FORUMS Cameras, Lenses & Accessories Fuji Digital Cameras
Thread started 19 Sep 2018 (Wednesday) 10:22
Fujifilm X-T3 worse high-iso noise from RAW files than the X-T2?
Erik_A
Joined Jun 2011
Sep 19, 2018 10:22 |  #1
It looks like the Fujifilm X-T3 worse high-iso noise from RAW files than the X-T2. I wonder if that is because they switched from Sony to Samsung manufactured sensors.
https://www.dpreview.c​om …063&y=-0.7686060647765847 (external link)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/09/3/LQ_933985.jpg
Image hosted by forum (933985) © Erik_A [SHARE LINK]
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Sep 19, 2018 10:54 |  #2
I think its impressive to see the XT2 is doing a pretty decent job keeping up with a 5DIV at high ISO
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
kirkt
Sep 19, 2018 13:58 |  #3
It's probably a toss up, considering that the above screenshot is comparing raw renderings and using ACR 11 - it may be better to examine the JPEGs, which will probably have some NR applied in camera, but at least will represent Fujifilm's interpretation of the image data as opposed to a as-of-yet non-available raw converter's. Once other raw converters support the XT-3, then the raw files can be examined and the larger X-T3 image can be resampled to the size of the XT-2, etc.
kirk
Kirk
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Sep 19, 2018 15:45 |  #4
Kevin Mullins posted a shot last week in low light, he put it in his X-T3 video here: https://youtu.be/Aap8N​UsVfZw?t=14m15s (external link)
Fujifilm cameras and lenses.
Gear I use to create (external link)Instagram (external link)Blog (external link)
Coffee & Fujis (external link)About Capture One (external link)YouTube (external link)
AlanU
Gallery: 144 photos
Post edited over 5 years ago by AlanU. (3 edits in all)
Sep 19, 2018 18:54 |  #5
http://www.aevansphoto​.com/does_fuji_cheat_i​so/ (external link)
Which ISO standard does Fuji use? I’m not aware which one Fuji follows. I know there is a difference as I've verified this in studio.
https://photographylif​e.com …ji-cheat-with-its-sensors (external link)
I did a test and noticed a difference between my Fuji and Canon in my basement studio (no available light) using only studio lights. There was aprox 2/3 stop difference between my canon in Fuji using identical settings on both cameras.
I'm not sure if you can compare images apples to apples in studio settings. I am no sure what Fuji standard fuji uses. I have tested this myself and found a difference. I posted the difference a while ago on the POTN.
Not sure if the links I provided has a solution to matching exposure.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
cug
Joined Oct 2015
Sep 20, 2018 00:38 as a reply to  @ AlanU's post |  #6
It might be that Fujifilm has finally gotten around and is using an ISO standard that is closer to the rest – so it might not be directly comparable. They've always been between 1/3 and 2/3 of a stop off from my Canon gear. Maybe it's just that they are now more in line.
AlanU
Gallery: 144 photos
Sep 20, 2018 08:34 |  #7
cug wrote in post #18711674 (external link)
I guess Fuji using the new Samsung sensor in the XT3 is doing well considering it’s not a Sony cmos sensor.
Perhaps somebody purchasing the new Fuji XT3 has extra time on their hands can do a controlled studio test and match identical settings with a canon, Nikon, Sony and Fuji and see how close the exposure will be with studio strobes .
Does the studio test show the actual settings on the camera? Iso 12800 used in adequate lighting will definitely have different results between sensors if the environment is even darker. Wouldn’t that be the case??
If exposure triangle is all the same in all of the cameras the availability of light would be the variable. Wouldn’t the lower light have an effect in noise characteristics in the case of physical surface area of the sensor?
My confusion is caused because my XT2 has never been that close in digital noise pattern compared to my A73 or 5D Mark four. XT two was a little bit closer to the performance of the 5D Mark III. But the Fuji did have a very nice colour recovery at higher ISO.
The big draw to the new Fuji body is how it apparently has better auto focus in low light. The response of the new body is quite incredible and if I was A Fuji wedding photographer full-time I would have bare minimum pair of XT three on pre-order. However it does really seem the Samsung is falling short in lowlight performance. I think the price point of the new bodies is helping sales. Just watched a German Fuji X photographer do a comparison and both XT2 and XT3 seemed quite close in low light performance .
Fuji - gone
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Post edited over 5 years ago by Two Hot Shoes.
