Need flash for indoors...have a d7!! and a eos 5d!!!. know very little about flash but know I need something for indoors. Something to build on in class I later want a slave for special pictures.
thanks
May 20, 2018 16:08 | #1 Need flash for indoors...have a d7!! and a eos 5d!!!. know very little about flash but know I need something for indoors. Something to build on in class I later want a slave for special pictures. Gear
inkista Senior Member 700 posts Likes: 95 Joined Oct 2007 Location: San Diego, CA, USA More info | May 20, 2018 17:49 | #2 What's your budget? What are you shooting with flash indoors? Are you planning on using it more on the camera hotshoe? Or off camera on a lightstand in studio-style setups? I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream
Lyndön Goldmember More info Post edited over 5 years ago by Lyndön. | May 20, 2018 20:28 | #3 Yep, Godox/Flashpoint (same stuff rebranded) is probably the best in terms of value for the price, and the ability to be cross compatible between different camera systems is great for future-proofing to some degree. Personally I lean toward Flashpoint stuff because I find they come with higher quality cases and a few extras sometimes vs. the Godox brand... even though they’re essentially the same item.
May 20, 2018 23:13 | #4 Lyndön wrote in post #18629287 Yep, Godox/Flashpoint (same stuff rebranded) is probably the best in terms of value for the price, and the ability to be cross compatible between different camera systems is great for future-proofing to some degree. Personally I lean toward Flashpoint stuff because I find they come with higher quality cases and a few extras sometimes vs. the Godox brand... even though they’re essentially the same item.
Gear
Lyndön Goldmember More info Post edited over 5 years ago by Lyndön. | May 20, 2018 23:44 | #5 They’re very popular on here for sure. One reason is that they have an entire system of lights from small speedlites up to very powerful 1200w/s strobes, that can all be mixed and matched for off camera use with a single transmitter (per camera brand). That’s great for us who shoot more than one system, since we only need to buy one transmitter per brand and all of our lights are cross-compatible whether we’re using a body from Canon, Sony, Fuji, Olympus, Panasonic, or Nikon. The only catch is that you have to buy a flash unit specific to your camera brand if you’re going to be using it ON the camera. Once they’re off-camera they don’t care about what brand the master is. They’re also built pretty well, probably not quite up to Canon’s build quality (at least not in weather sealing), but hey... you can get about 4 TT685’s for one Canon 600EX-RT.
May 21, 2018 00:00 | #6 will use it on the camera until I find out something else that would make a good picture (where more than 1 light is needed). Gear
May 21, 2018 00:39 | #7 Don't make the same mistake as I did: Get the most powerful you can afford and are willing to lug around. For on-camera you want lot's of ooompf (bounce flash).
inkista Senior Member 700 posts Likes: 95 Joined Oct 2007 Location: San Diego, CA, USA More info | May 21, 2018 01:10 | #8 Lyndön wrote in post #18629388 ... I’ve never used a Godox speedlites on my Canon though, just on my Sony and Olympus which don’t use AF assist on the speedlite for some reason. I think, from what I've read, that since AF function is done by the image sensor on mirrorless cameras (not a separate AF array), and because the image sensor has a UV/IR cut filter over it, and most AF assist lamps are IR or near-IR, they can be less-than-useful. That's why mirrorless cameras tend to use a white LED instead for AF-assist. I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream
inkista Senior Member 700 posts Likes: 95 Joined Oct 2007 Location: San Diego, CA, USA More info Post edited over 5 years ago by inkista. | May 21, 2018 01:13 | #9 drifter106 wrote in post #18629392 will use it on the camera until I find out something else that would make a good picture (where more than 1 light is needed). Ok, then you may want to also consider a Canon OEM flash, since they tend to be better for on-camera use. If you are budget constrained, possibly consider a used 580EXII rather than one of the newer radio-equipped RT flashes. The Godox TT685C or V860IIC tends to be better if you're budget-constrained or plan to use the flash off-camera as often as on-camera. You can always add an X1RC receiver to the foot of a 580EXII to use it along with other Godox gear. I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream
