Thread started 21 Aug 2018 (Tuesday) 22:49
Help me understand layers please...
reefvilla
Gallery: 44 photos
Post edited over 5 years ago by reefvilla.
Aug 21, 2018 22:49 |  #1
Just to start, I am using Paint Shop Pro 2019 to edit.
So, say I have a picture and I want to adjust the curves.
Why not go to adjustment, click curves, adjust to my liking and clicked ok......instead of making an adjustment layer. If I dont like it I can undo the edit, right?!
I hear people talk about "destructive" editing and I guess I just dont understand enough about layers...
Why is it destructive to just edit with no adjustment layer?
Thanks for any help!!
-----------Canon EOS R -----------
Peano
Post edited over 5 years ago by Peano.
Aug 21, 2018 23:17 |  #2
reefvilla wrote in post #18689892 (external link)
Why not go to adjustment, click curves, adjust to my liking and clicked ok......instead of making an adjustment later. If I dont like it I can undo the edit, right?!
Right. That's why it's called nondestructive editing. After you save the layered file, you can still go back and undo your editing.
If you edit a pixel layer and save the file, that permanently changes those pixels. Hence, destructive. You can't go back and undo the edit. But if you use an adjustment layer, you can undo or otherwise adjust the edit.
Peano
RadiantPics.com (external link)
Merlin_AZ
Aug 21, 2018 23:21 |  #3
You can delete the adjustment layer and return to the original.
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Aug 22, 2018 00:27 |  #4
Merlin_AZ wrote in post #18689909 (external link)
You can also keep the adjustment layer, but vary its opacity. That is to set the adjustment you want, but then you can vary the percentage of that adjustment. Also, if you make an adjustment and it looks great on the subject but it makes the background look bad, you have the choice of selecting what parts of the image you wish to adjust by using one of the selection tools, or even by simply erasing the parts of the layer that you don't want the change to occur to.
Philip
reefvilla
Gallery: 44 photos
Aug 22, 2018 08:29 as a reply to  @ Nogo's post |  #5
This I did not know. I have had several edits where part of the photo looks good but the editing didnt work on say, the sky or some other part.
Maybe I'm wrong.... edit: I'm sure I'm wrong.... but I thought once you create adjustment layers, edit picture and then go to save, it would Merge layers into a single layer to save. Which would mean you cannot adjust layers after it is saved?
Merlin_AZ
Aug 22, 2018 09:46 as a reply to  @ reefvilla's post |  #6
If you save the .psd file, it will save all the layers.
reefvilla
Gallery: 44 photos
Aug 22, 2018 09:48 as a reply to  @ Merlin_AZ's post |  #7
Ok..thanks
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Aug 22, 2018 10:10 |  #8
reefvilla wrote in post #18690090 (external link)
If the PSP layers have a layer mask option, you're better off using that because it can be modified later where erasing can't be brought after a save & closing the file. This would be the same as if you had used a Adjustment Layer in the first place in PS.
.tiff files also save the layers. I usually use those because windoze can display them.
medd63
Gallery: 11 photos
Joined Feb 2014
Aug 22, 2018 12:10 |  #9
He is using paint shop pro. Does that even save files as a .psd? I would think not.
6D, 7D2, T4i, 16-35mm f/4L IS, 100mm Macro f/2.8L IS, 100-400mm f/4.5-5.6L IS, 50mm f/1.4 IS, EF-S 55-250, 1.4 II TC, Kenko Extension Tubes, MeFoto Globetrotter & Roadtrip Tripods, Lightroom CC, Photoshop CC
reefvilla
Gallery: 44 photos
Aug 22, 2018 12:19 |  #10
medd63 wrote in post #18690243 (external link)
I will check later but I'm pretty sure it does.
I have used PSP since 2005 but I think it's time to switch to Adobe
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Aug 22, 2018 13:45 |  #11
Nogo wrote in post #18689927 (external link)
- You can also keep the adjustment layer, but vary its opacity. That is to set the adjustment you want, but then you can vary the percentage of that adjustment.
- Also, if you make an adjustment and it looks great on the subject but it makes the background look bad, you have the choice of selecting what parts of the image you wish to adjust by using one of the selection tools, or even by simply erasing the parts of the layer that you don't want the change to occur to.
These are the main reason I usually use layers for everything.
Varying opacity of your adjustments in real time can be a real eye opener, and will show you very quickly when you have taken adjustments too far, and allow you to quickly dial in the "correct" amount to get the best image.
A great example that will boost the speed you work; you COULD adjust levels for each image one at a time, being careful to get it all looking good but not over cooked, OR you could use "auto levels" on an adjustment layer and back off opacity, one slider, until it feels right. The latter is MUCH faster.
This is of course very helpful too!
CDS' HOT LINKS
reefvilla
Gallery: 44 photos
Aug 22, 2018 14:18 |  #12
PSP does save in .psd and it will re-open with all the layers showing, however, none of the layers will adjust.
I can move the slide bar or toggle off the layer but nothing happens.
It will not save in .tiff … I get a merge warning
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/08/4/LQ_929177.jpg
Image hosted by forum (929177) © reefvilla [SHARE LINK]
number ­ six
fully entitled to be jealous
Aug 22, 2018 14:34 |  #13
reefvilla wrote in post #18690338 (external link)
Hosted photo: posted by reefvilla in
./showthread.php?p=186​90338&i=i213896909
forum: RAW, Post Processing & Printing
I use PSP X6. The default for saving an image is .pspimage format, which will allow later editing of layers. No reason to use .psd unless you need it to be readable by Photoshop.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
reefvilla
Gallery: 44 photos
Aug 22, 2018 14:35 as a reply to  @ number six's post |  #14
OK... Thank you!
EDIT: That works perfect!!! Thanks
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Aug 24, 2018 16:12 |  #15
https://www.youtube.co​m/watch?v=ZBKHeU8rWFs (external link)
Image Editing OK
7,255 views & 5 likes for this thread, 11 members have posted to it and it is followed by 10 members.
1522 guests, 131 members online
