Thread started 05 Jun 2018 (Tuesday) 14:28
Hit me with a Salami and Call me Nancy - Tonal Uniformity Question
PhotoJourno
High Plains Chimper
Post edited over 5 years ago by PhotoJourno.
Jun 05, 2018 14:28 |  #1
Hello friends,
Rather embarrassed to have to ask this question, though it only presented itself right now (not sure why not in years past) and I am trying to figure out the best way to proceed.
As I prepare a few galleries for my website (showcasing my past work as a journo), I am now seeing that the selection of images I have picked all seem to have rather different tones. Each photo -for the most part- looks good on its own, but when put together to create a somewhat seamless dynamic gallery, really shows the jumps in tone, temperatures, etc.
What process do you follow in PS or your workflow to make your finished product uniform when it comes to displaying it side by side? I haven't had this issue before, but it's really noticeable. I do recall a few steps involving a gray blending layer, luminosity, and being able to work with histograms in order to match photos, but was wondering if Photoshop for instance or the Interwebs have come up with a less time consuming way of approximating some photos to others.
*** EDIT: ADDED IMAGE ***
Here are some examples of the uniformity issues I am trying to mitigate, or attenuate. While photos from the same event were shot under similar conditions and do appear more alike, when I am creating an "Air Show" gallery, I'd like to be able to have the sky look somewhat similar, without ruining the photos.
(NOTE: I am sure some of this has to do with my substandard Photoshopping skills rather than anything else)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/06/1/LQ_916941.jpg
Image hosted by forum (916941) © PhotoJourno [SHARE LINK]
--Mario
"Sensa luce non si vede nessuna cosa"--Lorenzo Ghiberti
Wilt
Post edited over 5 years ago by Wilt.
Jun 05, 2018 14:49 |  #2
Nancy,
The only tone which can be truly uniform in appearance from shot to shot
a) requires that the same tone appears in all photos, and
b) is used as the basis for exposure measurement, and post processing
...the 18% gray midtone is the most commonly used 'reference' tonal area.
Differences between shots in the Contrast adjustment will affect tones. Difference in settings for Shadow or Highlight will affect tones.
If 18% gray is not inherently in a scene, you cannot truly expect 'uniformity' to exist in every shot.
Wilt
Jun 05, 2018 15:22 |  #3
One Macbeth card, shot under contrasty vs. less contrast lighting conditions, in 4 different kinds of light with different White Balance. All four shots processed to be less contrasty, normal contrast, and more contrasty in appearance
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/Principles/tonal%20differences_zpsl3qrzbn5.jpg
Only gray swatch #4 in bottom row has any degree of 'uniformity' regardless of lighting contrast vs. r postprocessing Contrast setting
OhLook
Gallery: 105 photos
Joined Dec 2012
Jun 05, 2018 15:26 |  #4
Nancy, the examples are missing.
Tones are expected to differ between a snow scene and a forest scene, between an air show and a football field, between . . . Examples of the images you want to juxtapose would help us respond.
PRONOUN ADVISORY: OhLook is a she. | Comments welcome
Progress toward a new forum being developed by POTN members:
https://photography-on-the.net …/showthread.php​?t=1531051
PhotoJourno
High Plains Chimper
Jun 05, 2018 15:40 as a reply to  @ OhLook's post |  #5
Thank you! I did add them just now, sorry about that. And thanks for calling me Nancy (I have this thing about Thread titles and email subjects that causes me to often choose rather "interesting" titles). :)
--Mario
Wilt
Jun 05, 2018 15:43 |  #6
Even if you ASSume that the sky is 'uniform' in tonality, in actuality it varies in brightness depending upon the angle relative to the sun position!
PhotoJourno
High Plains Chimper
Jun 05, 2018 16:08 as a reply to  @ Wilt's post |  #7
This is embarrassing indeed. And I thank you, as it does make perfect sense. I just couldn't get over those galleries I've been browsing where every photo appears to be shot under the same conditions, and displays ever so beautifully in a gallery.