Sep 20, 2018 08:47 |  #8
AlanU wrote in post #18711838 (external link)
Fuji have stated in their press release that they have increased resolution with no loss of image quality at high ISO values so not really a surprise to find them very similar at 12800ISO. Mr Mullins did point out he thought the 12800 JPEGs from the camera looked a bit tidier on the X-T3 over the X-T2. Sure stick with you a7s or whatever and enjoy shooting when there is crappy light or learn to add light and drag the shutter a bit or just learn how to get the best out of one camera. Plenty of 12800ISO images in this forum that are full of detail and colour taken with Fuji cameras, all you have to do is look...
kirkt
Post edited over 5 years ago by kirkt.
Sep 20, 2018 08:47 |  #9
AlanU wrote in post #18711544 (external link)
Fujifilm uses SOS. Canon uses REI. The link you quoted tells you this if you read the article. So does the internet.
See: http://www.openphotogr​aphyforums.com/forums/​showthread.php?t=18387 (external link)
for example.
We often see today in the specifications for digital cameras that the "sensitivity" is presented in terms of the metric(s) ISO SOS and/or ISO REI. What does that mean?
It is a long story, and I will start with some background.
Classical reflected light exposure metering
In what I call classical reflected light exposure metering (whether with a free-standing exposure meter or via an inbuilt automatic exposure system) the "instrument" measures the average scene luminance.
From that, plus the "sensitivity" of the film or digital imaging system, a photographic exposure (combination of shutter speed and aperture) is recommended or put into effect.
This is quite a leap of faith, given the variations in scene structure and the existence of various "exposure strategies" the photographer might want to follow. But it is simple to do, and for many years it was the basic for much exposure planning.
Now assume the following (we will assume a digital camera):
• The "calibration" of the automatic exposure system (we will work with that rather than a free-standing meter as the standards are more "singular") is per the applicable ISO standard.
• The ISO speed of the digital imaging system (an input to the equation of the automatic exposure system) is determined per the applicable ISO standard (using the "saturation" basis).
Now imagine that we shoot a scene with such a camera in which the average luminance is 18% of the peak (highlight) luminance (the infamous "typical scene".
Then, for a "metered" exposure, the result on the sensor will be that the photometric exposure for a highlight area will be 70.7% of the saturation photometric exposure ("1/2 stop below it"). The average photometric exposure will be 12.8% of the saturation photometric exposure.
A collateral implication is that if we take a metered exposure of a uniform-luminance scene (perhaps a frame-filling gray card), the photometric exposure anywhere on the sensor is 12.8% of the saturation photometric exposure.
You were expecting maybe 18%? Well, 12.8% is just about 18% of 70.7% of the saturation photometric exposure.
The "1/2 stop" distance is often called the exposure metering "headroom", a term borrowed from a similar matter in sound recording. Its purpose is to avert overexposure in the event that, for the actual scene being shot, the average luminance is less than 18% of the peak (highlight) luminance. (It's not enough if the average luminance is below 12.8% of the peak luminance.)
Intelligent metering
Of course modern cameras use a much more sophisticated approach to automatic exposure control, which involves measuring the scene luminance at multiple points (maybe even at every pixel location), and concluding from that what the range of scene luminance is (at least over the regions that we are probably interested in).
Typically, the "calibration" of such a system is stated by consideration of the photometric exposure that would result from a uniform luminance scene. If we made that consistent with the "calibration" of a "traditional" automatic exposure system , one possible implication would be that in a hypothetical "typical" scene, the photometric exposure for highlights would be 1/2 stop below the saturation photometric exposure.
But this is a 1/2 stop waste of the "range" of the sensor system. No "headroom" is required, since the exposure control system deals with the actual (at least intelligently estimated) range of scene illuminance, not some simplistically-assumed range.
Getting back the "headroom"
Of course, we can readily reclaim the "headroom" by just making a 1/2 stop change in the calibration of the exposure control system. But there are some subtle downsides to that. One is that if we now use an external exposure meter (calibrated per the ISO standard for such) with the camera, for a "uniform luminance scene", the photographic exposure it will recommend will be different from that which the camera would adopt. This might make users think that the automatic exposure system in the camera was "miscalibrated".
So a crafty ploy is used. The "rating" of the various sensitivity settings in the camera, as ISO speed, is understated by 1/2 stop (compared to the ISO definition). This shifts the photographic exposure that would be set by the camera (or recommended by an external exposure meter) "hotter" by 1/2 stop, thus "burning the headroom".
