Thread started 12 Jul 2018 (Thursday) 16:28
dual monitor contrast and brightness settings
ncjohn
Jul 12, 2018 16:28 |  #1
To me, setting the brightness and contrast of the monitor is the hardest part of calibration. I've had several of those images that say something like, "set the contrast so square x is as close as possible to square y, and set the brightness so square a is as close as possible to square b". and I use them. But even when they look perfect (as possible) on both monitors, the monitors don't look anything like each other. I'm not talking about color; even when the color seems to match on the monitors, the contrast and brightness never look really close.
Since the brightness and contrast seem to affect the calibration, I'd like to know how other people decide on how to set them before calibrating.
I'm using an Asus PB238q and a Viewsonic VP2365WB.
SkedAddled
Gallery: 16 photos
Jul 12, 2018 17:44 |  #2
I've had a similar situation with a pair of Dell UltraSharp monitors,
so I'll be interested to find out what turns up with this.
I can't even seem to get the color temperature quite the same.
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
John ­ from ­ PA
Joined May 2003
Jul 12, 2018 18:44 |  #3
ncjohn wrote in post #18661428 (external link)
My Viewsonic had an "Eco" mode enabled out of the box that I had to disable to get repeatable results. Go to http://www.tftcentral.​co.uk …ws/viewsonic_vp​2365wb.htm (external link) and scroll down for some related input.
ncjohn
Jul 12, 2018 19:33 |  #4
John from PA wrote in post #18661479 (external link)
No, not doing eco mode. But thanks. (Eco mode is kind of like "Just how bad do you want your monitor to look?")
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 13, 2018 03:21 |  #5
Two different panels, from two different manufacturers, each with different back light technologies, dynamic contrast and refresh rates.
It doesn't matter what you do, they will never match.
You might get them close with a calibration device that supports multiple monitors, but not even that will be able to make them match.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
losangelino
Gallery: 76 photos
Joined Jul 2012
Jul 13, 2018 08:58 as a reply to  @ Moppie's post |  #6
I think you will need two separate video cards, which you would then connect each monitor to a separate one before you can calibrate each monitor differently with software. Otherwise, with a calibration tool, the tool sets a profile and both monitors are affected.
IG: @lensesandwheels (external link)cars | @photomagicology (external link) portraits
website: ClothesAndDagger.com (external link)
ncjohn
Post edited over 5 years ago by ncjohn.
Jul 13, 2018 10:53 |  #7
Are there calibration devices that set brightness and contrast?
I use the puck from a Spyder 3 with DisplayCal. DisplayCal works with multiple monitors but I don't think it addresses brightness and contrast. (I have a hard time with the instructions so I could be wrong.)
The color is definitely close enough but I think the Viewsonic has less inherent contrast and it's frustrated me for a while now. So I just thought I'd see how other people set their brightness and contrast before calibrating.
1,080 views & 0 likes for this thread, 5 members have posted to it and it is followed by 3 members.
1057 guests, 103 members online
