have to pan the camera to the next position and, as you're panning from a fixed point, each progressive picture is part of a circle. The distance from the sensor plane to the left extreme of the building is greater than the distance from the sensor plane to the center of the building. So when the algorithm assembled this it had to curve the building to get the correct alignment.
Just my guess.
It's an easy fix in PS especially since the curve is slight.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
BigAl007
Gallery: 556 photos
Mar 22, 2018 11:12 |  #3
What you are seeing is the normally expected perspective distortion as would be expected when using any extream wideangle lens. The perpective distortion is due to angle of view, not focal length. You could shoot lots more images using a 600mm lens to get the same coverage and the final image would still have the same degree of distortion, although it would have a lot more detail.
As saea501 says it is relativly simple to correct in post processing. One tip to remember if you do want to correct this is to make the pano quite a bit bigger than you want, so you have plenty of spare pixels to bend about during the correction. This will give you more options when it comes to making the final crop.
Alan
tspencer1
Joined Oct 2015
Mar 22, 2018 12:54 as a reply to  @ BigAl007's post |  #4
Thank you both. Makes perfect sense. I don't have PS but did watch a couple of videos on how to fix. I did not find anything similar in ON1 Raw - but appreciate the tips.
kirkt
Post edited over 5 years ago by kirkt. (3 edits in all)
Mar 22, 2018 12:58 |  #5
This distortion is easily corrected with simple pixel editing tools like the Warp tool and Distort tool in PS. Also, if your pano application gives you various projection options, choose "rectilinear" instead of "equirectangular" or "spherical" or "cylindrical."
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/03/4/LQ_905688.jpg
Image hosted by forum (905688) © kirkt [SHARE LINK]
Kirk
WiscTim
Gallery: 92 photos
Mar 22, 2018 14:53 |  #6
There is an Affinity Photo tutorial on how to correct panorama distortion:
https://vimeo.com/1706​33074 (external link)
C&C always welcome, editing allowed
tspencer1
Joined Oct 2015
Mar 22, 2018 19:57 as a reply to  @ WiscTim's post |  #7
Kirkt and WiscTim - thank you both!
inkista
Apr 11, 2018 15:41 |  #8
Just one other note. You can usually fix this kind of distortion in the pano-stitching software before you stitch. In Hugin, for example, in the preview window's move/drag tab, you can adjust the yaw, pitch, and roll for the pano by simply dragging around.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/04/2/LQ_908573.jpg
Image hosted by forum (908573) © inkista [SHARE LINK]
If you drag vertically, you adjust the pitch (horizontal bowing, and getting leaning verticals to be vertical again).
Dragging horizontally adjusts yaw (usually only useful to re-center a 360º pano).
And right-dragging (or ctrl-dragging if you're on OSX) will adjust the roll; good for tilted horizons, or S-horizons in 360ºx180º/equirectangu​lar panos.
Most panostitching standalone programs (Hugin, PTGui, ICE, etc.) have a feature like this, and it's one reason not to be stitching using Lightroom or Photoshop. :)
Also, if the stitching program lets you set control points, you can set horizontal and vertical control points to ensure vertical or horizontal lines. See: http://www.johnhpanos.​com/levtut.htm (external link)
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
tspencer1
Joined Oct 2015
Apr 13, 2018 09:17 as a reply to  @ inkista's post |  #9
Good info - thank you!
2,790 views & 8 likes for this thread, 6 members have posted to it.
Panorama Issue
1061 guests, 101 members online