MalVeauX "Looks rough and well used" More info | May 21, 2018 09:20 | #10 drifter106 wrote in post #18629169 Need flash for indoors...have a d7!! and a eos 5d!!!. know very little about flash but know I need something for indoors. Something to build on in class I later want a slave for special pictures. thanks The R2 system is really fantastic, well made, reliable, and friendly to the budget. IMAGE LINK: https://flic.kr/p/Hv7XdF Here's the same flash (ETTL & HSS) in a 28" beauty dish, bare, in some brighter sun. Camera dropped ambient, flash filled for the contrasty look. At close range, you can flash in the sun for at least fill. IMAGE LINK: https://flic.kr/p/GVHrtn IMAGE LINK: https://flic.kr/p/25d8Qka Very best,
Lyndön Goldmember More info | May 21, 2018 10:45 | #11 inkista wrote in post #18629416 I think, from what I've read, that since AF function is done by the image sensor on mirrorless cameras (not a separate AF array), and because the image sensor has a UV/IR cut filter over it, and most AF assist lamps are IR or near-IR, they can be less-than-useful. That's why mirrorless cameras tend to use a white LED instead for AF-assist. The other criticism I've heard with Godox on the hotshoe is the stiffness in the head rotation (since the head is held in place by friction, rather than a lock button) can put additional torque on the hotshoe of the flash. And some folks feel that TTL performance isn't quite as good as with OEM, although reports vary on that. There's also some gracenote features in the RT system that aren't duplicated in the Godox X system, such as shutter release control via the camera hotshoe connection (i.e., you can use a flash as a shutter remote), four-digit ID codes (rather than two), the RF interference graph, remote wakeup, etc. Not to mention actual customer support and warranty factory repair vs. retailer exchanges and an email address in Shenzhen that never seems to bother replying to queries . But for a lot of folks, the price difference between the two (600EX II-RT: $480; TT685C: $110) can more than make up for the differences.The RT system does also allow for access to some 3rd-party studio strobes, notably a Phottix Indra and the Jinbei/Orlit RT strobes. But again, Godox is probably gonna cost less, and the AD200 option is more or less unique (although Cactus is changing that). And, of course, Godox also offers li-on versions of all their speedlights, which simplifies battery handling, which can be irresistible if you're an all-day multiple-flash shooter. I’ve read some things regarding the AF assist on mirrorless and seen similar explanations. It’s not that much of a big deal since the Sony and Olympus bodies I have both include AF assist lights (amber) on the body itself.
Ltdave it looks like im post #19,016 5,709 posts Gallery: 24 photos Likes: 8590 Joined Apr 2012 Location: the farthest point east in michigan More info | May 22, 2018 12:16 | #12 inkista wrote in post #18629417 Ok, then you may want to also consider a Canon OEM flash, since they tend to be better for on-camera use. If you are budget constrained, possibly consider a used 580EXII rather than one of the newer radio-equipped RT flashes. The Godox TT685C or V860IIC tends to be better if you're budget-constrained or plan to use the flash off-camera as often as on-camera. You can always add an X1RC receiver to the foot of a 580EXII to use it along with other Godox gear. Whatever you get, for on-camera use, I do recommend finding a speedlight with 360º swivel and TTL/HSS capability.
-im just trying. sometimes i succeed
May 22, 2018 16:39 | #13 what does the canon 600's have over the Godex/Flashpoint or visa versa. I know the canon is a lot more expensive but insofar as getting the job done and done right which would be the way to go. Gear
Lyndön Goldmember More info Post edited over 5 years ago by Lyndön. | May 22, 2018 22:45 | #14 The Canon has a better AF assist if you shoot in dark difficult situations (wedding receptions), and it’s better weather sealed if you get stuck in a situation like shooting outdoors in the rain. It’s also got a few features that are rarely used, like the ability to trigger the shutter on one camera with a Canon 600RT on it from a separate camera with a 600RT. The ID codes and such mentioned earlier only come into play if you have a lot of shooters around using the same flash. You can think of it like putting them on different channels to prevent interference.
| Latest registered member is semonsters 1503 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
