What is meant by this? A 3rd from the top of the image or is it INTO the image?
Oct 01, 2018 06:02 | #1 What is meant by this? A 3rd from the top of the image or is it INTO the image?
TeamSpeed 01010100 01010011 More info | Oct 01, 2018 06:37 | #2 Assuming landscapes shots... https://improvephotography.com …3-photo-deep-depth-field/ Past Equipment | My Personal Gallery
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 5 years ago by Wilt. (10 edits in all) | Oct 01, 2018 12:36 | #3 The theory is that Depth of Field is a bit shallower in front of the plane of focus, and a bit deeper in back of the plane of focus, so that if you have 4 rows of people in a group you would want to focus on the second row, and the DOF Zone would include the front row and also the back to rows as within the 'in focus' zone for the shot.
Teamspeed's linked article tells you the classic definition of 'one third into the scene'...so if your wife was at 50' and the Washington Monument was at 250', you should focus at about 115' or 1/3 the distance between 50' and 250' ((200' / 3) + 50). The reality is that someone with 20/20 vision would see a DOF Zone from about 62' to about 699'. so the Washington Monument is 'in focus' while your wife is seen as blurred, as the distribution is only 8% in front and 92% behind the plane of focus at 115'!... You would need to focus at 70' for your wife to be perceived as 'in focus' standing at 50'! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
CyberDyneSystems Admin (type T-2000) More info | Oct 01, 2018 12:53 | #4 - See also "hyperfocal" GEAR LIST
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 5 years ago by Wilt. (2 edits in all) | Oct 01, 2018 13:08 | #5 CyberDyneSystems wrote in post #18720037 - See also "hyperfocal" eg; https://photographylife.com …rfocal-distance-explained
daleg Senior Member More info Post edited over 5 years ago by daleg. | Oct 01, 2018 13:12 | #6 there are several answers that are technically correct depending on subject(s) and composition.
TeamSpeed 01010100 01010011 More info Post edited over 5 years ago by TeamSpeed. | Oct 01, 2018 16:27 | #7 I don't do the math (wrong or right) when composing a shot, I use guidelines, it works well enough, and if I take a few extra shots focused at different points to be safe, I should have what I need. Doing all the math takes something away from the experience IMO. I take pictures to get away from math. Past Equipment | My Personal Gallery
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 5 years ago by Wilt. | Oct 01, 2018 17:34 | #8 TeamSpeed wrote in post #18720236 I don't do the math (wrong or right) when composing a shot, I use guidelines, it works well enough, and if I take a few extra shots focused at different points to be safe, I should have what I need. Doing all the math takes something away from the experience IMO. I take pictures to get away from math. I have enough of that through the day as it is. Where should I move my 401k? What stock should I buy today? How much file space will our solutions eat up today at the rate they are logging? How many lines of code will I get rid of if I rewrite that person's solution? How much to tip for dinner? Arggggg it never ends...^ You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
TeamSpeed 01010100 01010011 More info Post edited over 5 years ago by TeamSpeed. (6 edits in all) | That is a nice way to do it, thanks! I will have to see which of my lenses have that, I never use it today. I suspect all of mine probably are compressed as you mention and about useless. Past Equipment | My Personal Gallery
LeftHandedBrisket Combating camera shame since 1977... More info | Oct 01, 2018 19:21 | #10 The macro vs landscape ratios are good to keep in mind. 1/3 was likely derived as a "typical" shot, whatever that is. Having a hyperfocal calculator on a phone is a nice perk, but like the others, I just make it up as I go along, experience helps too. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Snydremark my very own Lightrules moment More info | Oct 01, 2018 19:39 | #11 Left Handed Brisket wrote in post #18720345 ... One thing to keep in mind, and ill use the wife / monument example. "Typically" you'll want foreground subjects to appear a little sharper, or at least no less sharp than background objects. So when you are making up some random spot to focus on, make it closer to the camera than farther. With nothing to back me up, this is my own theory on why the "rule" says 1/3. As a modification to this, I will usually find a spot that I want to "anchor" the shot, which is normally my subject or foreground object and focus there; with it falling somewhere in the "front" 2/3 of the framing I'm going for. The larger the aperture, the closer I will land to the camera, generally. - Eric S.: My Birds/Wildlife
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | I use to obsess over hyperfocal distance and depth of field calculations. Never again. Such contrivances only slow me down and cripple my creativity. Nowadays, I simply focus on the most important object in the scene and forget about it. It's ok for some areas of a landscape scene to fall out of focus, as long as the primary point of interest is very sharp. Trying to get everything "acceptably sharp" leaves you with nothing that is "tack sharp." And that's not good. If you need everything to be sharp, as is the case with ultra wide angles that include near and far objects of competing interest, then you really have no choice but to focus stack. Get use to it.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 5 years ago by Wilt. (2 edits in all) | Oct 02, 2018 16:18 | #13 texshooter wrote in post #18720586 I use to obsess over hyperfocal distance and depth of field calculations. Never again. Such contrivances only slow me down and cripple my creativity. Nowadays, I simply focus on the most important object in the scene and forget about it. It's ok for some areas of a landscape scene to fall out of focus, as long as the primary point of interest is very sharp. Trying to get everything "acceptably sharp" leaves you with nothing that is "tack sharp." And that's not good. If you need everything to be sharp, as is the case with ultra wide angles that include near and far objects of competing interest, then you really have no choice but to focus stack. Get use to it. ^ You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
TeamSpeed 01010100 01010011 More info | Oct 05, 2018 09:50 | #14 TeamSpeed wrote in post #18720286 Hot non-photographic tip, I think GE has finally plateaued, and I put the equivalent of a 1DX2 into their stock. I expect it to recover about 20% of this year's losses by the end of the year. They took a beating! If that happens, GE will have paid for 1/2 an EOS-R. Well, GE is on its way. Bought last week and am up 13%. 1/5 of the EOS R is paid for right now! Past Equipment | My Personal Gallery
Sibil Cream of the Crop 10,415 posts Likes: 54444 Joined Jan 2009 Location: SoCal More info | Oct 06, 2018 06:34 | #15 TeamSpeed wrote in post #18720236 I don't do the math (wrong or right) when composing a shot, I use guidelines, it works well enough, and if I take a few extra shots focused at different points to be safe, I should have what I need. Doing all the math takes something away from the experience IMO. Agreed, especially with rapidly changing light during the golden hours. You've got to get the shot or you lose the light.
| Latest registered member is semonsters 972 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
