Practically, does the extra 2 stops or so of dynamic range with the 5D Mk 4 make much difference? Am I likely to get blue skies instead of white, for example?
I mostly shoot portraits.
icor1031 Goldmember More info Post edited over 4 years ago by icor1031. | Dec 08, 2018 18:31 | #1 Practically, does the extra 2 stops or so of dynamic range with the 5D Mk 4 make much difference? Am I likely to get blue skies instead of white, for example? Canon 5Ds || Zeiss Sonnar 135/2 || Zeiss Otus 85/1.4 || Sigma ART 85/1.4 || Sigma ART 50/1.4 || Tamron SP 35/1.4
ksbal Goldmember More info | Dec 08, 2018 19:26 | #2 are your portraits outside? are you shooting at 800 or less for ISO? Then you might see a difference. Godox/Flashpoint r2 system, plus some canon stuff.
Dec 08, 2018 20:06 | #3 ksbal wrote in post #18766992 are your portraits outside? are you shooting at 800 or less for ISO? Then you might see a difference. If we are talking studio portraits, then no, shouldn't see a difference. Outdoors (I mentioned blue sky) @ 100. Canon 5Ds || Zeiss Sonnar 135/2 || Zeiss Otus 85/1.4 || Sigma ART 85/1.4 || Sigma ART 50/1.4 || Tamron SP 35/1.4
ksbal Goldmember More info Post edited over 4 years ago by ksbal. (2 edits in all) | Dec 08, 2018 20:18 | #4 at 100iso, yes that will be significant, depending on how you expose, and what you want to do with it. Softbox: Godox/Flashpoint r2 system, plus some canon stuff.
davesrose Title Fairy still hasn't visited me! 4,568 posts Likes: 879 Joined Apr 2007 Location: Atlanta, GA More info | There may still be situations where you need to HDR, but I've found the DR to be a good improvement with the 5D4 vs 5D3 (my previous camera). Extra resolution also helps. As to whether you'll see a significant difference: with the 5D4, you can side with slight underexposure to get detail in highlights and then bring up shadows in post. If you contend with noise with your current process, then the extra DR will be noticeable. If you're shooting portrait outside, you can also save time with post if you have adequate lighting on your model. Canon 5D mk IV
ksbal Goldmember More info Post edited over 4 years ago by ksbal. | Dec 08, 2018 20:56 | #6 For example, here are a couple, with the sun directly behind the boys, even with highlights down and shadows up, it is hard to get this to match up. (no strobes, all natural) Image hosted by forum (949141) © ksbal [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (949142) © ksbal [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Godox/Flashpoint r2 system, plus some canon stuff.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 4 years ago by Wilt. (2 edits in all) | Dec 09, 2018 01:11 | #7 Some folks think 'dynamic range' is the measure of the range of exposure brightnesses that can be captured...for example, 13EV range from the darkest lit areas to the brightest lit areas. The 5DIII vs. the 5DIV is not that difference. In fact, dpreview tests generally have no longer included such a measure after days of the the Canon 50D (9 years ago) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Dec 09, 2018 02:27 | #8 Wilt wrote in post #18767150 Some folks think 'dynamic range' is the measure of the range of exposure brightnesses that can be captured...for example, 13EV range from the darkest lit areas to the brightest lit areas. The 5DIII vs. the 5DIV is not that difference. In fact, dpreview tests generally have no longer included such a measure after days of the the Canon 50D (9 years ago) Rather, the characteristic of 'exposure latitude' is where the 5DIV is markedly better than the 5DIII, in which the detail in the darker zones of exposure of a scene, when 'pushed' to bring up and make more visible the details in the shadow areas there is less visible 'banding' and other 'noise' amplified into greater visibility. This test illustrates the benefit... https://www.dpreview.com …s/canon-eos-5d-mark-iv/10 So then, where do I find a measurement comparing the former? And how does the 6D compare to the 5d mk iv? Canon 5Ds || Zeiss Sonnar 135/2 || Zeiss Otus 85/1.4 || Sigma ART 85/1.4 || Sigma ART 50/1.4 || Tamron SP 35/1.4
