davesrose wrote in post #18766492
I think you've done a good job with the first image. I recently was asked to scan an old 800 ISO 35mm negative, and found it challenging to try to get adequate contrast and noise reduction with all the apparent grain. I sided with getting good contrast that still showed some grain (800 ISO film was considered fairly grainy anyway). With your second image, I'm afraid you don't have much to work with. It's not just that it's out of focus, but the contrast is limited and the ladies faces are in shadow (so I'm not sure how much you can bring out contrast unless you're scanning from a negative). What software are you using? Myself, for individual photos I fine tune, I use Photoshop. I'd first be trying to see about painting in brightness with blend modes and seeing about sharpening with smart sharpen (maybe even exaggerating and masking in areas).
Yeah, what I'm thinking about with the faces being in shadow is some selective dodging with a paint brush on their faces to lighten them relative to the rest of the image (obviously using a layer so I can fine tune with opacity, and revisit the amount of dodging & burning I do).
I'm using Photoshop CC for this work - both for the import off my flatbed scanner, and the post-processing. I usually use USM for my sharpening purposes. I was able to bring a little extra definition to the faces via local contrast enhancement using the USM set to 10/50/0.
Thanks for the feedback & tips. I managed to get all those ridiculous scratches to disappear... but still have work to do to make the somewhat presentable. Again, it doens't have to be perfect, it's for nostalgia for these ladies, as in each of the images one of the ladies passed away this year. That said, I want to do the best that I can with the source material, both for my own pride and growth as a photographer & editor, and also for the finished product given to loved ones.
Here's the edit where I've removed the scratches from photo 2 (still a bit noisy, but not nearly finished editing this image):
