Thread started 01 Jul 2018 (Sunday) 03:27
Godox 2x AD200 + AD-B2, or AD600 Pro?
crissoft
Jul 01, 2018 03:27 |  #1
Hello,
I already have 1 Godox AD200, TT685 and trigger.
For on-location shooting, for overpowering the sun, it is absolutely necessary AD600 Pro, or is sufficient 2xAD200 with AD-B2 head.
Please convince me to buy another AD200 with AD-B2, instead of AD600 Pro. :)
Thanks in advance :)
5Dc, 5D mark III, 24-70 f/2.8 VC, 70-200 f/2.8 VC, toki 10-17 FE, sig 35 1.4, 50 f/1.8 II, sig 70 macro, 85 f/1.8, ST-E3, 600 EX RT, 580EX II, 430 EX II, 2 x Elinchrom D-Lite 4 To Go, 4x Yongnuo 622C
a6000 + 16-50 OSS, 55-210 OSS, 50 1.8 OSS, sig 19, 30, 60
dmward
Gallery: 28 photos
Jul 01, 2018 09:20 |  #2
You'll need all the power you can afford for outside in the sun. the AD600 offers flexibility that's not available with 2 AD200s.
jlafferty
Joined Feb 2017
Jul 02, 2018 06:33 |  #3
But just barely though. The reasons you'd get the 600Pro versus the AD-B2 and two 200s aren't really about output power - they're color accuracy, shorter recycle times, better bulb & mount design. The AD-B2 is only maybe a third of a stop behind a single 600/600Pro.
The twin 200s is IMO more "flexible" - it can be run as two sources, key and fill, or one fairly powerful source. It's lighter, smaller and breaks down in a modular way. Plus the OP is already halfway there.
dmward wrote in post #18654456 (external link)
Current Portfolio (external link)
jlafferty
Joined Feb 2017
Jul 02, 2018 06:38 |  #4
TBH I'd say you should get both though ;)
Then you'll have a complete kit - two powerful sources, or a third when you need it.
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jul 02, 2018 10:14 |  #5
jlafferty wrote in post #18654939 (external link)
So with that in mind, the question is which way do you most often shoot?
If you normally use two lights and rarely need great power, then go with the two AD200s.
If you normally need high power and usually shoot with on light, go with the AD600. If you really need power--especially if you use HSS--you'll get much better use out of a flash that's designed to take such usage in stride, rather than a setup that will be constantly working at its limit.
RDKirk
Joined May 2004
Jul 02, 2018 10:14 |  #6
jlafferty wrote in post #18654941 (external link)
This, too.
dmward
Gallery: 28 photos
Jul 02, 2018 13:33 |  #7
RDKirk wrote in post #18655007 (external link)
This, too.
And the AD600 has a dual head accessory as well if you want to really get serious.
bobbyz
Jul 05, 2018 09:32 |  #8
Even though I have AD200, I use AD600 more. I like extension head option of the AD600 but now even AD200 offers that. AD600 is heavier so I need less sandbags. And for shooting in the sun, you do need power. I find AD600 even at full blast doesn't have enough juice.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
dmward
Gallery: 28 photos
Post edited 16 days ago by dmward.
Jul 05, 2018 22:08 |  #9
bobbyz wrote in post #18656754 (external link)
That's why I got the duel head for the 600. I use it with one pack and if there is a problem I can add the second pack quickly.
AD200 plus remote heads plus AD-B2 plus AD600 (X2) plus 1200 remote head provides range from 200Ws to 1200Ws with size, portability options. Naturally, one gets the same range of output from AD600 with 1200 head and power settings. :-)
422 views & 7 likes for this thread
Latest registered member is edwardo
473 guests, 383 members online
