Hi,
I had a mid-2011 27 inch iMac that had thunderbolt 2. I bought an OWC TB2 dock (https://eshop.macsales.com
). After plugging in the dock, I still had 2 TB2 connections available (1 on the iMac, 1 on the TB2 dock). I liked the OWC dock because it not only added USB ports, but it also had a Firewire port (I still have a couple of legacy Firewire devices). I hooked 2 Seagate TB2 external drives to the dock, booting the iMac from an SSD I installed in one of the drives. I ran the system this way for several years. The iMac booted and operated very fast.
I now have a 2017 27 inch retina iMac. It has TB3, so I bought an Apple TB3 to TB2 converter to hook the OWC dock to. I know OWC has a TB3 dock but I still wanted to use the dock I have. The TB2 dock still works wonderfully. I've got one of the Seagate external TB2 drives still hooked to the dock and boot from it and several USB 3 external drives as backup devices. I hook the other iMac TB3 port to an Akitio (https://www.akitio.com/products
) Thunder3 Raid box with two 1 TB hard drives raided for video editing. The Akitio also has 2 USB 3 ports, an ethernet port, an SD card slot, and another TB3 port which I've got a TB3 to TB2 converter plugged in to hook to a Buffalo TB2 1TB hard drive to store my pictures.
If I were to buy another dock, I would have no fear buying the OWC TB3 dock. The TB2 dock I have had been replaced by OWC after they found a problem with the USB ports disconnecting hard drives that were attached to them. The replacement dock has worked without a problem.
I know the OWC docks trade one TB port for another, not really giving you any more TB ports. But, I've bought TB devices that had at least 2 ports on them so I could daisy chain the devices. I've got 3 TB2 devices daisy chained on one TB3 converter and haven't noticed any degredation. Hope this info is helpful. Feel free to ask questions.
Mark
