Thread started 07 Jul 2018 (Saturday) 21:26
Softboxm umbrella, octabox comparative sizes....
RPCrowe
Joined Nov 2005
Jul 07, 2018 21:26 |  #1
When comparing sizes of octaboxes or umbrellas. It is easy to determine that (given the same distance from modifier to subject) a larger unit will produce a softer light than the smaller unit. In other words, a 45 inch octabox will produce a softer light than a 32 inch or 24 inch octabox.
However, does this hold true for softboxes?
I realize that a 45 inch by 45 inch softbox will produce a softer light than a 24 x 24 inch softbox. However, in general use, would a 24 x 36 inch softbox produce a softer light than a 24 x 25 inch model. Or will it just produce the equivalent softness over a greater area?
dmward
Gallery: 28 photos
Jul 08, 2018 07:50 |  #2
RPCrowe wrote in post #18658236 (external link)
distance of diffused light source from subject determines the amount of light that can be "wrapped" around the subject to soften and widen transition zone from highlight to shadow. So, at same distance bigger will result in more wrap. That is one reason I like big, and feathering, which is a way to control where the light strikes the subject. Grid on the modifier will also help with control.
Wilt
Post edited 2 months ago by Wilt.
Jul 08, 2018 09:51 |  #3
Ignoring the scatter of uncontrolled light reflecting off walls and ceiling etc. a 36" umbrella is just as soft a source as a 36x36" softbox or a 36" Octobox or a 36"x36" white reflector panel...only the reflected catchlights vary in appearance
dpe
Joined Jan 2017
Jul 09, 2018 02:45 |  #4
I was always told to look at the diagonal measurement, so theoretically it is softer
mike
UK based photographer specialising in equestrian but also doing things like Prom Photography (external link)
Left ­ Handed ­ Brisket
That's my line!
Gallery: 10 photos
Joined Jun 2011
Post edited 2 months ago by Left Handed Brisket. (2 edits in all)
Jul 09, 2018 08:26 |  #5
Yes size is relevant to subject distance, but it is also relative to orientation of subject and light.
Take it to an extreme and consider a strip box or long rectangle. The light provided with a 90 degree rotation would be vastly different ((tall vs wide).
So corner to corner measure is only relative to objects and shadows cast along that plane. Same for edge to edge width. In reality however, I doubt you'd see much difference with area and all other things being equal ... which is pretty much impossible.
Wilt
Jul 09, 2018 12:45 |  #6
dpe wrote in post #18658961 (external link)
mike
Academic debate. Consider that a long narrow light source is only like a 'large source' in one dimension only, and is a 'small source' in the other dimension. That contradicts the diagonal measure, does it not?!
366 views & 1 like for this thread
Latest registered member is Packman12355
844 guests, 418 members online
