Thread started 13 Aug 2018 (Monday) 16:26
Flash master/slave issue?
reefvilla
Gallery: 44 photos
Post edited over 5 years ago by reefvilla. (3 edits in all)
Aug 13, 2018 16:26 |  #1
I have a 600EXii-RT, a 430 EXiii-RT, and a 270EXii. Using a 6Dii body set on First-curtain synchro.
The 600 and the 430 work fine together so no problem there.
When I try to fire the 270 with the 600 there is a delay.
Master will flash then the 270 will flash about 1/2 second later.
I'm sure someone knows why but I cant figure out what I have set wrong?
-----------Canon EOS R -----------
reefvilla
Gallery: 44 photos
Aug 13, 2018 16:36 |  #2
If I go to the menu on camera and change from ETTL to MULTI flash, the 270 will fire twice, once when the master flash does and then another flash 1/2 second later?!!?
AND, I just went from MULTI to the manual setting and the 270 fires as it should, and full strength because its hotter with my hand in front of it than any other test fire.
Is the 270EXii just to old to work with this new stuff? I planned on using it for fill or artsy crap... :)
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Aug 14, 2018 10:28 |  #3
How do you have it set up? You can set the 600 to either RT or Optical Wireless, not both. I'm assuming the 270 is Optical only so my guess is you have the 600 set to Optical to get it to fire? Optical needs line of site. Maybe that is it.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Aug 14, 2018 10:31 |  #4
reefvilla wrote in post #18683584 (external link)
When in ETTL you get a pre-flash. The pre-flash is probably setting off the 270 for the first flash.
Image Editing OK
reefvilla
Gallery: 44 photos
Aug 14, 2018 10:38 |  #5
Yes, optical. I will mess around some more later today.
I'm sure whatever the problem is, me!! Lol
digital ­ paradise
Gallery: 157 photos
Post edited over 5 years ago by digital paradise.
Aug 14, 2018 10:41 |  #6
You can get RT devices that attach to a non RT flashes.
Image Editing OK
1,226 views & 0 likes for this thread, 2 members have posted to it.
1522 guests, 131 members online
