FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 02 May 2018 (Wednesday) 08:56
Gimbal Heads and Tripods
Nick5
May 02, 2018 08:56 |  #1
Looking at two different tripods to be used with a gimbal head.
Both do not have center column.
Induro GIT 304 L at 59" and the GIT 404 XL at 71"
At 5'11 tall the 304 would be fine for relatively flat ground............
So do most of you that have a "Rig" go for the larger size?
Just thought I would see what most are using.
Thanks.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
SYS
Gallery: 602 photos
Joined Jul 2004
May 02, 2018 11:53 |  #2
You can make tall shorter but you can't make short taller. That's the main advantage for 404. One way to figure out whether this is going to be a real and practical advantage for you is to ask how many times have you in the past felt the need for a taller tripod for your shooting needs. If not, then you don't really have a practical need for one and 304 has a real, practical advantage in weighing far less than 404, if you do plan on using the tripod for birding or wildlife. Since you want to pair it with your Gimbal head, I'd have to assume that it isn't for your home use. Gimbal head alone can get pretty heavy. You add the tripod, ball head and your camera and the long lens on top of everything, things can pile up quickly weight wise.
I have a Gitzo GT4553S with almost identical weight as 304 and ProMediaGear GT1 Tomahawk Sidekick Gimbal that only weighs 1.9lbs, and these two alone is pretty heavy. Add the RRS BH-55 ball head, 5DIII and pretty light Sigma 150-600C.... and I'm not young. ;-)a
-Goethe
johnf3f
May 02, 2018 18:02 |  #3
Just to give you an idea, I am a bit shorter than you at 5'9''.
I was out earlier today using my Gitzo GT4542LS, Wimberley 2 and 800mm. This tripod goes to 61'' and I still had 9'' of tripod height in reserve. The Gimmbal head adds quite a lot of height!
Always get a tripod that is taller than you need but you don't have to go too far;-)a
Life is for living, cameras are to capture it (one day I will learn how!).
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 5 years ago by CyberDyneSystems.
May 02, 2018 18:30 |  #4
I prefer the 3 series for pretty much all the work I do.
I did happen to pick up an Induro 4 series a few years back when they were on stupid low price clearance for the newer model,. and man it's a huge wonderful tripod. That said, I have never needed the additional height or "beef" and pretty much always pack the 3 series. The only time I have really used the 4 was in studio, or when I needed more than one tripod, and lastly for astro work at above 1000mm.
3 series with a Gimbal is the most common bird set up I've seen. But there are those with 4 and even 5 series out there too.
I am 6'
As John says, the Gimbal adds height, as does a leveling column if you go in for that. I find them indispensable.
CDS' HOT LINKS
Nick5
Jun 04, 2018 21:30 |  #5
Well I bought the Induro GIT 304 L Tripod along with the Induro GHB2 Gimbal Head. With a level surface and my lower legs retracted about 4", my 5D Mark III and 100-400 L IS Mark II on Gimbal raised at Center Point is at a comfortable eye level.
Very sturdy and does fold down to a nice small size.
Valerie ­ S
Jun 12, 2018 02:06 |  #6
I've got a Gitzo GT 5541LS with a Wimberely WH-200. It's a beast, but I never have to worry about stability. I'm a very fit woman in my 50's, 5'7" and I climb down cliffs with the Gitzo attached to a ThinkTank Glass Limo with a 400/2.8G and a D5 or D500, so portability is subjective. I'll shoot with a 400/2.8, 1.4x TC III and a D500 on it and it's solid. It is taller with the WH-200, but the tripod is pretty tall on it's own and works for odd situations, like his. It also folds down to shoot from about 6" off the ground.
My feelings on tripods are, get something that more stable than you need for your longest lens set up, so you're ready for anything. Pick up a second lighter duty tripod later later for other stuff. You can always put a 14-24 on the 5541LS, but you can't put a 400/2.8 on a 2 series.
my stuffz
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jun 12, 2018 14:54 |  #7
Valerie S wrote in post #18643692 (external link)
. . . and I climb down cliffs with the Gitzo attached to a ThinkTank Glass Limo with a 400/2.8G and a D5 or D500, so portability is subjective.
This is quite intriguing!
What is it that you shoot?
johnf3f
Jun 12, 2018 18:31 |  #8
I like your thinking! The 5541 is a bit of a monster but, as you say, it is stable!
I am more than happy with my 4 series (GT4542LS) for my 800mm (my previous 3 series was OK too) but you can never have too much with tripods so long as you can carry them!
2,024 views & 3 likes for this thread, 6 members have posted to it and it is followed by 5 members.
1475 guests, 132 members online
