Thread started 16 Jul 2018 (Monday) 01:41
Volleyball. First time ever with a dslr.
braban11
Joined Jun 2018
Jul 16, 2018 01:41 |  #1
My first time ever using a dslr. Nikon d3400 with kit lenses. Tried shooting without settings at first, but ended up shooting in sports mode.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/07/3/LQ_922900.jpg
Image hosted by forum (922900) © braban11 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/07/3/LQ_922901.jpg
Image hosted by forum (922901) © braban11 [SHARE LINK]
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Jul 16, 2018 03:00 |  #2
I would shoot Manual mode with auto ISO.  :p
Canon R3 | RP | 7D2+grip | EF 70-200mm f/2,8L IS II | EF 135mm f/2L | EF 50mm f/1,2L | RF 100mm f/2,8L | Tamron 24-70mm f/2,8 VC G2 | Tamron 17-35mm f/2,8-4 Di OSD | ZE 2/100mm | ZF 2/35mm | ZF 1,4/85mm | ZF 2/135mm | CV 1,4/58mm Nokton | Micro-Nikkor 60mm f/2,8D | DC-Nikkor 105mm f/2D | Micro-Nikkor 200mm f/4D |
Speedlite 430EX III-RT | 600EX-RT |
Manfrotto BeFree Travel | MT055XPRO3 |
Zivnuska
Gallery: 72 photos
Jul 16, 2018 05:04 |  #3
Welcome! You're in the right place. You've done a good job for your first time with a dslr. Your timing is excellent and you've captured good action. Well done.
As you continue to shoot volleyball, there are some things you will want to know. I've compiled my list of those ideas at this site:
http://zivnuska.zenfol​io.com/blog (external link)
Give it a try. I believe that you will find some good techniques there.
Phil Zivnuska
www.zivnuska.zenfolio.​com/blog (external link) = My Blog
www.zivnuska.zenfolio.​com (external link)
"It's not tight until you see the color of the irides."
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 16, 2018 07:39 |  #4
Ah-keong wrote in post #18663777 (external link)
That's just another auto mode. It's not as if the light at the net is changing, is it? But white shirts vs dark shirts will result in different exposures.
Manual by itself gives the best results & makes post production much easier. My experience & some links: Some Volley Ball Tournament Tests **56K Warning!**
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Jul 16, 2018 21:58 |  #5
PhotosGuy wrote in post #18663841 (external link)
true also. for me, depending on the ambient exposure and the lights positioning. different frames would expose differently, I would then adjust the exposure compensation accordingly based on the exposure of the different frames.  :p
Noitca
Gallery: 73 photos
Jul 17, 2018 10:29 |  #6
I know you said it in jest.. but in some of the gyms my son has played basketball in... YES! :)
T1i with 18-55, 55-250, 50 1.8
CheleA
Joined Jul 2014
Jul 17, 2018 16:59 |  #7
What he said, almost:) I am very partial to ETTR(Expose To The Right) in manual mode. Just expose for the bright colors(white) and everything else will fall into place. Manual mode and RAW make post-processing a breeze.
PhotosGuy
Joined Feb 2004
Jul 17, 2018 21:13 |  #8
CheleA wrote in post #18664842 (external link)
The Ref's white shirt works well for that! ; )
mike_d
Jul 17, 2018 23:26 |  #9
Noitca wrote in post #18664609 (external link)
I've experienced that. Crappy old lights cycling in intensity, color temp, and tint make for some post processing work to even things out.
Noitca
Gallery: 73 photos
Jul 18, 2018 06:30 as a reply to  @ mike_d's post |  #10
Yep, sometimes post is the only way to fix it.
One gym my son plays in, there are lights out around in some areas. Lights on in others. Windows up high on the walls so day games there is a bright sunny spot on the court. So following across the 1/2 court you can easily go from close to properly exposed, to a stop or more under to just completely blown out.
Zivnuska
Gallery: 72 photos
Jul 18, 2018 08:47 |  #11
My first tip is one that is applicable to all of sports photography: Shoot tight, crop tighter. Players not involved in the action are merely observers. Crop them out to the extent possible. In this case, the people at and behind the scorer's table don't add anything to the image. Consider shooting in the portrait orientation for this shot of the setter.
Phil
braban11
Joined Jun 2018
Jul 19, 2018 00:15 as a reply to  @ Zivnuska's post |  #12
so crop out the hitter and blur the scores and misc people behind her? These are just as they were taken off the camera. What editing software is the easiest to use?
braban11
Joined Jun 2018
Jul 19, 2018 00:17 as a reply to  @ Zivnuska's post |  #13
I will check it out. High school season is coming so ill be able to get a higher perspective in most gyms.
braban11
Joined Jun 2018
Jul 19, 2018 00:18 as a reply to  @ PhotosGuy's post |  #14
It just seemed when i was in manual the shots were way to dark and too blurry. Im sure that alot of that has to do with the kit lens not being fast tenough
mike_d
Jul 19, 2018 00:24 |  #15
braban11 wrote in post #18665725 (external link)
Yeah kit lenses will usually kill you for indoor sports. I use a 70-200 f2.8 and wouldn't want anything slower. You images don't show exif data. What aperture, speed, ISO were these shot at?
In manual mode, the camera does just what you tell it to. If they were dark and blurry, its because you underexposed and chose too slow of a shutter speed. I've never shot volleyball, but I have shot little kids basketball and soccer indoors. I don't go below 1/500' and even that doesn't 100% freeze action. You'll probably want to be closer to 1/1000' with high schoolers unless you want to show motion blur on the extremities.
4,066 views & 10 likes for this thread, 9 members have posted to it and it is followed by 5 members.
544 guests, 154 members online
