Anyone have any recommendations for a super sturdy monopod that can hold a slr + the weight of a 24-70 or 16-35 up fully extended upwards and at a 45 degree angle so i can shoot down on my subject from up high?
kaitanium Goldmember 3,967 posts Likes: 15 Joined Sep 2005 Location: San Francisco USA More info Post edited over 5 years ago by kaitanium. | May 29, 2018 13:25 | #1 Anyone have any recommendations for a super sturdy monopod that can hold a slr + the weight of a 24-70 or 16-35 up fully extended upwards and at a 45 degree angle so i can shoot down on my subject from up high?
bpalermini Goldmember More info | May 29, 2018 13:39 | #2 I like Induro monopods. Bob
gonzogolf dumb remark memorialized More info | May 29, 2018 14:03 | #3 Honestly Any monopod can handle that. Start with manfrotto and then compare from there.
kaitanium THREAD STARTER Goldmember 3,967 posts Likes: 15 Joined Sep 2005 Location: San Francisco USA More info Post edited over 5 years ago by kaitanium. (2 edits in all) | May 29, 2018 15:09 | #4 gonzogolf wrote in post #18635213 Honestly Any monopod can handle that. Start with manfrotto and then compare from there. i would definitely not say "any" monopod. When tilted down at an angle (would like to shoot max 45 degrees tilted), some of the carbon fiber ones start bending and or wobbling and although they dont break, they dont instill any confidence in me. Revised my post and added that tidbit to it for further clarification.
FL-Sean Member 130 posts Likes: 1657 Joined Nov 2017 More info | May 29, 2018 15:12 | #5 I've had my Sirui P224C for 6 months now,like it very much..90 bucks
May 29, 2018 17:37 | #6 I use my Gitzo GM2541 for lighter stuff but Gitzo mono pods are not cheap unless you do some research or buy used. Life is for living, cameras are to capture it (one day I will learn how!).
kaitanium THREAD STARTER Goldmember 3,967 posts Likes: 15 Joined Sep 2005 Location: San Francisco USA More info | May 29, 2018 22:10 | #7 First time ive heard of sirui stuff. ill have to take a look at them. thanks all
Nick5 Goldmember More info | Jun 02, 2018 09:05 | #8 For almost ten years now my go to Monopods were the Manfrotto 681B. Aluminum shaft with Lever Locks. Still working after all of these years. As I left the second monopod at our other location home three hours away, that was the excuse I needed to treat my self to a Carbon Fibre Monopod. So yesterday at our local shop they had the Induro CLM 304 L Monopod. Same height and stability as my old trusty Manfrotto's and less weight as well. Will use it for an all day Golf Outing on Wednesday. Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
daleg Senior Member More info Post edited over 5 years ago by daleg. (5 edits in all) | Jun 02, 2018 09:33 | #9 monopod - Gitzo CF GM5561T
daleg Senior Member More info Post edited over 5 years ago by daleg. (11 edits in all) | the Manfrotto 681B was my first monopod. I still like it and own it. depending on the head, it's not bad at all. one caveat: keep it away from sand - which will destroy the extension mechanisms. for lighter rigs, I used it with the discontinued Kirk MPA-1, which is literally the Manfrotto 234 head converted by Kirk for Arca-Swiss plates. Note that this head is only rated for circa 6 lbs. So, light loads only.
| Latest registered member is semonsters 1507 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
