FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 05 Nov 2018 (Monday) 20:09
Carrying Heavy Lens on Monopod?
Larry ­ Johnson
Joined Sep 2011
Nov 05, 2018 20:09 |  #1
I bought a 7lb lens that I expect to be using on a monopod. Might have a Sirui 90-degree tilt head on a manfroto monopod. Should I have any concens about the lens breaking off the monopod if I carry the pod on my shoulder with lens pointing to the ground. Just how strong are those little attachment screws.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 06, 2018 08:43 |  #2
I do it all the time. I would not worry.
CDS' HOT LINKS
Trvlr323
Nov 06, 2018 09:07 |  #3
I have a Sirui L-10 tilt head that I pair with a Sirui P-326 monopod. I've often exceeded the recommended weight limit and never had an issue. All the Sirui stuff I own seems to be built like a tank.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
bpalermini
Gallery: 203 photos
Joined Mar 2011
Post edited over 5 years ago by bpalermini.
Nov 06, 2018 10:08 |  #4
I use an 8.47-pound lens on a monopod a lot.
Q1 = no, don't worry
Q2 = very strong in my experience.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
johnf3f
Nov 06, 2018 16:50 |  #5
My only worry when carrying a big lens over my shoulder (with a mono pod or tripod) is my shoulder!
Life is for living, cameras are to capture it (one day I will learn how!).
RPCrowe
Joined Nov 2005
Nov 07, 2018 11:03 |  #6
I also do this all of the time with no problems. However, I will usually rest the weight of the lens on my shoulder as I do so. Not that I am worried about the camera/lens separating from the monopod it's just a bit easier for me to carry the rig that way!
Wilt
Post edited over 5 years ago by Wilt.
Nov 07, 2018 12:39 |  #7
Worry more about...
  • any QR system releasing prematurely (bumping the lever/screw lock)
  • the head's baseplate unscrewing from the monopod, because not held with Locktite (or retaining safety screw) on the 3/8 center thread
...than worrying about the 1/4"-20 screw (into lens foot) breaking
Larry ­ Johnson
Joined Sep 2011
Nov 07, 2018 17:11 as a reply to  @ Wilt's post |  #8
Thanks for all the replies. Yes, I’m mostly concerned about the small screw breaking loose or similar.
After posting I thought it would be a good idea to put a safety cable from the lens’ strap loop to the monopod.
Ain't Nature Grand!
Choderboy
I like a long knob
Gallery: 185 photos
Nov 08, 2018 04:12 |  #9
I replaced the Sirui clamp on two L10 tilt heads. It's a big screw (8mm). Both had thread locker. Good thread locker too, I had to drill and extract the first screw.
On the 2nd head I used a hot air gun to soften the thread locker.
I use mine with 14-15 lb load, carried on my shoulder. I would not trust a Manfrotto monopod for that type of use. I have an old Gitzo which has a big chunk of aluminium to anchor the screw that attaches to the L10. I chopped my Manfrotto pod up (after the screws corroded) to see how the top plate is secured.
Seems like a failure waiting to happen to me.
Dave
Image editing OK
SYS
Gallery: 602 photos
Joined Jul 2004
Nov 08, 2018 10:48 |  #10
I use Sirui L-20S on my Gitzo monopod for carrying 5DIII with Sigma 150-600C on my shoulder all the time with no issues. I do have a safety tether in the form of BlackRapid shoulder strap just in case, though.
-Goethe
daleg
Joined Aug 2013
Jan 11, 2019 17:31 |  #11
Likewise. I have a Manfrotto 680B. Caution - they do not like sand. I wouldn't use it on a 7# lens - especially with a heavier pro body. I'd be more concerned with the monopod head, if you're not connecting directly. the original Manfrotto 234 monopod head had a very low weight rating - this head was mod'd & resold by Kirk as the MPA-1 (same weight rating, arca-swiss mount).
For a heavier rig, I use an Gitzo 5 series pod w/RRS MH-01 & same clamp as my ballhead.
For lighter rigs, I use a Sirui L-10 head on either the Sirui P-326 (a six section, great light pod!) or it's more pricey video relative, the P-426S. The Manfrotto is now pretty much back-up - after having a very bad beach shoot - where it became a hazard - although since repaired.
Note - I believe Sirui has since released a heavier L-20 monopod head.
vision35
Gallery: 26 photos
Post edited over 3 years ago by vision35.
Sep 07, 2020 21:15 |  #12
I personally might be more concerned about potential camera body lens mount damage. Or the possibility of the monopod unscrewing. Just keep an eye on it. A large enough surface area in contact with the camera base should in theory reduce the possibility of mounting screw breakage.
Bianchi
Gallery: 41 photos
Sep 18, 2020 01:56 |  #13
Consider this head when using a Mono-Pod and Big Heavy lens
Larry ­ Johnson
Joined Sep 2011
Sep 19, 2020 20:18 as a reply to  @ Bianchi's post |  #14
Ordered!
Ain't Nature Grand!
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 19, 2020 21:42 |  #15
vision35 wrote in post #19121824 (external link)
With big lenses, you mount your kit from a lens tripod ring, not from the bottom of the camera.
4,101 views & 9 likes for this thread, 13 members have posted to it and it is followed by 9 members.
1689 guests, 140 members online