Exposure index
Before I proceed with the story, I must speak of another term that will soon be part of the story.
When exposure metering first came into existence, there was of course no established numerical way to express the sensitivity of a certain film type. Thus, exposure meter manufacturers (such as Weston) devised there own premises and scales of sensitivity, and then did research to determine what the value of that metric was for available film types. These were listed in a pamphlet the user got with the exposure meter.
In many cases, this metric was called the exposure index of the film.
Eventually, standard schemes of rating film sensitivity were established, such as (in the US) by the American Standards Association. The metric was labeled "ASA film speed". "Speed" was a common colloquialism for film sensitivity, since, for a given scene luminance and a given aperture, the greater the sensitivity, the faster would be the needed shutter speed.
The ASA sensitivity system eventually was embraced by an international standard system, where the metric is called the "ISO speed" of the film.
Today, "exposure index" has taken on a new meaning: "what we tell the metering system is the ISO speed of the film or sensor". What does that mean?
Suppose we are shooting with film rated at ISO 200, but we recognize that the lighting situation is such that we would like to decrease the photographic exposure from what the meter will recommend by 1/2 stop (what today we would usually call -1/2 stop of exposure compensation - the formal term is exposure bias).
There is no "exposure compensation" setting on our meter, but we set the "ISO dial" to ISO 280. That will cause the meter to issue a 1/2 stop less photographic exposure recommendation that would be normal.
So the little dial marked "ISO" is where we set, not necessarily the ISO speed of the film, but rather the "exposure index" at which we want the exposure reckoned.
Back to the story
Before our little excursion into the significance of "exposure index", I mentioned that, in order to "burn the headroom" of the traditional exposure metering equation when we were using "intelligent" metering systems, we could understate the ISO sensitivity of the system that was fed to the inbuilt automatic exposure system (or set into an external light meter as the "exposure index"). But in fact that meant lack of compliance with the established ISO definition of ISO speed, at the least intellectually troublesome, and with some implications about understating the low-light potential of the camera.
So a few years ago, the ISO added to the standard for the "sensitivity" of digital camera imaging systems two new metrics (in addition to ISO speed):
• The ISO Standard Output Sensitivity (ISO SOS). For all practical purposes, this metric is determined the same way as the ISO speed using the "saturation" basis, but will have a value that is 70.4% of the ISO speed (almost exactly "1/2 stop lower).
If the ISO SOS value is fed to the automatic exposure system, or used as the exposure index into a free-standing exposure meter, then the "1/2 stop bump" in photographic exposure, needed to "burn the headroom", will occur.
• The ISO Recommended Exposure Index (ISO REI). This value can be chosen by the camera manufacturer, at its discretion, for use an an exposure index to attain an arbitrary bump in the photographic exposure compared to that based in the ISO speed which the manufacturer feels will be most useful for typical photographic tasks. There is no technical definition. It is to be chosen for the desired result.
If the camera manufacturer wants to adopt the exact "bump" in photometric exposure implied by the ISO SOS value, he can make that clear by stating the determined ISO SOS value and then stating the same number as the ISO REI value.
Thus, if for one position of the "ISO" control on the camera, the manufacturer says, in the specifications, that is is "ISO 400 (SOS/REI)", he is saying that:
• The ISO speed at that setting is about ISO 568.
• The automatic exposure system in this camera will choose the photographic exposure according to the industry standard exposure equation for ISO speed of ISO 568.
• It is recommended that, in using a free-standing exposure meter, you set the "ISO" setting (exposure index) to ISO 568.
Woof!
Best regards,
Doug
More here: http://dougkerr.net/Pu​mpkin/articles/SOS_REI​.pdf (external link)
and here: http://lmgtfy.com/?q=F​ujifilm+ISO+SOS (external link)
Kirk
Kirk
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Sep 20, 2018 08:58 as a reply to  @ kirkt's post |  #10
Pretty sure I posted this info at least once before, some people on here have short memories, including some who commented on the very similar thread to this one [not you Kirk], or at least how this one is dragging into the Fuji ISO measurement debate.
I think we'll all just have to wait and see how the Higher ISO looks on the X-T3 when apps like Lightroom are about to deal with the raw files from that camera.
