Thread started 21 Mar 2006 (Tuesday) 08:52
POLL: "What do you think - Does the G series have a mechanical shutter or not?"
NO! Only DSLRs have a mechanical shutter. Digicams start and end readout from the sensor...
7
41.2%
YES! Like any other camera, the G series does have a mechanical shutter!
10
58.8%
17 voters, 17 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
Andy_T
Joined Jan 2003
Mar 21, 2006 08:52 |  #1
So ... continued from this thread:
Some people here believe that the G series does have a mechanical shutter in front of the sensor, others think that only DSLRs do have such an assembly.
Some of the arguments used by both camps ...
'No shutter' fraction:
- It wouldn't have life preview then
- it doesn't make a noise when set to 'silent'
'Mechanical shutter' fractions:
- Yes, it does make a tiny noise when taking an image
- How should long time noise reduction work then?
so ... what do you think?
I make it an open poll...
... and sorry if I have wasted your time :lol:
Hopefully Mr. Canon will step in at some time in order to resolve the issue without doubt...
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Terrywoodenpic
Mar 21, 2006 10:43 |  #2
Yes it does
Read the manual page 193
Mechanical + electronic shutter
Don't ask me how Probably is normally open, Closes, opens to take picture closes, opens again to view... like the Hasselblad. that would be why normal flash is limited to 250th second.
Terry
Terry_______________
Over 60 years in photography
wasted money cameras never on film.
Andy_T
Joined Jan 2003
Mar 21, 2006 11:00 |  #3
Very interesting.
Thanks for stepping in so fast, Mr. Canon :D
Although you do spoil my nice poll...
Now the only thing to explain is how live preview works...
Best regards,
Andy
dbump
Joined Apr 2003
Mar 21, 2006 12:50 |  #4
Love the poll!
So, re: live preview, why wouldn't the camera just hold the shutter open at any time the live preview was enabled? Am I missing something about how sensors work, and how they switch from constant reading for preview to reading for a picture? I thought it'd just be as simple as simultaneously closing the shutter and adjusting the aperture, then opening and closing the shutter for the correct duration, and once done, opening it back up again for preview?
Hmm. Now I'll have to count clicks when I get home.
7D, G10, 17-55 f/2.8 IS, 70-200 f/2.8 IS, 100 Macro, 50 f/1.4, 430EX II
There are no wrong notes
--Thelonious Monk
Andy_T
Joined Jan 2003
Mar 21, 2006 13:17 |  #5
I assume the shutter is always open ... until you take the image. And then you have to wait for 3 seconds until the image is written to the CF card, anyway.
Best regards,
Andy
superkully
Mar 21, 2006 13:21 as a reply to  @ Andy_T's post |  #6
It does, if you take a picture of your face you'll see it opening and closing.
You can also hear it closing when you switch off live-preview and, of course, when you take a photo.
And I'm not talking about the extra sounds you can programme in either.
magicmikey
Mar 21, 2006 13:37 |  #7
To confirm what others have said, here's what I found on a website:
"In traditional cameras the shutter is a mechanical arrangement using a few metal slats, which can be opened as a hole in the objective. The hole is shut while there is no photographing so that no light at all can force its way into the film. When an image is taken, the slats flick quickly to the side and back again. In this short space of time, while there is light in the objective, the film is exposed.
"We also find a shutter function in digital cameras, although it doesn’t work in quite the same way. There is normally a constant “hole” in the objective, so that the image sensor is exposed all the time. If this wasn’t the case then we wouldn’t be able to see the subject on the LCD screen. It continuously receives signals from the image sensor so that we can see the subject through the lens (TTL).
"In small ordinary digital cameras a mechanical shutter does not, in fact, regulate exposure time. The image sensor does this by itself; it can be programmed to gather light for a certain period. There is quite a lot of flexibility here, for example, many cameras work with a stepless variable shutter speed such as 1/148 sekund.
"The shutter speed can be 1/10.000 second, when an image sensor controls the time. Few mechanical shutters can work as fast.
"It is first when the exposure is complete that the mechanical shutter closes. Then the image sensor can discharge its data in the dark. A shutter closes too, by the way, if the LCD screen is shut down, and when the camera is turned off."
dbump
Joined Apr 2003
Mar 21, 2006 13:54 |  #8
Great info, MM!
I'm trying to imagine what I'd use a 1/10,000 exposure for. Yow.
--Thelonious Monk
andrewaaa5
Joined Sep 2004
Mar 21, 2006 14:55 as a reply to  @ superkully's post |  #9
what if i dont have a face? :(
first thing that springs to my mind would be some guy welding metal. That flame is SUPER bright!
andrew crighton
website -- > www.butterpeanut.com (external link)
flickr -- > flickr/photos/andrewaa​a5 (external link)
dbump
Joined Apr 2003
Mar 21, 2006 15:12 |  #10
Having just done some welding (edit: TIG, not gas torch), and being told that I need to wear long sleeves so as not to get instant sunburn, I don't think I want to expose my sensor to that kind of light for even that short a duration. You've probably seen the classic sensor burn example, of the guy with a nikon who did a time lapse of sunset, and now has a permanent black arc on all his images?
--Thelonious Monk
andrewaaa5
Joined Sep 2004
Mar 22, 2006 02:36 as a reply to  @ dbump's post |  #11
nope : ( I have not seen this. I never knew sensors could be burnt in such a way. I have not heard that before. I best be careful, as I like to take shots of the sun. I always use the ND filter, or more recently, a series of grad filters, hmm.. I wonder if I am still damaging my sensor :(...
andrew crighton
superkully
Mar 22, 2006 05:35 as a reply to  @ andrewaaa5's post |  #12
Sorry dude, I wasn't thinking about the facially deficent amongst us. What I meant was take a photo of your eyes...
If you don't have eyes either, well, you must be photography's Beethoven.
dbump
Joined Apr 2003
Mar 22, 2006 08:04 as a reply to  @ superkully's post |  #13
Here's the link:
http://www.philohome.c​om/skyshooter/burning_​ccd.htm (external link)
It does require extended exposure, but good to be careful about extreme light sources.
--Thelonious Monk
andrewaaa5
Joined Sep 2004
Mar 22, 2006 11:21 as a reply to  @ dbump's post |  #14
dbump wrote:
Here's the link:
ok, gotcha. thanks for sharing. i am presuming the fella (or lady..) had the live preview mode on for the duration of the snapping thus exposing the CCD all the time.
andrew crighton
dbump
Joined Apr 2003
Mar 22, 2006 11:33 |  #15
I assume so too. A normal exposure of the sun certainly isn't damaging.
--Thelonious Monk
3,969 views & 0 likes for this thread, 7 members have posted to it.
1506 guests, 129 members online
