Thread started 14 Oct 2018 (Sunday) 16:02
Automate Tone Curve Adjustment?
Jocce
Gallery: 12 photos
Joined Jun 2012
Oct 14, 2018 16:02 |  #1
I've started to digitizing a lot of my old Negatives (and also my Father and Grand Fathers slides). (Photographing them against a Light Box)
I'm using Camera Raw to process them
When processing them I need to invert them.
No problem, I've done a preset for inverting blacks/whites in the Tone Curve.
But one of the things I need to do to most of my images is adjusting each channel (Red, Green Blue), basically pulling in the end points to where the Histogram starts.
Since each image looks different this is not a set point, this is a point that needs to be adjusted for each image (and channel).
Is there anyway of automating this? Or do I need to do this manually on EVERY image?
/Jocce
Feel free to correct my English. I'm from Sweden ;)
My Website (external link)
Fotointresse.se (external link)
Twitter (external link)
kirkt
Oct 14, 2018 20:11 |  #2
Hold down the ALT or OPTION key in ps when you click the auto button on the curves adjustment and it will permit you to set the auto method. You can choose the method that works best for your application and make an action that you can apply to a batch of images.
Kirk
Kirk
Jocce
Gallery: 12 photos
Joined Jun 2012
Oct 15, 2018 09:37 as a reply to  @ kirkt's post |  #3
I was hoping not to open every image in PS, since I am using Camera Raw...
/Jocce
kirkt
Oct 15, 2018 12:40 |  #4
Jocce wrote in post #18729304 (external link)
/Jocce
You don't have to open the images, just run a batch operation on them once you are done whatever it is you do in ACR - you can assign the action you create in PS to the batch operation.
ACR is not for image processing, it is for raw conversion.
kirk
Kirk
Jocce
Gallery: 12 photos
Joined Jun 2012
Oct 15, 2018 13:23 |  #5
kirkt wrote in post #18729456 (external link)
kirk
Well, I need to do this as one of the first steps in ACR and make other adjustments in ACR after doing this.
As a part of the conversion...
If I run them in PS I have to leave the RAW-format, and want to do all my adjustments there before going in to PS.
/Jocce
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Oct 15, 2018 14:45 |  #6
I think you're stuck then, I'm not aware of a batch method for ACR.
BTW, I'll be in Stockholm in two weeks, hope the weather holds. :)
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
kirkt
Post edited over 5 years ago by kirkt. (2 edits in all)
Oct 15, 2018 15:22 |  #7
Jocce wrote in post #18729497 (external link)
/Jocce
What does raw give you that 16bit TIFF does not? Again, ACR is a raw converter, not an image processing application. It appears to be constraining your workflow efficiency to the point where an alternative may be more efficient and yield potentially better results in the process. Again, I have no idea what it is that you are trying to do and what adjustments you need to perform, but the dynamic range of a scanned negative is nowhere near that of an actual real-life scene, so ACR seems to be more for convenience than need here.
You can always run ACR as a filter on the RGB file (i.e., TIFF) if necessary to make it more convenient for your approach.
kirk
Kirk
Jocce
Gallery: 12 photos
Joined Jun 2012
Post edited over 5 years ago by Jocce.
Oct 16, 2018 01:35 |  #8
DagoImaging wrote in post #18729559 (external link)
Batch for ACR is not the problem (Open all files, Mark them all and use make the setting).
Its the AUTO part of the Tone Curve that I can not do.
Welcome here. If the weather holds you are going to have great experience!
Visiting for vacation or work?
/Jocce
Jocce
Gallery: 12 photos
Joined Jun 2012
Oct 16, 2018 01:37 |  #9
kirkt wrote in post #18729580 (external link)
kirk
Quality will propably be the same, but to keep the workflow within ACR would be nice (= do not have to use two different applications, save two different files etc).
Tha Batch-parts is no problem, just that I havn't figured out how to do the Tone Curve Adjustment automatically...
/Jocce
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Oct 16, 2018 07:21 as a reply to  @ Jocce's post |  #10
I will be there for work but have free evenings and weekends. Weather seems to be about the same as where I am right now, so not to bad.
Jocce
Gallery: 12 photos
Joined Jun 2012
Oct 16, 2018 07:33 |  #11
DagoImaging wrote in post #18730019 (external link)
If you have the time (During day in the weekend), go for a trip in the Archipelago. REALLY beautiful :)
/Jocce
1,831 views & 2 likes for this thread, 3 members have posted to it and it is followed by 3 members.
1117 guests, 170 members online
