Thread started 20 Mar 2006 (Monday) 01:53
How's this background?
Lotto
Mar 20, 2006 01:53 |  #1
I picked up a $15 piece of fabric from Walmart for portrait background test. I like the color and tone, but untill start shooting with it, I find it is quite 'busy'. Anyway, I try my best to use longer lens to throw the BG out of focus, choose contrast color between subject's clothes and BG filter. Still, I am not sure if it will work. Here's couple samples...
What do you think? Does the background take too much atttention away from the main subjects?
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Hermes
Mar 20, 2006 02:03 |  #2
There's a little bit too much going on for my liking but i'm impressed with how crease-free you've managed to keep the bg. How did you hang it? what type of material is it?
Maybe it's just the fact that you've tested it with child portraits - they are usually best kept simple. I'd say defininately try moving the subject further from the bg, use a longer lens and enhance the blur in ps if necessary.
Ruffneck
Mar 20, 2006 02:57 |  #3
To be honest...it really isn't all that bad!
Canon 20D & 60D, Canon70-200mm L 4.0, Canon 17-40mm L 4.0, Canon 24-70 L, 2.8, Canon 28-135mm IS, Canon 85mm f1.8, Canon 100mm Portrait Lense, Tamron 17-50 VC, Sigma 15-70mm 2.8-4 HSM, Canon Speedlite 580Ex, Canon Speedlite 420Ex, 3 AB800's, ...and a whole host of other odds and ends!
TeeJay
Joined Jun 2005
Mar 20, 2006 03:04 |  #4
Like the others have said, that doesn't look too bad. They could both do with being a little more OOF, but I think I prefer the second - maybe it's the contrast of colours that does it for me.
(I didn't know they still sold fabric with this sort of pattern on it - looks like it's left over from the 70's - you did well finding it!;-)a)
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
tim
Light Bringer
Mar 20, 2006 04:42 |  #5
It's not bad, esp if you can get your DOF a bit narrower.
rayzorb
Joined May 2003
Mar 20, 2006 05:24 |  #6
I like the shots. How did you place your flash units and what camera settings did you use?
50D + 30D + 20D(sold) + 580EX | G3 | IXUS 700
Lens: 24-105L IS (Xmas 2007 :D), 100-400L IS (Xmas 2006 :) )
50mm 1.8, 100mm Macro, 10-22mm, Conia 17-34mm(sold)
HP B9180 Pro Printer
Lots of Manfrotto, Lowpro and Giottos bit and pieces
tim
Light Bringer
Mar 20, 2006 05:51 as a reply to  @ rayzorb's post |  #7
You'll probably learn more if you try to work it out by looking carefully at the shadows... take your best guess and someone will tell you if you're correct :)
rayzorb
Joined May 2003
Mar 20, 2006 06:07 |  #8
I'd guess he bounced the 580 directly off the roof and had the 430 45deg to the left slightly higher than the camera? I have the same setup (580 and 420) but my shots look so flat....I will post tomorrow for some advice..(late here in Australia)
Ray
Amorous
Mar 20, 2006 12:47 as a reply to  @ rayzorb's post |  #9
Ray
I seem to remember that he has a home made softbox that he uses with 580EX. So, I would say soft box with 580EX on camera left and 430 as the hair light on camera right.
My web site: http://kaitcilla.smugm​ug.com/ (external link)
Los Angeles area local photography group: http://lashooters.org (external link)
Amorous
Mar 20, 2006 12:49 as a reply to  @ Amorous's post |  #10
The shots are not bad at all, and I do like the second one better. May be it's because the BG was OOF more. Considering the cost of the BG, you did a great job. I seem to remember that you take studio portrait shots in the garage. You definitely will need if you place the subject farther away from BG and use a longer lens.
wazmunstr
Joined Feb 2006
Mar 20, 2006 13:00 |  #11
i agree with everone here. try and get your subject farther from the bg. the blur with blend the colors of the fabric together and look less distracting.
Instagram // http://www.instagram.c​om/versuspixels (external link)
Lotto
Mar 20, 2006 15:20 as a reply to  @ wazmunstr's post |  #12
Thanks for everyone's feedbacks. I post couple more pictures to show my setup, hope that could answer some of your questions.
#3 shows the garage and my home made gadgets. The positions of the lights maybe a bit differents in the actual shots, but you got the idea. This is my first test using a back drop, have been using that plain white wall for a while, and it starts to get a little 'bored'. Most of the my photo subjects are yong kids, lots of times I would have some props in their hands to keep them quiet and still, and I prefer to shoot f5.6-f8. Maybe time for me to buy a real back drop:oops:
#4 is my favorite of the shoot, just like everyone suggesting here, longer lens and larger lens openning did the trick.
#3
#4
TeeJay
Joined Jun 2005
Mar 21, 2006 03:16 as a reply to  @ Lotto's post |  #13
#4 is superb! - I think it works really well with those settings - now how much did you say you were selling that fabric for? :D
rayzorb
Joined May 2003
Mar 21, 2006 03:37 |  #14
Lotto, are you using your flash units in the softboxes or are they dedicated lights? Also, what sort of hairlight and kicker do you use? I am very interested as you mentioned they are home made and I need to say as much $$$ as possible....Saving for an L one day ;)
Lotto
Mar 21, 2006 04:56 as a reply to  @ rayzorb's post |  #15
Thx TJ, once you visit a fabric store, you will find something nice that you like in there:eek:
rayzorb, all my lights are AA or AAA powered flashes. Like the others noticed already, the 580 is in a 24x36" SB, the 430 is in used with a 18x18" small SB for the kicker. For the BG and hairlight, i use couple of the cheap wireless slave flash--http://www.ritzcamera.​com/product/531660769.​htm (external link). If you are comfortable working with metal and have some basic tools, you could made all sorts of light modifiers too. Nothing against the real studio setups, but I like to learn the fundamentals before I invest in them.
Thanks again for looking.
3,461 views & 0 likes for this thread, 15 members have posted to it.
1589 guests, 137 members online
