Thread started 14 Jul 2018 (Saturday) 16:28
Went full frame and now my Sigma DC 17-50 f/2.8 isn't compatible.
ready ­ to ­ snap
Joined Jan 2014
Jul 14, 2018 16:28 |  #1
I just went full frame last week and today getting ready to head out to a shoot and I realized my Sigma DC 17-50 isn't compatible with my 5dmkii. Good thing I still have my old 60D so I can still do the shoot. Is there an adapter I can get or what lens should I replace it with? Thanks!!
Wilt
Jul 14, 2018 16:36 |  #2
I presume you shot at 17mm and discovered image cutoff due to a too-small image circle to cover the 24mm x 36mm frame dimension?
(and not an issue of mechanical interference with the reflex mirror)
ready ­ to ­ snap
Joined Jan 2014
Jul 14, 2018 16:38 as a reply to  @ Wilt's post |  #3
There was no interference with the mirror but bad vignette at all lengths.
Marm ­ O. ­ Set
Joined Dec 2011
Jul 14, 2018 16:40 |  #4
Did you like the field of view range that the 17-50 gave you? Did you find yourself wishing it were a little bit wider or a little bit longer?
still shooting but mostly different film formats
Wilt
Post edited over 5 years ago by Wilt. (2 edits in all)
Jul 14, 2018 16:43 |  #5
APS-C 17mm = FF 28mm
APS-C 50mm = FF 80mm
So 'same FOV' for FF as 17-50mm on APS-C simply means finding a 28-80mm f/2.8 lens
Better than adding lens elements to 'adjust' FL by introducing more contrast-losing optics into the optical design.
ready ­ to ­ snap
Joined Jan 2014
Jul 14, 2018 19:06 |  #6
I was happy with the 17-50 but a little wider wouldn't be a problem. I was thinking about trying out the Canon 17-55 f/2.8
Wilt
Jul 14, 2018 19:16 |  #7
ready to snap wrote in post #18662830 (external link)
The Canon 17-55mm is an EFS lens, and will not fit the EF mount of your FF camera, and its smaller image circle will mimic the Sigma 17-55mm on FF!
If you want wider FOV on FF compared to your APS-C 17mm, you want wider than 28mm, the most common FL wider is 24mm.
So you might want to consider Canon 24mm - 70mm f/2.8 lens (but this is a pricey alternative!), or 24-70mm f/2.8 Sigma or Tamron
Marm ­ O. ­ Set
Joined Dec 2011
Post edited over 5 years ago by Marm O. Set.
Jul 14, 2018 19:17 as a reply to  @ ready to snap's post |  #8
The 17-55 will not physically mount to the 5D mark II. The 17-55 is only for crop sensor cameras and the 5D series are all full frame cameras.
the 17-50 on a crop sensor is the equivalent to 28-80 on full frame. The best equivalent for your full frame camera will be a 24-70. There are several to choose from and most of them are great. This will get you slightly wider field of view than your 17-50 on the crop sensor.
John ­ from ­ PA
Joined May 2003
Jul 14, 2018 19:17 |  #9
The Sigma 24-70 DG OD HSM Art should be considered. A bit pricy at $1300 list but the refurb is available at $969. See https://www.sigmaphoto​.com …8-dg-os-hsm-a-refurbished (external link).
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jul 14, 2018 19:17 |  #10
EF-S lenses are made for crop cameras.
You need an EF lens
Maybe the Canon 24-105 or 24-70 would get you started.
Wilt
Jul 14, 2018 19:33 |  #11
24mm is considerably wider than 28mm on FF body!!!
On APS-C, having 24mm on FF is like using 15mm lens on APS-C
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jul 14, 2018 23:48 |  #12
I think the OP has a Sigma 17-50 which has an EF mount. The image circle is designed for a crop sensor and the vignetting will be there. I can mount my Sigma 8-16 on my 5D3 with no mirror interference, but only at 16 mm there is no vignetting
Gerry
John ­ from ­ PA
Joined May 2003
Jul 15, 2018 05:59 |  #13
MakisM1 wrote in post #18662974 (external link)
EF or EF-S confusing! The best description is that from wiki where it is stated "The Canon EF-S lens mount is a derivative of the EF lens mount created for a subset of Canon digital single-lens reflex cameras with APS-C sized image sensors."
In the Sigma line a DG designation is comparable to EF and the DC designation is comparable to the EF-S. Specifically the OP has the Sigma 17-50mm f/2.8 EX DC OS HSM FLD. Physically it may mount, but for the reasons you outline may yield undesirable artifacts in the final image.
Choderboy
I like a long knob
Gallery: 185 photos
Post edited over 5 years ago by Choderboy. (5 edits in all)
Jul 15, 2018 06:42 |  #14
Crop refers to 1.5 or 1.6 (APS-C), not 1.3 (APS-H)
Designations used:
Sigma.....Crop: DC...........Full frame: DG
Canon.....Crop: EF-S.......Full frame: EF
Tamron...Crop: Di-II.........Full frame: Di (and Di-III for mirrorless)
Tokina.....Crop: DX..........Full frame: FX
So a few lenses to consider:
Canon EF 24-70 2.8
Canon EF 24-70 2.8 II
Canon EF 24-70 f4 IS
Canon EF24-105 f4 IS
Canon EF 24-105 f4 IS II
Tamron SP 24-70mm f/2.8 Di VC USD
Tamron SP 24-70mm f/2.8 Di VC USD G2
Tamron SP AF 28-75mm F/2.8 XR Di LD
Sigma 24-70mm f/2.8 DG OS HSM Art
Sigma 24-70mm f/2.8 IF EX DG HSM
Sigma ART 24-105mm F/4 DG OS HSM
Dave
Image editing OK
ready ­ to ­ snap
Joined Jan 2014
Post edited over 5 years ago by ready to snap.
Jul 15, 2018 08:01 |  #15
Thanks everyone for the informative replies. What budget wise Lens would be a good companion with my 70-200 f/2.8? Most of my work is portrait and I do not mind buying used.
15,057 views & 0 likes for this thread, 10 members have posted to it and it is followed by 3 members.
1332 guests, 117 members online