At least it does bring me the consolation that what I am searching for, is not really 100% achievable in this context.
Thanks everyone for your comments. :)
--Mario
gewb
Gallery: 326 photos
Jun 05, 2018 16:11 |  #8
PhotoJourno wrote in post #18639815 (external link)
And thanks for calling me Nancy . :)
Beats being called Shirley. 8^)
90D / 60D / Pro1 / A85
Peano
Jun 05, 2018 17:23 |  #9
I selected each frame separately and opened a selective color adjustment layer for each. Then tweaked mainly blues and cyans, just eyeballing for uniformity. Not perfect matches, but much closer than the original.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/06/1/LQ_916956.jpg
Image hosted by forum (916956) © Peano [SHARE LINK]
Peano
RadiantPics.com (external link)
Wilt
Post edited over 5 years ago by Wilt. (4 edits in all)
Jun 05, 2018 17:26 |  #10
You CAN achieve somewhat 'uniform' sky tonality, but at the expense of 'adequate' exposure of your subject! You subject could be front lit vs. backlit, causing the subject relative brightness to change by 3EV in brightness even when the background sky is kept a uniform tonality.
Simple demonstration...the brightest direction of sky I established to be 0EV. As I aimed around the circle at different directions from the sun, the sky changed brightness by up to -2.2EV
I aimed at the palm of my hand, and the palm changed from 0EV to +3.2EV when measuring at the SAME angles to the sun~...the sky got darker while my palm got brighter, facing in the SAME DIRECTIONS around the circle.
If I opened up my aperture by 2.2EV to keep the sky a constant tonality, my skin would get brighter by 5.4EV (3.2EV lighting plus 2.2EV wider aperture) in the same compass direction!
BigAl007
Gallery: 556 photos
Jun 05, 2018 17:44 |  #11
I regularly shoot airshows, and as Wilt says it changes with both angle to the sun, and angle above the horizon, and that's just during a single pass! The sky can change a lot in the course of an afternoon, not forgetting that the sun also move across the sky at 15° per hour. Keeping any sort of consistent colour in the sky is nigh on impossible, unless the photographer is cheating and doctoring the sky in post to the point that they are just changing out the sky in most of the images.
Alan
Peano
Post edited over 5 years ago by Peano.
Jun 05, 2018 18:18 |  #12
Wilt wrote in post #18639874 (external link)
It's important in this case to distinguish luminosity from color. Look again at the sample images the OP posted. There are differences in luminosity for sure, but the most glaring differences are in color. Hue.* The main challenge is to make the hues more uniform; luminosity is secondary.
EDIT: *Hue and saturation.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/06/1/LQ_916962.jpg
Image hosted by forum (916962) © Peano [SHARE LINK]
Peano
PhotoJourno
High Plains Chimper
Jun 05, 2018 23:22 as a reply to  @ Peano's post |  #13
Wow, that does show me what a gap I need to close. Well, the sooner I know the better, right?
Thank you so much, I think for a decent looking gallery, it is important to show this type of uniformity.
Much appreciated!
--Mario
PhotoJourno
High Plains Chimper
Jun 05, 2018 23:23 as a reply to  @ Peano's post |  #14
Thanks for explaining it like thus. I see it and understand it clearly.
Cheers,
--Mario
kirkt
Jun 06, 2018 06:29 |  #15
The sky may indeed appear differently depending upon the elevation of the sky you are shooting, the sun, the weather, time of day. Think about grouping like images together (ie, images where the sky should appear the same) instead of trying to force legitimately different images to look uniform. If images where the sky should look the same show differences in the sky, then your camera settings or workflow needs some tweaking. Trying using a fixed white balance instead of auto, for example. At least the corrections you apply will lend themselves to batch processing rather than a potential for having to apply corrections on a per-image basis.
Kirk
Kirk
3,119 views & 8 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1449 guests, 131 members online
