While this is in a church setting, this is NOT part of a mass/service, so my discussion about flash is not one about being able to use a flash in this setting...its more about the affects of using and how to use.
Lighting will be a challenge in this environment. I could shoot with my 50mm on my 70D to make up for lighting but while this will give me great results, it will limit me some due to not being able to zoom and I dont want to be hustling all over the room to 'get that shot'. So I am choosing the next best lens I have at my disposal...the 18-135mm IS STM. I have done some test shots and without lighting my ISO is bumping way up...12800 on some cases. This I just dont like.
So...I have done some test shots where I mounted an off camera flash to the left side of the room pointed straight up at the ceiling. I am using the Flashpoint R2 trigger to control the flashpoint flash.
the flash power is 1/1 as I am shooting in manual mode.
The ceiling, ugh, is a high peak ceiling with dark wood. However, the up lighting gave me enough boost to be able to move around the room and shoot at 160 6.2 at 1600 ISO. Much much better!
So, here is my dilemma. This flash is going to be mounted on a window sill about 5 ft from ground and nearly straight up. This will be either around eye level to people standing or above the heads when people are sitting.
My fear is that this flash, firing to the side will be somewhat distracting to those sitting nearby either by sound of flash going off or by seeing the flash fire (even if directed upwards)!!!!
I am not sure I can get this flash any higher as there is no room for a stand, plus I do not have a stand for this purpose (NOTE to self, get a stand for this purpose anyway as its going to be needed someday)
So, am I worried about nothing? Or should I do something to get this flash somewhere else that will be less distracting?
Ceremony is about 1.5 hours long, so there will be a lot of shots.
