FORUMS General Gear Talk Camera Vs. Camera
Thread started 30 Apr 2018 (Monday) 16:34
Autofocus Demands
wunhang
Apr 30, 2018 16:34 |  #1
So I ran into an interesting issue that I figured the know-it-alls from on high would be able to figure out... I previously was using my SL1 on my 70-200 for the long reach second camera with my 5D2 on the general use end with the 24-70. Now that I have a shiny new 5D4, I am wondering which is actually more demanding on the autofocus to nail focus - long end or short end? Which would you put the older 9 point autofocus system on versus the latest and greatest?
Canon 5D IV | Canon 5D II | XSI (Infrared modified) | SL1 | 16-35mm L f/4.0 IS | 24-70mm L f/2.8 II | 40mm f/2.8 | 85mm f/1.8 | 70-200mm L f/4.0 IS | Rokinon 14mm f/2.8 | C/Y 28mm f/2.8 | Tamron 35mm f/1.8 VC | C/Y 50mm f/1.7 | Zeiss 100mm MP
::SmugMug (external link)::
EverydayGetaway
Joined Oct 2012
May 01, 2018 00:26 |  #2
If it were me I'd just put whatever lens/focal length you think will be used the most on the newer camera. If they get used the same amount then I'd think that the narrower DOF of a longer lens would make focus more critical.
Fuji X-Pro2 // Fuji X-T1 // Fuji X-100T // XF 18mm f2 // XF 35mm f1.4 // XF 60mm f2.4 // Rokinon 12mm f2 // Rokinon 21mm f1.4 // XF 18-55mm f/2.8-4 // XF 55-200mm f3.5-4.8 // Rokinon 85mm f1.4 // Zhonghi Lensturbo ii // Various adapted MF lenses
flickr (external link) // Instagram (external link)
Bassat
"I am still in my underwear."
Joined Oct 2015
May 01, 2018 06:14 |  #3
I haven't had focus speed/accuracy issues since I sold my 5Dc. Well, discounting the 6D in AI-Servo. Pretty much any modern camera with any modern lens attached should do a good job of AF. Of course, extremes exist.
saea501
... spilled over a little on the panties
Gallery: 42 photos
May 01, 2018 08:41 |  #4
Bassat wrote in post #18617276 (external link)
The 6D has no problems with AI Servo.
At least mine doesn't. I guess I got the only 6D with a focus system that works quite well for moving subjects. How lucky I am. ;-)a
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com …282@N06/with/38​203470844/ (external link)
Bassat
Joined Oct 2015
May 01, 2018 12:25 |  #5
saea501 wrote in post #18617340 (external link)
I used a 6D side by side with a 1D4. The 6D can't compete. Traded 1D4 for an 80D. Ditto.
davesrose
Title Fairy still hasn't visited me!
May 01, 2018 12:34 |  #6
I would think that speed of focus depends on what ranges your focusing. If you need to select full range with your 70-200mm to focus, then it will take longer to focus from far end to something close by. Likewise for 24-70mm. I think the main consideration is whether you want to use the SL1 for reach with the longer end of the 200mm or don't need the reach and want more focus points from the 5D4.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
wunhang
Post edited 8 months ago by wunhang.
May 01, 2018 14:18 |  #7
davesrose wrote in post #18617461 (external link)
Well, before I got the 5d4, I assumed that the AF performance across my gear was par. The lenses would perform the same in terms of focus accuracy/capability whether on the little rebel or the 5D2 negating the framing difference of the two cameras (ie if I took a picture of something 15 ft away and just crop the 5D2 picture to get the same image as the SL1).
Now, on a recent shoot, I was to take pictures of a child running towards me across a bridge with her balloons billowing behind her, I went from 200mm when she started out (~150 ft) down to near 35mm (running past me ~ 5 ft away). So I had to have both cameras at the ready. In terms of criticality of nailing the focus on a running child, would the 5D4 or 5D2 be on the wide end or the long end?
I put the 70-200 on the 5D2 since I thought at the time that the distance differential between shots would be less severe on the AF keeping up (5 ft of change from 150 ft away would not cause the focus to shift much since % change in focus distance was less). I still ended up with significantly more keepers on the 5D4 than the 5D2. Just trying to rationalize whether I made a mistake or did the right thing in my setup.
davesrose
May 01, 2018 19:19 as a reply to  @ wunhang's post |  #8
I went from a 5Dc (which had the same AF as the 5D2) to a 5D3 (which has similar AF to the 5D4). I did some manual focusing with the 5Dc because of the limited AF points and the less sensitive low light capability. Again, I think the main deal with AF speed (in daylight) is more to do with how much focus pull it’s having to do (example being wildlife, where you might switch focus from something far, to close, to far again). Personally, I prefer the 5D3/5D4’s use of more AF points. I got a 7D2 for a crop since it has more AF points and an interface like the 5D3. I know some people have said they don’t use the 7D2 as much if going with a 5D4, as the extra resolution is more tolerant of cropping.
Extra AF points helps with normal focal lengths where I can select a particular point I want to focus on. It also helps with telephoto: in your example of a kid running up to the camera, a camera with 61 AF points has more spread for AF tracking and keeping points on the kid.
Canon 5D mk IV
879 views & 2 likes for this thread
Autofocus Demands
Latest registered member is laylaholic
681 guests, 267 members online
