Thread started 18 Jun 2018 (Monday) 00:46
light pollution filter for the 6dmkii?
kaitanium
Jun 18, 2018 00:46 |  #1
Does anyone know if one of these exists or what my next best option is? Wanting to do some milky way shots from the backyard in the middle of a city of course.
AZGeorge
Jul 19, 2018 13:02 |  #2
The only effective filter I know of is distance.
George
Democracy Dies in Darkness
gjl711
Jul 19, 2018 13:26 |  #3
There are actually several. Google "light pollution filter astronomy" and you'll get lots.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
kaitanium
Jul 19, 2018 13:41 |  #4
gjl711 wrote in post #18666050 (external link)
nope.
i should specify a but further. clip-in filters. Looks like astronomik is the only one however doesnt state if it works with the mk2
Celestron
Jul 19, 2018 22:33 |  #5
kaitanium wrote in post #18647130 (external link)
As mentioned the Astronomiks CLS for Canon is the filter uou need but here’s a link , you can call them and ask if it will fit your camera .
https://www.highpoints​cientific.com …n-eos-clip-filter-cls-eos (external link)
gjl711
Jul 19, 2018 22:36 |  #6
There site (external link) seems to indicate that it's for crop cameras given their list is all crop, but poking around a bit, some have said that it works in a 6D but vignettes around the corners.
::Gear::
Celestron
Jul 20, 2018 06:59 |  #7
gjl711 wrote in post #18666400 (external link)
If the clip in doesn’t work you can get lens filters however they are expensive .
https://www.astronomik​.com/en/ (external link)
gjl711
Jul 20, 2018 07:04 |  #8
Celestron wrote in post #18666590 (external link)
Poking around that site I found this (external link). Seems they have a FF filter after all.
::Gear::
kaitanium
Jul 20, 2018 10:35 |  #9
yes the clip filters dont work and are for apsc cameras.
the 6d one is the only one. ill have to ask if it fits or not.
TCampbell
Gallery: 13 photos
Joined Apr 2012
Post edited over 5 years ago by TCampbell.
Aug 02, 2018 12:09 as a reply to  @ kaitanium's post |  #10
Astronomik makes clip-in filters in sizes to fit either Canon APS-C or full-frame.
The "catch" is that if you use a Canon APS-C camera then you can't use "EF-S" lenses. The rear-most element of an EF-S lens slightly protrudes into the camera body and would hit the filter. You can use the APS-C version of the clip in filter if you use "EF" lenses (they don't have an element that protrudes into the camera interior like the EF-S lenses).
But honestly...
You REALLY want to get away from the light if you want Milky Way shots. These filters improve things, but they don't perform miracles.
The are broadband filters that block the sections of the spectrum mostly associated with the emission wavelengths of Mercury and Sodium lights. Until recently, was the most common source of light pollution. But now that cities are switching over to LED street lights... these filters aren't nearly as effective.
The other thing about the CLS filters is that they do NOT block the wavelengths associated with deep-sky emission nebulae such as Ha, Hb, OIII, & SII. But the Milky Way isn't an emission nebula... it's stars. And stars are black-body radiation sources (full-spectrum light) -- not narrowband objects. This means when you use a CLS filter, you're blocking quite a bit chunk of the light from the Milky Way itself.
For the best odds at a Milky Way shot... get away (well away) from urban light pollution and do this on a clear moonless night (e.g. check the calendar for the 'new moon' and pick a night near that) and don't use a filter.
kaitanium
Aug 03, 2018 00:16 |  #11
I think ive moved on from the filter idea. Bought myself a monocam and will use filters.
birderman
Joined Mar 2011
Jan 09, 2019 09:55 |  #12
If Clip in ones aren't suitable for your camera then you can try Nisi, they do screw in and Square mounted types - but of course these may be limited by the lens you are using
https://nisifilters.co​m.au …0mm-natural-night-filter/ (external link)
and Skytech also do Clip in filters similar to Astonomik
https://www.tringastro​.co.uk …llution-filters-140-c.asp (external link)
Birderman
London, UK
my photos on Flickr (external link)
My Website (external link) or my Facebook - KishWphotos (external link)
kaitanium
Jan 23, 2019 12:15 |  #13
I found a super cheap canon T3i and just using a clip in filter for that camera as its easier to find and compatibility is gauranteed. Plus it gives me an extra 1.6x boost in focal length.
birderman
Joined Mar 2011
Post edited over 4 years ago by birderman.
Jan 28, 2019 07:51 |  #14
kaitanium wrote in post #18797066 (external link)
Would love to see some shots with this setup, preferably with and without the filter ?
Living close to London,UK my skies are heavily polluted and having similar Camera would like to see how the LP filter performs.
Birderman
London, UK
kaitanium
Post edited over 4 years ago by kaitanium.
Jan 28, 2019 11:35 |  #15
people say minimal effect. i assume it will just allow me to do slightly longer subs and with slightly less gradients (the photoshop Gradient xTerminator plugin is a must have). i havent had a clear sky for months so i havent been able to go out with my new setup. I really got the T3i mostly for that extra 1.6x reach and the fact it is a lighter load on my mount
there is this guy https://www.astrobin.c​om/263253/H/?nc=user (external link) has done many excellent results with a dslr under rather high bortle skies. look through his gallery and see what hes got. very inspiring
6,270 views & 4 likes for this thread, 6 members have posted to it and it is followed by 3 members.
1504 guests, 136 members online
