Thread started 24 Jun 2018 (Sunday) 13:01
Gripe about photo papers--Why no reverse side imprints?
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jun 24, 2018 13:01 |  #1
Conventional wet-processed papers were easy to tell front side/ rear side. With non-plastic-coated papers, the emulsion side was clearly enough different that it could be discerned even under safelights.
When most paper was plastic-coated, manufacturers imprinted the rear side with branding.
Why can't that be done now? Why do I open a package of paper that costs $2.00 a sheet and all they can tell me is that it's packed in the box with the printable side of the paper face up?
Why can't they lightly imprint the back of the paper?
agedbriar
Jun 24, 2018 13:14 |  #2
Because then it would cost $2.25 a sheet?
Quint ­ on ­ Trask
Gallery: 21 photos
Joined Apr 2015
Jun 24, 2018 17:15 |  #3
Some papers are quite hard to tell which is the printable side. True about face up in the box. I had marked all 20 sheets with a light X with a pencil on the back corner. Helps.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jun 24, 2018 17:20 |  #4
agedbriar wrote in post #18650562 (external link)
$2.005 per sheet would be a better guesstimate.
I agree it is pretty silly. It used to be so obvious, even if their wasn't a printed mark there was an easy way to tell.
Hen3Ry
Jun 26, 2018 09:34 |  #5
To tell which side is printable, touch the tip of your finger to your tongue, then press on the paper and lift your finger. If the paper sticks to your finger, that's the printable side.
Je n'avais pas besoin de cette hypothèse-là.
RDKirk
Joined May 2004
Jun 28, 2018 07:37 |  #6
Hen3Ry wrote in post #18651636 (external link)
A. Doesn't always work, particularly on art papers...which is when it's most difficult to tell the difference in sides.
B. Likely to create a spot on the print
Hen3Ry
Jun 29, 2018 08:29 |  #7
RDKirk wrote in post #18652846 (external link)
Actually my experience is that it works very well with Epson Cold Press Bright. In fact, every time. ;)
1,770 views & 2 likes for this thread, 5 members have posted to it and it is followed by 3 members.
1451 guests, 128 members online
