Thread started 01 Jul 2018 (Sunday) 12:44
purchased the 100-400L II
drifter106
Joined Feb 2006
Jul 01, 2018 12:44 |  #1
just recently purchased this and have taken a few shots with it...very nice. MY concern is the foot. Now I will show my lack of knowledge but I would like to hear from those that use it. I want to mount this on a monopod but things don't match up accordingly. What do I need to get so my lens will mount on the monopod.
Would rather hear from you guys that use the lens instead of some sales person at this point.
thanks
john
have a 7dmark II and 5dmarkIII as cameras. Plan on using the 7dmark II with this lens and keeping the 70-200 f2.8 II or the 16-35f4 on the 5dmarkIII.
any advice would be greatly appreciated..
the 100-400 II...wow, what a lens! lol
Gear
Remember, what is common knowledge to some is a revelation to others.
For the sake of his sorrowful passion, have mercy on us and the whole world.
rndman
Gallery: 189 photos
Jul 01, 2018 12:49 |  #2
drifter106 wrote in post #18654538 (external link)
thanks
john
Please elaborate your issue. What do you mean by things don't match up? Is it the monopod screw size that is not matching?
Also instead of a separate thread, post your question on the already popular 100-400 thread. You will get more responses.
smugmug (external link)
John ­ from ­ PA
Joined May 2003
Jul 01, 2018 13:13 |  #3
https://www.dpreview.c​om/forums/thread/38056​81 (external link) probably some help.
Choderboy
I like a long knob
Gallery: 185 photos
Jul 01, 2018 15:28 |  #4
I don't understand the "don't match up" either.
The foot has a socket. Monopods have a screw. Socket + screw = match.
100-400 II Replacement Foot (3 models)
https://photography-on-the.net …/showthread.php​?t=1426176
Recent update in that thread details the 4th model foot now available.
Dave
Image editing OK
mcoren
Beware the title fairies!
Gallery: 192 photos
Joined Mar 2015
Jul 01, 2018 16:23 |  #5
Does the monopod require its own head? Heads attach with a 3/8” screw thread, then the head (or mounting plate on the head) provides a 1/4” screw thread to attach the camera or lens foot.
For example: https://www.bhphotovid​eo.com …Swivel_Tilt_Hea​d_for.html (external link)
Mike
Canon EOS R7, M5, 100 (film), and Sony α6400
I have an orange cat and a brown cat. In HSL, they're both orange.
rndman
Gallery: 189 photos
Jul 01, 2018 16:53 |  #6
mcoren wrote in post #18654644 (external link)
Mike
Which monopod is this that has 3/8" screw?
drifter106
Joined Feb 2006
Post edited over 5 years ago by drifter106.
Jul 01, 2018 17:57 |  #7
monopod screw is to big for the canon foot...
answered by own question, need to get a monopod that has the same diameter screw hole (thread) as the foot. duh!
Gear
johnf3f
Jul 01, 2018 18:03 as a reply to  @ drifter106's post |  #8
Most mono pods allow you to reverse the screw on the top to change from 3/8 to 1/4 inch threads.
Which mono pod are you using?
Life is for living, cameras are to capture it (one day I will learn how!).
drifter106
Joined Feb 2006
Post edited over 5 years ago by drifter106. (2 edits in all)
Jul 01, 2018 19:59 |  #9
Induro cm24
Gear
drifter106
Joined Feb 2006
Jul 01, 2018 20:50 |  #10
Choderboy wrote in post #18654620 (external link)
same size socket + same size screw = match
thanks for the link.....
Gear
mcoren
Gallery: 192 photos
Joined Mar 2015
Jul 01, 2018 21:54 |  #11
drifter106 wrote in post #18654738 (external link)
Induro cm24
The specs on that particular monopod say it has both 1/4” and 3/8” threads. As johnf3f said, the screw can probably be removed and reversed.
Mike
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jul 02, 2018 01:16 |  #12
The first thing I do with any new lens that I buy is to mount a long speed plate onto the foot. . That way I can use it with either my gimbal heads or my ball head. . Once I get a lens, a speed plate gets screwed onto it and it never comes off, ever.
RPCrowe
Joined Nov 2005
Jul 02, 2018 10:43 |  #13
I switched from the crappy Canon OEM foot to a Kirk Industries aftermarket foot. Canon often drops the ball in small ways with some of their excellent products. The foot of the 100-400mm f/4.5-5.6L II lens is just one of these drops.
1. The bottom edges of the foot are beveled rather than completely flat so it doesn't have a steady grip on any mounting surface.
2. The foot doesn't have Arca Compatible grooves.
The Kirk foot solves these problems.
BTW: I strongly suggest that anyone working with a tripod, especially when long lenses are involved, use a head with an Arca compatible clamp.
IMO - after dropping a small fortune on this lens, I should not have needed to spend another batch of bucks to convert the foot into a usable configuration... But, such is life when you are living with Canon gear!
chris001
Gallery: 374 photos
Joined Dec 2014
Jul 23, 2018 07:36 |  #14
RPCrowe wrote in post #18655017 (external link)
I'm not a pro, but the other night I was using my 100-400L II to take some skyline pictures and when switching lenses I had to switch mounts and in the dark is it a PITA. I ordered the Kirk replacement foot yesterday just for the Arca mount capability.
Thanks!
Chris
saea501
... spilled over a little on the panties
Gallery: 43 photos
Jul 23, 2018 09:05 |  #15
I've never seen any tri or monopod that didn't use a 1/4-20 screw.
And I would disagree with the comment above about the Canon foot being 'crappy'. Mine surely isn't.
........but then I got the only Canon 6D that can focus on moving subjects too......so I must be a really lucky guy. :rolleyes:
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
5,405 views & 14 likes for this thread, 13 members have posted to it and it is followed by 6 members.
1503 guests, 127 members online
