Thread started 18 Aug 2018 (Saturday) 11:35
1st wedding, 2nd shooter
swbkrun
Aug 18, 2018 11:35 |  #1
I’m stepping in as a 2nd shooter for a wedding in a couple weeks. What’s the best advice you can give me, or someone gave you, or you learned the hard way?
Just looking to learn as much as I can.... even etiquette wise.
I have also had a lot of conversations with the primary photographer, about her goals and expectations of me.
Thanks in advance.
http://averymckenna.sm​ugmug.com/ (external link)
"When I stand before God @ the end of my life, I would hope that I would not have a single bit of talent left, and I could say, 'I used everything you gave me.'"
Erma Bombeck
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Aug 19, 2018 12:05 |  #2
Make a shot list if you can. Prepare at the venue beforehand to get settings right if you can, synch time with the primary shooter,do what the primary tells you, its his gig so don't try to upstage him, and, most importantly, relax and enjoy the day. You'll either like it or love it. If you have to edit as well, edit like the primary does, and if he uses presets, get them for consistency of images.
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
daisan
Gallery: 49 photos
Joined Jun 2018
Aug 19, 2018 12:50 |  #3
Be aware of the main photographer - don’t get in / walk into / stay in his shots. Don’t just shoot headshots / things. Shoot interaction between people. Shoot scenes. Shoot things the other shooter isn’t. Don’t shoot portrait unless it’s really needed. Have fun! Smile.
Duncan Kerridge
Norfolk Wedding Photographer (external link)
My Facebook (external link)
500px (external link)
NullMember
Aug 19, 2018 13:13 |  #4
bannedPermanently
swbkrun wrote in post #18686706 (external link)
Thanks in advance.
Colin Glover wrote in post #18687496 (external link)
daisan wrote in post #18687518 (external link)
Most important rule of all: Don't call HER a HIM.
daisan
Gallery: 49 photos
Joined Jun 2018
Aug 19, 2018 14:14 as a reply to  @ NullMember's post |  #5
Yeah, don’t do that
Duncan Kerridge
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Aug 19, 2018 22:44 |  #6
usually as 2nd shooter, try to run away from the 1st shooter. unless the 2nd shooter is also an assistant.
if the 1st shooter is focus on the bride, then the 2nd focus on the groom and vice versa.
if the 1st shooter is focus on the "safety" shots, then the 2nd should do a PJ style in the background and vice versa.
if the 1st shooter uses flash, then the 2nd should not use flash in the same area and vice versa....
if the 1st shooter is focus on the "important" shots, then the 2nd may focus on "flavor" shots like Makro, Ultra Wide Angle, Fisheye, etc
 :p
Canon R3 | RP | 7D2+grip | EF 70-200mm f/2,8L IS II | EF 135mm f/2L | EF 50mm f/1,2L | RF 100mm f/2,8L | Tamron 24-70mm f/2,8 VC G2 | Tamron 17-35mm f/2,8-4 Di OSD | ZE 2/100mm | ZF 2/35mm | ZF 1,4/85mm | ZF 2/135mm | CV 1,4/58mm Nokton | Micro-Nikkor 60mm f/2,8D | DC-Nikkor 105mm f/2D | Micro-Nikkor 200mm f/4D |
Speedlite 430EX III-RT | 600EX-RT |
Manfrotto BeFree Travel | MT055XPRO3 |
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Aug 20, 2018 12:09 as a reply to  @ NullMember's post |  #7
Thanks for pointing that out John. At least I wasn't the only one to make that mistake, though my mistake probably was the trigger for the second.
swbkrun
Aug 20, 2018 23:50 |  #8
Thanks all for the advice. I’m sure there is a ton more out there but this is a great foundation.
Erma Bombeck
Silver-Halide
Joined Jan 2015
Aug 21, 2018 17:26 |  #9
1. Ask her for some business cards at the start of the day. That makes it clear to her that you intend to represent her and not yourself if the opportunity to schmooze arises.
2. Don't shoot over her shoulder during formals. Subjects will look at you and ruin the primary's shot. Your job is to stand at 45 degrees and get the side angle, or perhaps focus on the kids running around 20 yards away.
3. Look through her website extensively. That way you'll know things like if she uses flash at the reception or not, and you sound more proactive when you say: "I noticed that you use a lot of bounce flash at receptions, would you like me to do the same or shoot ambient light with my fast lens?" rather than "how should we divide up and shoot the reception?"
4. When a bridesmaid forgets her boquet at the last location, be the first to offer to go fetch it and hustle when you do.
stuff like that.
swbkrun
Aug 23, 2018 18:40 as a reply to  @ Silver-Halide's post |  #10
Thank you
Erma Bombeck
6,420 views & 4 likes for this thread, 6 members have posted to it and it is followed by 6 members.
1192 guests, 168 members online
