Thread started 20 Jul 2018 (Friday) 07:32
Godox AD200 barebulb life
jwilson
Jul 20, 2018 07:32 |  #1
Purchased a Godox AD200 last summer, mostly used the Fresnel lens...was using the barebulb attachment last night in a softbox and it died on me...probably have less than 500 pops with the barebulb. Never been dropped, never been overheated...is this common or did I just draw a bad bulb?
dpe
Joined Jan 2017
Jul 20, 2018 08:55 |  #2
jwilson wrote in post #18666617 (external link)
I have done 500 in an evening on many occasions so maybe put this one down to bad luck
Mike
UK based photographer specialising in equestrian but also doing things like Prom Photography (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jul 20, 2018 09:58 |  #3
First, make sure you don't have the accessory knob tightened down on the bulb itself.
Second...yeah, I have heard a number of complaints about the life of the bulb.
I have two, and after hundreds of flashes, I haven't had a problem with either.
I'd like to think it was a bad batch.
simonbarker
Post edited over 2 years ago by simonbarker.
Jul 20, 2018 14:40 |  #4
No for casual use I'd expect years out of a flash tube. While the AD200 hardly has the most heavy duty tube going there should be a lot more complaints if they were dying that quickly.
Most likely you have a faulty piece of equipment, tubes are not super complicated things though, are you sure it doesn't have a crack somewhere?
Phil ­ V
Joined Jan 2005
Jul 23, 2018 14:01 |  #5
RDKirk wrote in post #18666677 (external link)
I agree with the first points, but a lifetime in engineering and the tech support leads me to believe its user error that causes the failures.
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
mihaikolf
Joined Apr 2012
Post edited over 1 year ago by mihaikolf.
Jul 25, 2018 04:07 |  #6
My ad200's bulb stopped working after 30 pops. All it does when pressing the button is a clicking noise and a little spark in the bulb. The fresnel head works fine. Is there a fix ?
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Jul 25, 2018 05:43 as a reply to  @ mihaikolf's post |  #7
That sounds familiar.
https://www.dpreview.c​om/forums/thread/42550​84 (external link)
For Sale: Sigma USB Dock
mihaikolf
Joined Apr 2012
Jul 26, 2018 03:30 |  #8
I took it back today and the verdict was that the bulb died. They replaced it and I also bought a spare one for backup.. so yeah the life span is really short or it was just bad luck
2,243 views & 2 likes for this thread
Latest registered member is RonWatson
876 guests, 250 members online
