Thread started 20 Mar 2006 (Monday) 06:02
Silly Question time
dpp
Joined Oct 2004
Mar 20, 2006 06:02 |  #1
Hello
Firstly I m not a big flash user, and sometimes struggle to understand it.
My question is this.
How do I balance the flash output with the ambient room light to that I get the ambience of the room light but light the subject and some of the background.
This is what I have been doing.
Setting higher ISO and FEC set to anywhere from -1 to -2.
But this is guess work on my part and the images look fine, but is there a better more reliable way?
Cheers
snibbetsj
Joined Jun 2004
Mar 20, 2006 08:45 |  #2
Well, you can set up in Av mode, select your aperture, make sure shutter is within sync speed or het HSS, set FEC about -.5 and that will work, or set up in M mode, set exposure correctly, keeping shutter speed slower than 1/250 or select HSS, and dial in about -1 to -1.5 FEC. Either method should work fine.
Jeff Stebbins
TeeJay
Joined Jun 2005
Mar 20, 2006 09:16 |  #3
Or, to put it another way, select Shutter Priority (Tv) mode, and set your shutter to say 1/125. This will allow the camera to expose for existing ambient lighting, and the flash system (ETTL) on the camera will pop the flash to fill in where it needs to.
If the subject comes out dark, (but the rest of the pic is OK) half press your shutter button, and let go. Whilst the display is still "active" press the little button on top of the camera nearest your finger. This will then display the Flash Exposure Compensation readout in the viewfinder (which is slightly smaller than the normal display at the bottom of the viewfinder). Using the wheel on top of the camera, move the dial to the left to make the subject darker, and to the right to make the subject lighter (but, importantly - leaving the background exposed correctly)
Play around with that and see how it goes.
I started out thinking that I would try and explain that in just a few words - Hmm.... guess I failed!:-)
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
tim
Light Bringer
Mar 21, 2006 01:37 |  #4
Reset the camera to defaults (mainly set FEC to zero) and shoot in P mode. If the background's too dark up the ISO (if it lets you, never used P so not sure you can change ISO in that mode). If it doesn't do what you want post the picture and tell us what you want to change.
Now how would I do it? I'd meter the background in either Av or Manual, set FEC to zero, then shoot.
newgenphoto
Joined Jul 2004
Mar 21, 2006 13:53 as a reply to  @ tim's post |  #5
My thoughts as well Tim... I can dig up an example or two where this worked very well.
Jasen Master
J. Master Photography (external link)
My Gear (Needs updated)
JMP Blog (external link)
Facebook (external link)
1,744 views & 0 likes for this thread, 5 members have posted to it.
Silly Question time
1681 guests, 138 members online