AlanU
Gallery: 144 photos
Sep 20, 2018 09:34 |  #11
Two Hot Shoes wrote in post #18711863 (external link)
Kim,
To be transparent according to the article the actual REI should be divided by 0.71.
12,800 iso (REI - Nikon / Canon) / 0.71= 18,028 (Fuji SOS).
Technically speaking this test is Scewed or has a conversion been performed???
In this test wouldn’t the Fuji require at least 1/3 stop more at 16,000 iso?? However it wouldn’t be fair at 20,000 iso.
This would compare all cameras in the comparison to REI iso standards.
Having numbers with a comparison chart using two different standards is far from a controlled experiment wouldn’t you say?
Kind of like comparing horsepower and bragging about Brake Horespower Not including parasitic loss.
Kim this is not a debate but factual comparison. I’m just not aware if there has been a iso standard conversion in this studio chart to test. I highly doubt that there is any conversion performed . However people reading this thread are taking numbers at face value which is purely incorrect and very misleading .
If there is something I am dragging ....it’s reality of real numbers.
If you are aware of these differences, why are you not making non Fuji photogs aware of this? Many readers of this thread are taking these iso 12800 as a baseline comparison as if they are using the same standards. These numbers are clearly not the same for technical judgement visually.
The only factual real comparison in this scewed test is XT2 vs XT3 since they are both using the same standards I’m assuming.
I’m just stating facts!
Fuji - gone
AlanU
Gallery: 144 photos
Sep 20, 2018 09:42 |  #12
If the Fuji is tested at iso 12,800 (sos standard) the Canon and Nikon should be tested at iso 9088 (REI iso standard). Unfortunately there’s is no setting in those cameras.
That is more like a logical honest comparison.
Fuji - gone
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Post edited over 5 years ago by Two Hot Shoes. (2 edits in all)
Sep 20, 2018 11:27 as a reply to  @ AlanU's post |  #13
ISO is a totally arbitrary setting within a set of parameters that the camera manufactures see as best for them, with the REI standard anyway. SOS standard is more ridged.
Heres the reverent bits for you Alan. But like most things related to photography worrying about a 1/3 of a stop here and there is of little coincidence when really one needs to think about the composition - I doubt it ever make a difference in the real world.
"The Recommended Exposure Index (REI) technique, new in the 2006 version of the standard, allows the manufacturer to specify a camera model’s EI choices arbitrarily. The choices are based solely on the manufacturer’s opinion of what EI values produce well-exposed sRGB images at the various sensor sensitivity settings. This is the only technique available under the standard for output formats that are not in the sRGB color space. This is also the only technique available under the standard when multi-zone metering (also called pattern metering) is used.
The Standard Output Sensitivity (SOS) technique, also new in the 2006 version of the standard, effectively specifies that the average level in the sRGB image must be 18% gray plus or minus 1/3 stop when the exposure is controlled by an automatic exposure control system calibrated per ISO 2721 and set to the EI with no exposure compensation. Because the output level is measured in the sRGB output from the camera, it is only applicable to sRGB images—typically JPEG—and not to output files in raw image format. It is not applicable when multi-zone metering is used."
Add into that an understanding of how and why the signal is amplified as the gain is increased in the processor and you'll have a good understanding of the basics of it. Not that is really matters anyway outside of forums and the pub/camera club.
AlanU
Gallery: 144 photos
Sep 20, 2018 18:48 |  #14
Two Hot Shoes wrote in post #18711964 (external link)
I agree there's a lot of info here. But regardless , using ISO 12,800 is not the same standard between Canon/Nikon and Fuji's (SOS) Iso numbers. That's a misrepresentation of a "real" test between Fuji and Canon/Nikon. Definitely not a comparison of apples to apples. Visually the advantage goes to Fuji iso numbers.
Nothing to do with brand loyalty here.......
Fuji - gone
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Sep 21, 2018 12:06 |  #15
This.
I really wish my Fuji dials were all in full or even half stop increments in fact. To me that would just make it so much faster to change settings on the fly without having to look at all. I love using old lenses simply for the full stop aperture changes. People's need for that extra little bit of 1/3 stop control makes no sense to me... it's not going to have a notable difference to your end result and it just slows down the workflow, especially for the ISO dial (which is partly why I almost always just leave it on "A")
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
8,605 views & 13 likes for this thread, 11 members have posted to it and it is followed by 9 members.
1447 guests, 131 members online