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | DXOMark does some measurements, and says dynamic range of the You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info Post edited over 4 years ago by tzalman. (2 edits in all) | Dec 09, 2018 04:56 | #10 Dynamic Range is the range from one fixed point to a variable point. The fixed point (same for every camera) is the point at which the senor wells are filled to saturation - more intense light (more photon input) will have no effect on that photo site, will not cause greater electron output. When the voltage value of a saturated sensel (pixel) is digitized it will always be 255 in 8 bit language or 16,383 in 14 bit. The actual number of photons required to fill the well may differ, but the constant will be that there is always a saturation point and it is always represented by 16,383. Let that many or more sky photons reach the sensor (exposure) and the sky will be white, period. That is the top of the DR. Image hosted by forum (949185) © tzalman [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. As you can see the 5D4 at ISO 100 will give you a usable image at 10.8 stops below saturation and the 6D will have problems under 9.3 below. [For instance, if you set exposure so that the sky comes in at 0.8 below saturation (clipping) in order to keep it nice and blue, the 5D4 can cleanly capture shadows that are 10 stops darker than the sky and the 6D will ground out at with shadows that are 8.5 stops darker than the sky.] BUT, that gap decreases until it disappears at ISO 1250/1600. In other words, in low light or fast action the 5D4 offers no advantage. Its main advantage is in well lit and contrasty situations, like landscapes. Elie / אלי
Amazing post. Canon 5Ds || Zeiss Sonnar 135/2 || Zeiss Otus 85/1.4 || Sigma ART 85/1.4 || Sigma ART 50/1.4 || Tamron SP 35/1.4
davesrose Title Fairy still hasn't visited me! 4,568 posts Likes: 879 Joined Apr 2007 Location: Atlanta, GA More info Post edited over 4 years ago by davesrose. | One of the main limiting factors for camera systems being 14 bit is the analog to digital converter (ADC) is 14 bit. There aren't that many sensors that go to 16 stops of light to warrant a 16bit system. A cinema camera: RED, actually has a sensor that gets close to 16 stops and has an ADC that's 16bits (and is the highest scorer at DxO). Canon 5D mk IV
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Dec 09, 2018 11:51 | #13 icor1031 wrote in post #18767014 Outdoors (I mentioned blue sky) @ 100. Might? So, not likely / not much / not significant? You seem to be asking about headroom; not DR per se. DR does not specify how much of it is headroom and how much is footroom (IQ-limiting shadow noise). I wonder if your issue isn't metering, rather than DR.
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Dec 09, 2018 12:15 | #14 icor1031 wrote in post #18767236 Amazing post. Why don't we go above 14 bits, then? Also, when it comes to editing - say I expose 0.9 low to retain more highlights. Do I then increase exposure by 0.9 in lightroom? That would turn it back into pure white? So, I also do minus highlights? The bits aren't the base-ISO DR problem with the majority of cameras. The problem is the analog "hiss" (random noise) and "hum" (banding noise) in the circuits that bring the readout signals from the readout amplifiers to the ADC. The 5D4 and 1DxII have 14 bits at ISO 100, but neither benefit from having 14 instead of 13. The only benefit of 14 is that when the firmware scales the RAW data, it has more precision to work with. At very high ISOs, 14 bits is actually absurd, and many cameras would suffer nothing from using only 4 or 5 bits at their highest ISOs.
BellPhoto Member 39 posts Likes: 9 Joined Dec 2018 More info Post edited over 4 years ago by BellPhoto. (2 edits in all) | Dec 17, 2018 23:10 | #15 icor1031 wrote in post #18766980 Practically, does the extra 2 stops or so of dynamic range with the 5D Mk 4 make much difference? Am I likely to get blue skies instead of white, for example? I mostly shoot portraits. As a fellow portrait shooter, DR is near the bottom of the list for us as far as importance goes. You want to look at the color depth which is far more important. However, DXO charts mean pretty much nothing when it comes to real world usage. All those little things some people obsess over in those tests in a lab have zero relevance in the real world because photos dont exist in a vacuum the way those tests are conducted. Many other variables come into play in the real world outside of a lab. You also want fast lenses, especially if you are shooting in lower light obviously. The 6D was my main camera the last 4 years before switching to Sony over the summer. I never once sat there wishing I had more DR, ever. Its a workhorse camera and its cheap.
| Latest registered member is semonsters 1706 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
