Thread started 09 Jul 2018 (Monday) 16:57
Just discovered that my Sekonic L478D will not wirelessly trigger monolight
southwestform
Joined Sep 2014
Jul 09, 2018 16:57 |  #1
I am using a single monolight with a PocketWizard and another PocketWizard attached to my 5dm3. I now want to use my Sekonic L478D to wirelessly trigger my light when taking a reading, though it seems that my meter does not do this and I need a Sekonic L478DR?
Do I have any options with my current meter? Do I need to use a synch cable if I want to get a reading with my monolight?
Thanks.
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Post edited over 5 years ago by ThreeHounds.
Jul 09, 2018 17:05 |  #2
I bought my 478D before the DR (radio) version was released... I just remove my transmitter from the hot shoe of the camera and carry it with me to trigger the flash to get the meter reading, then just slide it back into the hot shoe.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
southwestform
Joined Sep 2014
Jul 09, 2018 17:49 as a reply to  @ ThreeHounds's post |  #3
Sorry for having to ask this, though how do you use the transmitter from the hot shoe of the camera to trigger the flash?
Thanks.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jul 09, 2018 17:54 |  #4
"Test" button?
southwestform
Joined Sep 2014
Jul 09, 2018 19:25 as a reply to  @ Left Handed Brisket's post |  #5
I was confused by how to get the transmitter to talk to the meter, though I just plugged the cable in and that worked, so I'm guessing that is how it needs to be done?
ImageMaker...
looks like I picked a bad week to give up halucinagens
Gallery: 218 photos
Joined Dec 2015
Post edited over 5 years ago by ImageMaker....
Jul 09, 2018 19:51 |  #6
southwestform wrote in post #18659503 (external link)
It will not talk to the meter.
Set the meter to read the flash. Hit the test button on the transmitter. The meter will read the flash.
Cable is another way.
Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
Gallery: 15 photos
Joined Jun 2011
Post edited over 5 years ago by Left Handed Brisket. (2 edits in all)
Jul 09, 2018 19:58 |  #7
I don't have your specific set up, but the meter does not need to be timed to the strobe like a camera would. Just reset the meter and then click the test button.
I don't worry about making a corded connection between meter and trigger (I don't think I can even do that) and even keep an extra trigger so I can meter and adjust lights without having to be behind the camera.
southwestform
Joined Sep 2014
Jul 09, 2018 22:21 as a reply to  @ ImageMaker...'s post |  #8
How do you get the meter to read the flash? I'm guesing that you do not mean the meter will automatically take a reading when I press test since the meter is not wireless.
Thanks.
ImageMaker...
Gallery: 218 photos
Joined Dec 2015
Jul 09, 2018 22:40 |  #9
southwestform wrote in post #18659609 (external link)
Thanks.
Two different buttons so yep. Set the meter to read flash and hit the test button n the transmitter.
I’d go online and download the manual from Sekonic.
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Jul 09, 2018 22:43 as a reply to  @ southwestform's post |  #10
In the mode panel on the meter. choose the flash icon without the "C" (that means corded). Press the read button and the meter waits for the flash pop. Pop the flash with the test button on the transmitter and you get your reading.
I think it has a 60 or 90 second timer on the read mode so you can take a reading, adjust power level if necessary, and repop. Rinse and repeat as necessary.
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Jul 09, 2018 22:47 |  #11
It's on pg 25-26 of the manual.
1,313 views & 7 likes for this thread, 4 members have posted to it and it is followed by 2 members.
559 guests, 142 members online
